Question about Brother DCP-7030 Digital All-in-One Laser Printer
Cannot read new refill toner. - Brother DCP-7030 Digital All-in-One Laser Printer
  • 133 Answers
Brother is not recommend anyone to use generic toner with the original setting.
so you have to format the original setting by
open the front cover,
press option
then start
then 00
after all, the screen will show "accepted"
close the front cover, and you are ready to go
Posted on May 17, 2011
AR5731 Undetected
Dear
The refill guy may done somthing which by pass the CRUM chip. At your end you may check the module attached to the toner cart.and test with alter that chip.
This may solve.
Before doing this pl.check the errorcode display .there might be other related problem with the machine.
Thanks.
Feb 04, 2015 | Office Equipment & Supplies
Brother printer MFC 7440 N says to replace toner and I already did
Did you insert a brand new toner cartridge or refill only, if you insert a brand new they read your toner cartridge, if you insert a refill toner cartridge, first you need to reset the toner cartridge, i think in the right side, or left please switch and back to normal position.
Aug 16, 2014 | Brother MFC-7440N Laser Printer
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
"set the toner cartridge correctly"
Possible the chip that reads the toner bottles shorted out.
Try new bottles. If that don't work, the board in the machine that reads them need replacing.
You will need a technician to replace them.
Mar 29, 2017 | Ricoh SP C430DN Laser Printer
My printer is complaining of low toner, after refilling.
Did you replace the toner cart with a new one there are electronic chip on some toners that printer will read to determine if the same one or new
Jul 11, 2011 | Minolta Color PagePro PS Plus Laser...
New Samsung toner cart reads LOW
This is due to a sensor that reads the actual cartridge is defective not the actual cartridge or the cartridge is one that was refilled and thus not put back togeather the way it should have been. So its ether or a refilled cartridge or a bad sensor. Both req. repair in some sort.
Thanks for your free question, your free answer was delivered please do rate or leave some feedback.
Apr 22, 2010 | Samsung ML-2510 Laser Printer
Toner refill
IMPORTANT: This will most assuredly destroy your printer. The toner cartridge must be completely rebuilt with new seals, also. This is why the cheap replacements occasionally leak toner. That toner powder gets down in your printer & onto the fuser. This will cause the fuser to have different temperatures along its path, ultimately rendering it useless.
I strongly suggest that you buy a genuine HP toner refill.
Jan 21, 2009 | HP LaserJet 1005w Printer
HL-4040CN don't show or read new refilled magenta cartridge.
If you have removed and reinstalled the magenta cartridge several times, it is very likely the cartridge is defective out of the box. If you have another magenta cartridge, put that one in and see if the problem resolves. I'm betting it will. If that second cartridge does work, then return the defective cartridge to where you purchased it - they should replace it without a hassle.
May 10, 2008 | Brother HL 1440 Laser Printer
Resetting Toner count onprint settings PRINT SETTINGS report
I don't suggest refilling cartridges as I work on printers every day but seems to me that you have done everything correctly the only thing I think you have done is either filled with incorrect toner thus giving a incorrect reading or when moving gear you have dislodged the pin that activates the reset procedure.
Thanks J
Jan 14, 2008 | Brother HL-2040 Laser Printer
Samsung ml2010 has faint printing
There could be 2 problems. 1. The "Toner Save" option is turned on. You could disable this by clicking on the toner save button or disabling it in the printer drivers. 2. Trying shaking the Toner cartridge. (This sounds crude but believe me it has worked many times).
Dec 20, 2007 | Samsung ML 2010 Laser Printer
Brother DCP-7030 Digital All-in-One Laser Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
