Question about Hayward Sand Filter System & Tank 21" 1 1/2 Hp
The pressure keeps creeping up to 30-35 psi. what seems to be the problem and how can I fix it?
    President:
  • Hayward Master
  • 1,378 Answers
If you are certain the gauge is accurate (does it return to zero when the system is off?) and the system has worked well in years past it means your sand bed has deteriorated to the point that backwashing no longer removes enough debris and/or the sand is worn enough as to become to compacted in the tank. Either way it means it is time to remove at least the top several inches of sand and replace it with one 50# bag or better yet, remove all the old sand and refill the tank with new sand in the amount indicated on the label under media...it will be in multiples of 50#.
John
Posted on May 17, 2011
How do I increase the pressure on my Flotec FP711OT-08. It is low 40s psi, can I move it up to 50 psi or high 50 psi? Water pressure throughout the house is low.
There may be a pressure setting on your outfit but My feeling is -- your problem will be low pressure on your water line. Most pressure settings is to keep from having too much pressure on what your running. For instance our city water pressure is 70 lbs but in order to keep my furnace boiler system at 16 lbs I have to install a pressure reducer.
Nov 23, 2014 | Pentair Flotec Fp7110t-08 Water Tank...
I have a 175 pull behind IR compressor. When trying to set the high Idle I open the valve so that it is reading 100psi, the motor trys to throtle up but it seems under to much of a load. also when it drops...
100 psi is around the pressure that the engine goes back to idle
it should start to go to fast rpm when the pressure drops to around 75 psi
if it is trying to increase rpm at 100 psi , the engine is under load and that is your problem
Dec 19, 2017 | Ingersoll Rand P185WJD Platinum Series Air...
Schematics for a scubapro mk17 regulator
these are controlled by scubapro due to they need specail testing equipment to repair regulators E..G now IP pressure is 135 psi and there is no adjusting screw shims and springs then the cracking effort test to see if you have pressure flutter or creep. these can not be seen with out testing equipment.
Mar 18, 2012 | Scubapro Scuba Diving & Snorkeling
Dewalt air compressor keeps running until pressure output is 200 PSI, the same pressure in the tank. Why doesn't it quit running at 120 PSI the designated pressure on the compressor?
The regulator switch/unloader is bad or out of adjustment. Perhaps though the gauge is faulty. 200 psi in a 120psi compressor is dangerous, don't run it until it is fixed!
Dec 15, 2010 | Dewalt Air Tools & Compressors
I SEEM TO BE HAVING A PROBLEM WITH MY TANK PRESSURE. MY TANK PRESSURE SITS AT ABOUT 80 PSI AND THE REGULATED PRESSURE SITS AT ABOUT 70 PSI,IT DOES NOT GO ANY HIGHER, IS THIS NORMAL AND IF NOT WHAT DO I...
The C6110 is an oil free air compressor and has a piston ring that needs to be replace as part of regular service.
When the piston ring is worn out it will just keep pumping but it will not go over 80 psi or so because to much ir is passing by the ring.
Here is a parts diagram:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/C6110/C6110_PL.pdf
It sounds like the piston ring DAC-308 needs to be replaced. You can also replace the complete top end.
This is a pretty easy repair and can be done in less that 1 hour.
Sep 27, 2010 | Porter Cable C6110 150 PSI 25 Gal OilFree...
My john deer 3800 psi gas pressure washer
I would suggest taking it back if its brand new, even if you lost the receipt most stores can look up the sale to verify that its with the time frame for return.
Dec 13, 2009 | Garden
Starts fine, but then bogs out when accelerating, practicaly have to give it no gas and creep up to speed.Doesn't want to go up hills. Just replaced the cpi, fuel filter and fuel pump 3 months ago. Also...
Check the fuel pressure regulator and the EGR valve, I would check the fuel pressure regulator first and go from there. Good luck and keep me posted. Not sure what the pressure should be but thinking it's 62 to 65 PSI upon start up and should drop 5 PSI when engine running, check the vacuum line to the regulator.
Dec 09, 2009 | 1993 Chevrolet S-10 Blazer
Hayward Sand Filter System & Tank 21" 1 1/2 Hp Logo
70 people viewed this question
Top Hayward Garden Experts
Craig Butler
Craig Butler
Bill Boyd
Pushkar Singh
Pushkar Singh
Are you a Hayward Garden Expert? Answer questions, earn points and help others
