To be able to scan to pdf a special program must be used. This program must be licenced from Adobe, at a great cost and with a lot of limitations. Because of that the program is available only on the install disk that comes with the printer. Since the original install disk has only the XP drivers it means that there is no official conversion program available.
You will have to scan your files to an image format - bmp is the best here - and then convert it with another separate program. This one will do just hat and it's free
http://www.softpedia.com/get/Multimedia/Graphic/Image-Convertors/Image-to-PDF-Converter-Free.shtml
Welcome to Fixya. You can use a converter to convert the image file to Pdf. Just click on the link below.
Jpg to Pdf Converter Download
Thanks for using Fixya
converter jpeg to pdf does not solve our problem as the files have to be searchable in the end. I do want that my scans are sent to either pdf or MS word2010. We have Acrobat X standard installed on our system. Under the old installation the scanner opended the HP Scan Center Software where the final destination of my file could be fixed.
