Question about Motorola Mobility RAZR V3i Cellular Phone
My screen is black on my 4 month razr
Do you know what i can do about the black screen on my new cell phone?
  • epowell823 Aug 16, 2008
    got new raz phone lasted 2hr screen went black tried pressure and checking connections but no help
    epowell823@cox.net
    Brigadier General:
  • 7,752 Answers
Berg - you need to replaced the LCD or the flexcable in the phone if only when you boot the phone up the keypad only lits up.
Epowell823 - replaced the lcd or phone
Posted on Sep 13, 2008
Droid Razr M
if the screen is black then you need to replace with new one.droid phone lcd has flex cable so I don't think it just loose.thanks.
Nov 15, 2013 | Motorola Mobility XT907 DROID RAZR M...
Free motorola cingular subsidy password
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 31, 2012 | Motorola Mobility V3 Razr At&t / Cingular...
Razr v3x screen suddenly won't work even with phone turned on. Yesterday it was working just fine then this morning lcd is dead. I can hear it when somebody sends me an sms but I cannot read it since...
check the oem ribbon that runs to screen. the design of phone hinge is faulty, and usually cuts the ribbon that runs up to the screen after months of openings and closings,preventing it from lighting up. sometimes its the earpiece wires on the ribbon that get cut which prohibits u from hearing anything when u hold the phone to your ear and u have to switch to speaker...bummer..sooo my friend, CHECK THE RIBBON.
Mar 11, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Broken Front LCD Screen On A Motorola RAZR V3C?
I have been buying and repairing razrs for a month now and know how to do this well first of all you will need a t6 screwdriver to take out the 4 screws then you need to seperate the housing with a credit card or somthing thin it may be a little tight but dont worry about it breaking it will come off some have two little flex cables connected and some have one check yours and disconnect then carfully pull your lcd out and put your new one in.
Sep 22, 2008 | Motorola Mobility RAZR V3
My phone stopped working
You'll need a new phone. RAZRs die a lot, and they start their final journey this way - with smaller malfunctions that end up leading to death. Move your contacts to the SIM card if you get the phone to function again, and go get a new one soon. This one's on the way out.
Jul 05, 2008 | Motorola Mobility RAZR V3
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 display went out
Either your flex cable is broken or came loose. Is the top left hinge button still intact? Is it loose at the hinge? You will need a Torx 4 screwdriver to take the LCD screen apart to check the flex cable inside.
May 30, 2008 | Motorola Mobility RAZR V3
Problem
Try the phone while plugged in and see what happens.  If it works fine then it's probably the battery or the contacts to the battery.  I've had a problem with my razr that's similar to this.  My razr is on the keys light up when i press something but the screen is completely blank open and closed and all the buttons work.  Best thing to try is leave out with battery and sim card out and it might start working again.  However if it is only 2 months old it should still be covered under warranty.
Oct 17, 2007 | Motorola Mobility RAZR V3
Razr v3c the screen is dim all the time
it would be your display light is out and as far as I know the only way to fix that is to get a whole new LCD screen assembly. If that is the case go buy a new phone and not a RZR I know it's popular but honestly I've seen hundred's of them in my store busted and unusable after only a month or so. Not all motorola phones are bad but this one is the biggest piece of crap. I rank it with Kyocera phones!!!!!!
Feb 18, 2007 | Motorola Mobility RAZR V3
HELP!! my hot pink razr v3 has a red line constantly in the middle of the internal sreen..
take this to your provider to have fixed the sceern has broke in either a cable losse or a crack but thell fix it.
Sep 03, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3i Cellular Phone Logo
69 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
