Question about Compaq Computers & Internet
My Compaq Presario CQ61 is making a vibrating noise and its coming from the vent but im sure its not dust that is blocking it what else can it be? i already updated the bios but that didnt help
    Sergeant:
    Champion:
  • 210 Answers
I dont think .the problem is with the bios or software of your system.
You may need to open the cabinet of your computer system and check out..Clean and Tight up the things.
Posted on May 17, 2011
Fit my Compaq Presario CQ61?
accu Compaq Presario CQ61 100 percent compatible with you Compaq Presario CQ61. I bought two Compaq Presario CQ61 batteries from http://www.accukorting.com/compaq-presario-cq61.html two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Nov 30, 2012 | Computers & Internet
I have a compaq notebook model CQ61-412NR and i already have the usb fan hooked up under it, but it still keeps getting very hott and shutting down. is it safe to take the cover off the back to clean the...
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Aug 22, 2011 | Compaq Presario Fan
My HP Compaq CQ61-445ed is making a weird vibrating noise after 5 mins when i startup or earlier, when i give it a soft smash you hear nothing and then after 2-4 minutes it comes again..
The noise is coming from one of the fans in your computer. This most commonly happens with the CPU/GPU fan. If you are a DIY-er, then you can take apart the casing, and blow some compressed air into the exposed fan. This should clear out any dust or debris lodged in the case. If you aren't comfortable doing it by yourself, I recommend visiting a computer store or a friend that's good with a small screwdriver, and have them do this for you.
May 16, 2011 | HP Compaq Presario v3000z Notebook
I need xp drivers for compaq presario cq61-sv300
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
May 15, 2011 | Compaq Presario Notebook
Compaq presario CQ61 is making a vibrating noise. it is constant
Two things,
1) Check if you have a CD/DVD in the disk-drive and remove it. The spinning disk is causing the vibration
2) Go to START > Control panel > PERFORMANCE AND MAINTENANCE > POWER OPTIONS >
In the middle of the dialog box, you should see a box that says "Turn off hard disks".
There you can select "After 3 minutes" or "After 5 minutes". This will turn off another spinning/vibrating thing if you have an issue with imbalance there.
3) Make sure you are not blocking the vent holes on the bottom of your laptop so air can get through and it doesn't overheat. The last spinning thing on your laptop is the cooling fan. This only comes on when it is hot. If you are doing a lot of calculations or heavy-duty computing will also make it hot but this is very rare (I guess some games can also be considered heavy-duty computing and cause overheating). If you are doing heavy-duty computing, there is nothing that can be done about he vibration of the cooling fan.
Good luck
May 06, 2011 | Computers & Internet
Compaq presario C 700 fan runs non stop
Make sure the air vents are clear when it is operating, also use a can of compressed air to blow out the dust from the vents and fan. This should make it cool more efficiently and the fan shouldnt run as much afterward.
Feb 23, 2011 | Compaq Presario Fan
MY LAPTOP MODEL COMPAQ PRESARIO C773TU is shutdown after some time because of overheating so what can i do please help me? If i need to clean the laptop from inside so please tell how to do this?
This can happen on Compaq/HP laptops when dust builds up on the CPU heat sink. If you have a can of compressed air, it's easy to clean.
First, TAKE IT OUTSIDE! It will make a tremendous cloud of stinky dust, and you don't want that in your living room.
Second, notice where the hot air blows out when the laptop is running. These vents are the EXHAUST vents.
Blow air into the exhaust vents, and dust will come out of the laptop, usually from vents just around a corner from the exhaust vents. The place where you just blew dust out is called the INLET vents.
Use your compressed air to blow into the EXHAUST vents, spraying side to side until you're not able to get more dust out.
Then do the same process on the INLET vents -- again spraying in to each part of the vent until you're not able to get any more dust to come out.
Finally, do one more pass at the EXHAUST vents.
Depending on your environment and usage, this process should solve the overheating problem for 12-18 more months before dust starts to build up again.
Jun 14, 2010 | Compaq Presario C700T Notebook
Computers & Internet Logo
60 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
