Dryers Logo
Darrell Diehl Posted on May 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Soleus FS1-40R-41 Stand Fan When the fan is turned on, it takes 10-15 minutes for the blades to begin turning. If left in oscillate mode when turned off, it will oscillate immediately when turned back on, but the blades turning are still delayed. Can the delay in the blades beginning to turn be economically fixed? If not, is it safe to run the fan in the existing condition?
  • 2 more comments
  • Darrell Diehl May 17, 2011
    I had already tried to lubricate earlier - no luck.
    In checking it now, the motor shaft turns VERY hard. In trying to access the motor, I need to first remove the plastic cover. I removed the 4 screws that secure the plastic cover to the front of the motor, but I can't figure out how to remove the plastic cover further - removing the 4 screws only allows the cover to loosely move around the motor.
    It looks like there are 4 tabs on the front piece of the plastic cover that secure it to the rest of the plastic cover. How do you remove the plastic cover without ruining it in order to access the motor?
    I managed to get the plastic cover off of the motor.
    There is no knob at the top - this fan oscillates with a separate motor - no knob.
    After lubricating both the front of the shaft and the back of the shaft several times and turning the shaft to try to get the lube into the fitting, the shaft still turns very hard. I have it plugged in now and powered it up, trying to get it going, but it still has not yet started turning after being powered up for 5 minutes.
    Please advise.
    After a while longer, the fan finally got going. Before it got going, there was a faint hum coming from the motor. I let it run for a minute, then turned it off and lubed it some more, and then let it run a minute longer to try to get the lube into the bushing/bearings. The motor was very hot.
    I really don't think that lubricating this is going to solve this issue - what do you think?
    After a while longer, the fan finally got going. Before it got going, there was a faint hum coming from the motor. I let it run for a minute, then turned it off and lubed it some more, and then let it run a minute longer to try to get the lube into the bushing/bearings. The motor was very hot. I really don't think that lubricating this is going to solve this issue - what do you think?
    I managed to get the plastic cover off of the motor. There is no knob at the top - this fan oscillates with a separate motor - no knob. After lubricating both the front of the shaft and the back of the shaft several times and turning the shaft to try to get the lube into the fitting, the shaft still turns very hard. I have it plugged in now and powered it up, trying to get it going, but it still has not yet started turning after being powered up for 5 minutes. Please advise.
Anonymous
Level 3:
  • Soleus Master 43,501 Answers
  • Posted on May 17, 2011
Anonymous
Soleus Master
Level 3:
Answers
43501
Questions
0
Helped
10844735
Points
101584
Try lubing the fan with a penetrating oil like WD-40 or PB Blaster first before using regular oil.
Also setting the fan on it's front and back for a while to allow the penetrating oil to get into the bearing will help..once the motor is working freely then use a light motor oil to permanently lube the motor, also setting it on it's front and back for a few hours at a time to allow the oil to run into the bearing.
heatman101
Anonymous
Level 3:
  • Master 2,098 Answers
Anonymous
Master
Level 3:
Answers
2098
Questions
Helped
456513
Points
6457
This kind of symptom can be cure by lubricating the shafting and bushing of the fan. You may used any lubricating oil available. Picture below is not an actual picture of your unit but will help you identify and locate where lubrication will be done.
If the symptom still persist after you lubricate the shafting, this is an indication of faulty capacitor. This is inside the motor assembly. Open the back cover of the motor and you will see a black rectangular with two wires on it(that is the capacitor). Replaced this parts and your unit will back to normal operation again(two wires has no polarity, meaning you may connect it even in what way). Don't allow the unit stand for so long without oscillating the blade, it will damaged the motor.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
  • Anonymous May 17, 2011
    Most of the fan is secured with one screw at the back, you must also pull-out the oscillating knob at the top. If the shaft is hard to turn then the cap is not the issue here but the shafting itself. It is better to take it apart and clean it from dust then lubricate also the other end of the shaft...
Restoration Hardware Allaire No. 16 fan. It stopped oscillating and just clicks?
Question edited for clarity.
Question moved from Laundry Dryers.
There is a gear stuck or broken. It needs stripping and cleaning. Videos that should help.
https://www.google.com/search?q=allaire+no+16+fan+not+oscillating
Soleus Air FSH-40G fan would not start. The bad seems harder to rotate. what could have gone wrong? How to fix?
First unplug the fan for safety. Next add a couple drops of motor oil on the shaft that turns with the fan blade. Tip the fan blade at about a 45 degree angle when adding the motor oil. Spin the blade by hand at that same angle to allow the motor oil to flow down the shaft, inside where you cannot see the shaft. It should start turning by hand a lot easier now.
What does the "swing" button do on the soleus ac/heat remote control?
The swing button on the unit itself turns on the horizontal oscillation of the louvers. The remote's swing button adjusts the speed of the oscillation. In the fan mode, it lets the Soleus Air Conditioner circulate more air.
Home Depot has the manual for Soleus PH3-12R-03 here: http://www.homedepot.com/catalog/pdfimages/d4/d4382c05-2692-4075-a254-fdcdef6dc1fb.pdf . The buttons are the same across the units.
I hope this helps.
How do I fix my fan so it has fan movement when I turn it on, any speed?
Fan oscillations are typically started or stopped by a knob at the top of the motor housing. Sometimes the knob has to be pulled to engage the mechanism, sometimes pushed in and sometimes it has to be twisted several turns to the left or right, usually it is several turns anticlockwise.
The lights come on but the fan blade doesnt turn
Check the thermal fuse located inside the motor fan winding wire. Check the crystal oscillator and micro-controller located in the printed control board of the fan. When it is replace with similar type, the fan will function again and ready to be use.
Thanks for asking.
Wiring
12,000-BTU Portable Air Conditioner with Manual ... 3135 30-Inch Oscillating Industrial-Grade Pedestal Fan ~ Lasko ... 42.62 : Soleus Air FCM-30 12-Inch Convertible Stand/Table Fan ...
5helpful
2answers
Accutek stand fan just hums, won't turn
That means the bearings are dry and have locked. Simply open the motor cover by removing the screw and pull the oscillation knob by rocking it side by side gently to have free access to the motor.
MAKE SURE THE FAN IS UNPLUG FIRST. Use cream type grease on both ends of the shaft. After applying the grease rotate the blades until they're freely and you feel the blades have released.
Place the motor cover back and the oscillation knob and plug-in the fan. Leave it on HIGH for 10-minutes or more to make the rotor loose with the grease.
2answers
3helpful
Fan makes clicking noise when oscillating
inside the motor there is a nylon gear that is broken. the oscillation operates off a gear connected to the motor drive.
Top Soleus Dryers Experts
john h
Are you a Soleus Dryer Expert? Answer questions, earn points and help others
