Question about Hotpoint Dryers
My hotpoint TVM570 dryer is heating up but not turning.
    Master:
    Sergeant:
  • 385 Answers
Probably have a broken belt.
Posted on May 17, 2011
My hotpoint Aquarius tumble dryer isn't heating, model tvm570
heating elements do burn out . call a repair service locally
Dec 02, 2016 | Hotpoint Dryers
Replaceing belt tvm570
That dryer works very similar to a dryer I worked on not long ago with same idler. basic electrolux style dryer with various hotp[oint ge name brands attached to it.
Dec 27, 2013 | Hotpoint NVL333GY Gas Dryer
Hotpoint tvm570 not spinning
-Possibly broken belt.
-Do you still heard the motor spin...? If so the belt is broken.
Good Luck
Mai
Dec 19, 2013 | Dryers
Hotpoint aquarius tvm570 dryer
Either the belt is broken or possibly the motor starter has failed. Very often the belt. Be warned though, modern day tumble dryers use stretch belts that can be very difficult to fit.
Oct 18, 2013 | Hotpoint Dryers
My Hotpoint Aquarius TVM570 started making a funny noise then cut out... I changed the fuse to see if it was that but no luck. You can turn the timer but as soon as you press 'start' it just trips...
if you check this link it shows the basics for getting in the dryer ,, after that , you may have to remove the vent tube inside ,, you will see a fan attached to the back of the motor, your missing Rib could be rubbing against that or possibly even the drum as it turns,, be sure and unplug the machine anytime you remove the back
Jun 12, 2011 | Hotpoint Dryers
Problem with hotpoint as66vvxna1 dryer
There are a couple of things that you can check. FIRST go to the electrical box where the circuit breaker or fuse for the dryer is. Sometimes on half of the circuit breaker is tripped allowing the controls of the dryer to work, but not the heating element. Turn off the breaker and turn back on. Or replace the fusees. If this does not work, then you may have a loos wire or a burned out heating element. Sometimes there is a bad high temperature switch. Do the circuit breaker or fuse first. If the washer did not spin out the water well enough, the water can short the element to trip the circuit breaker or blow a fuse.
May 26, 2010 | Hotpoint Ariston AS66VXNA1 Electric Dryer
My hotpoint ctd00 wont heat up
I would suggest that you check the heater and thermostats, these are located behind a removeable cover at the rear of the dryer.
You will need a meter to test them with, you are checking for continuity
Feb 10, 2010 | Hotpoint Dryers
Hotpoint dryer nvl333eyoww
You need to check the heater element and or thermostats for continuity. You will need a meter to do this
Replace if found to open circuit.
Plz rate this solution.
Thanks.
Dec 17, 2008 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
213 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
