Question about HP Computers & Internet
I've problem with my CPU. When power on my system
    Sergeant:
    Champion:
  • 210 Answers
Delete temporary files from your sysytem
go in Start > Run ... type %temp% ... and Enter
a window will open...delete the files from that window
or the RAM memory you have is may be less . increase your RAM memory
Posted on May 17, 2011
My hp a 1410n desktop powers up but shuts down after five seconds
#1 on the list for this is shut down from over heat due to CPU fan not running or CPU overheat. Check to see if your CPU fan is turning on when your system is powering up. If its not.. thats your problem (get a new fan)... Even if it is it could mean the fan is not properly contacting the CPU with thermal paste. If this is the first time you\'ve powered the system up, your next step is to go out and get some thermal paste and put it under the CPU fan, if you\'ve been running the system and this problem just cropped up.. skip the thermal paste, its already there. #2 Next possibility is BIOs power settings are incompatible with your hardware. For example the frequency on the CPU is set higher then it can operate and its over heating. Some systems will automatically shut down and restart with default settings others you have to get into and set to default. can you get into BIOS? Can you reset your BIOS settings to defaults? Check your mother board manual. #3 A compenent is shorting out your system and needs to be replaced. Is the system posting prior to shutdown (beeping once on start up?) If its beeping more then once that means something else and you should read your manual. If its not beeping then its a short somewhere and you can bet you have a bad part in the system. To identify which part it is you can either disconnect things (RAM, Drives, vid card, PCI cards,ect) one at a time, attempting to start the system after each one or you can take everything but the bare bones out and try to start it. I usually take all the RAM out but one stick and start by testing them. Your RAM is the most likely place for a problem in this situation. #4 If you\'ve striped it down and it still can\'t get a boot (with no post beep). You need to replace the mother board.
Jan 18, 2014 | Computers & Internet
Tip
Why HP-p 077tx Laptop Working Slow and Fan RPM Is Maximum?
Is your HP-p 077tx laptop running slowly and making a lot of noise? If so, then it could be overheating.The electrical components in the PC make heat, and fans in the system help move the air to keep the modules from getting too warm. Extra heat will be the reason for fans to run continually, damage modules, and slow the CPU's speed.All of these failures with higher heat and power will cause the program to function slower than normal. If the Fan RPM is extreme all the time, it can be the first hint that your laptop isn't working efficiently. To run your system as cool and effectively as possible, either call at the HP technical support phone number or follow up one or more of the corrective actions given below.
Update your HP laptop BIOS
While computers are released, HP also distributes updated BIOS to manage CPU power loads, fans, and other modules. Before updating the BIOS, make sure that what BIOS version is currently installed on your system. If it's outdated, then update it to the new version available on the HP's official website. For complete information to find new BIOS version and know the instructions for updating your laptop BIOS, consult with the HP technicians to get the necessary help.
Improve the laptop efficiency to reduce heat
If you have various applications running on your system, it functions harder and creates more heat.Decrease the heat amount by improving the laptop efficiency. Here's how to do:
    ·Stop your application from initiating while the system is started.
    ·Close the additional programs if you're not using them.
    ·Disconnect the Internet if you're not surfing the web.
    ·If your laptop gets too hot while playing games, then try to play the game at a lower resolution and with reduced graphics settings.
    Identify corrupt processes using Windows Task Manager
    The regular CPU load can be the reason of heat buildup in the computing device, forcing the fan to work regularly to keep the system at functioning temperatures. Sometimes, corrupt program or malware can cause the heat buildup. A corrupt program can consume CPU time wherever between 1% and 100%. Follow the steps to find corrupt processes that might be making CPU slower.
      1.Save your work and end up all open applications.
      2.Press Ctrl-Alt-Delete keys all at once. Click the 'Task Manager' to reveal the Windows Task Manager window.
      3.Choose the 'Processes' tab, and to specify the processes by CPU load, and then click the CPU column header.
      4.Navigate the list of suspect processes.
      To identify more details about a process, browse the Internet to find the procedure name that shows in the Windows Task Manager. You can also avail tech support for HP laptop and get the suggestions for solving the issues.
      Keep your Laptop air vents clear and clean
      When heat builds up due to the regular use of the system, the fan spins faster to eliminate the excess warm and thus make the noise. HP laptop has vents in the bottom and sides to eradicate heat, letting air flow via the case. If the vents become blocked, the fan can't cool the components correctly. So, clean the dust if you find it out and inside the vents. While using your laptop, put it on a hard, smooth surface to keep the vent areas unblocked.
      Choose power save settings
      Try to choose the power save settings to shut your laptop off while it's not in use. Many operating systems let you change the power settings to turn off the screen while you're not regularly using your system. If you often leave your laptop in between your work, changing the power settings to power off your monitor while it's not being used can let your laptop functioning at a cooler temperature.
hp-p 077tx laptop working slow and fan rpm is maximum-lcsxb1y3zo4krmesmbi1txpa-3-0.jpg
on Jan 20, 2017 | HP Pavilion Computers & Internet
How to fix CPU power supply?
You CAN remove and open the PSU, but if you were to disassemble the PSU, you would likely find that the fan is soldered to the board in there. At least I have the dozen or so times I've looked. Generally a stock fan of the same size will work, but make sure the size is correct. and you'll still have to solder it 'natch.
Tallon41
Sep 13, 2012 | Dell Computers & Internet
Fujitsu Siemens CPU Fan does not spin?
First check to make certain the fan is plugged into the motherboard.
Follow the connector from the cooler unit to the m.b.
When you've located the proper plug - unplug it and then re-plug it back in, making sure it is firmly plugged in (make sure you turn off the power and unplug from the wall before doing any of this).
Then look at the fan closely and make sure it's not overly dusty or dirty.
This can clog up the fan and cause it to stop working.
If you've done all this and powered back up, and it's still not working - then you need to get a new fan.
Do not run your system without this cooling fan because you can fry your CPU.
DO NOT ATTEMPT TO OIL OR LUBE FAN THIS CAN END IN DISASTER
hope this helps
Aug 15, 2012 | Computers & Internet
2003 Mitsubishi Diamante, power loss
If your car idles and runs smooth after everything you've done, I would almost say clogged catalytic converter just by the power loss.
Jul 19, 2012 | 2003 Mitsubishi Diamante
URC8803
1) read carefully the instr. manual, normally you must keep the code by ENTER, once you put the codes, if this does not pass problem with the microcontroller or CPU, inside the R.CONTROL.
2) test the contacts cleaner+resolder the wires connector batteries
3) open the r.control and resolder the dry joints in the board. otherwise you must go to the repair shop TV for fix it.
see the diagram.
Jul 16, 2012 | Televison & Video
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
Hi my name is Steve, my Acer M5811 CPU fan is running at high speeds since a couple of months now and after 2 minutes of gaming, it's game over for my Acer. I've applied cooling gel to no avail. I...
Well if the fan is runing at top speed I dont think you have a bad fan, if you re-pasted the CPU correctly (I suppose you cleaned the dust build up in the heat radiator as well) since you had it in your hands... I dont think it's radiator dirt, and if the system POST (Power On Self Test) an can boot in to the OS (Operating System) I don't think it's the CPU either... The only thing I could think of is a power supply issue, try an other one, or a bad component RAM, PCI CARD, ETC... (but befor spending money) unpluge averithing you can leaving just the power, CPU, RAM and start the computer, if it POST and the fans are at a normal speed, than power down the computer and plug back stuff ONE AT A TIME to determine which of the components is causing the problem, if not sucsessful than try an other power supply or other RAM modules...
Cheers!
Sep 08, 2011 | Computers & Internet
Hello, I've got a Dell Optiplex GX280 series desktop pc which has refused to boot up. Instead it shows an error saying "Alert! chipset heat sink not detected system halted! Would appreciate your...
Both your CPU and chipset have heatsinks to dissipate the heat they generate.
Over times, the heatsink compound between these components and the heatsinks
may dry up and no longer conducts heat efficiently. Your system on power up,
detects excessive heat from the chipset and if allowed to continue on, will burn
itself up. To protect it, your system shuts itself down.
Open up your case and inspect the chipset. Make sure the fan (if any) is running.
If it is, you may have to remove the heatsink (normally clipped on to the chipset)
and remove the old compound and apply a fresh new layer of heatsink grease.
While you are at it, also replace the heatsink compound of your CPU.
Jul 11, 2011 | Dell Optiplex GX280 (99301) Motherboard
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
