Question about Sanyo EMS2298R Microwave Oven
It wont heat up my food - Sanyo EMS2298R Microwave Oven
How do I reset the microwave so it can heat up my food?
Posted on Jul 02, 2011
  • 3,051 Answers
Hello there and thank you for choosing fixya
Whenever a microwave will not heat up food this is normally due to a failure of 1 of 3 things
First is the mengatron Magnetrons are made of magnets that conduct an electrical circuit, thus creating the energy needed to cook food in the microwave. Although magnetrons are durable, they will eventually begin to fail. If a microwave begins to lose the capacity to heat, the problem is most likely the magnetron. Testing the voltage in the magnetron is done using a device called an ohmmeter it is tested like this
Unplug the microwave from the wall and turn it around so that you are facing the back of it.Remove the screws in the back cover and the sides then remove the outer shell it should slide back a bit then up and off
Locate the high-voltage capacitor, an oval-shaped cylinder, and place the tip of an insulated screwdriver on top of one of the metal terminals protruding from the top of it. Tilt the other end of the screwdriver downward slightly until the metal part touches the other metal terminal. You may hear a popping or crackling sound, which is energy being discharged. Remove the screwdriver from the terminals.
Place the tip of screwdriver back onto the first terminal and tilt the other end of the screwdriver until the metal touches the metal base that the capacitor sits on. Hold for a few seconds, during which time you may hear a popping sound. Repeat the procedure with the other terminal. i will finish this in a second post
Posted on May 17, 2011
  • Michael Thomas
    Michael Thomas May 17, 2011
    Locate the magnetron, which is a square, metal box with two cylinders
    extending from it. Disconnect the cables that extend from the cylinders
    by pulling them out of the base of the magnetron.
    looks something like this
    Now once you have your ohm meter do the following
    Turn on the ohmmeter and set it to the lowest setting. Place one wire
    lead from the ohmmeter on the left terminal of the magnetron and place
    the other wire lead from the ohmmeter onto the right terminal.
    Look at the display on the ohmmeter.The reading should be less than 1
    ohm if the magnetron is still good. If the reading reaches 1 ohm or
    higher, the magnetron is defective.
Wont heat food up
the magnatron is probably burnt up...
how old is the unit?
what brand and model is it?
Mar 24, 2013 | Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Not heating food but will heat plate. wont pop popcorn. takes three times as long to heat food even if on a paper plate
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Mar 04, 2010 | Sharp R-55TS Microwave Oven
Wont heat
heatman101
jkfk
Nov 06, 2009 | GE Profile Spacemaker JVM1871 Microwave...
Microwave has power but wont heat food
Nothing to do with programing if it doesnt heat you have a bad magnaton or a bad capacator. I work on panasonic microwaves every day.
Sep 27, 2009 | Whirlpool MH7140XF Microwave Oven
Wont heat food
It could be that the "grinding" noise was actually "arcing" taking place inside the cavity or uder the cover. The magnatron is possibly damaged or the h.v. diode. Should be repaired by qualified repairman
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Sanyo EMS2298R Microwave Oven Logo
185 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
