Question about OKI MICROLINE 320 Turbo Matrix Printer
I HV HD 755 TVS PRINTER - THE PAPER SPROCKETS ROLLERS ARE BROKEN - REQUIRE BOTH SPROCKETS RQ INFORM WHERE CAN BUY 2 PIECES ONE FOR LEFT AND OTHER FOR RIGHT SIDE.
  • brungta May 18, 2011
    MY HD 755 PRINTER PAPER FEEDER ROLLERS ARE BROKEN AS THEY R MADE OF SOFT PVC MATERIAL I THINK. I WISH TO BUY BOTH PAPER ROLLERS IN MUMBAI IN INDIA. UNABLE TO LOCATE RESELLER OF AUTHORISED SERVICE CENTER. CAN ANY ONE INFORM WHOM I SHOULD CONTACT FOR OBTAINING REPLACEMENT OF PAPER FEED ROLLERS. B B RUNGTA
2 Suggested Answers
savers2008
  • 286 Answers
SOURCE: i need TVS hd 755
I would suggest you go online and try the manufacturers , if you get no help from them try ....... driversguide.com or drivershq.com
Posted on Apr 15, 2011
Hp laserjet 2420 paper jam 13.20.00
Hi, check throughout the printer for small pieces of paper stuck, broken sensors etc, clean the rollers in the paper tray 2, check for wear. clean the registration rollers (under a metal flap under the print cartridge) do not clean the transfer roller (the spongey roller sitting under the drum!)
Feb 09, 2010 | HP LaserJet 2420 Printer
Paper feeds only from left side and gets jammed
Looks like the feeding mechanism is stuffed.
Perhaps try and get a broken one of some trade website and replace the mechanism, but MP210 is pretty cheap model this days and my personal recomendation is to bin this printer and buy new one.
It will save you some time and frustration.
Dec 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper roller on the left side of printer will not feed the paper
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Out of paper message, won't feed paper
The feed roller was turning but the paper wasn't moving and so I kept getting an "out of paper message." The paper was actually getting caught on a small black piece in the back of the printer. I removed the black piece and the paper start to feed fine.
Remove the back access door (it just pops out... no screwdriver required). The black guide piece (2nd from left) is about the size of my little toe after I took it out. Use a flat head screw driver to pop it out... that should leave 3 black guide pieces left. Put the access door back on the printer and the problem should be solved.
May 20, 2009 | HP PSC 1610 All-In-One Printer, Scanner...
1610 all in one.....won't grab paper
Remove the back access door (it just pops out... no screwdriver required). The black guide piece (2nd from left) is about the size of my little toe after I took it out. Use a flat head screw driver to pop it out... that should leave 3 black guide pieces left. Put the access door back on the printer and the problem should be solved.cf725f2.jpg
Jan 30, 2009 | HP PSC 1610v All-in-One Printer
Lexmarkx73 Won't feed paper through while printing
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
HP PSC 1315 Paper Feed Problem
Remove the back panel or the duplexer if you have one attached (no tools required). Then locate the pinch wheel which is on the left hand side, about 4-5 cm in and from the left (looking from the back). With a cotton bud reach in and wipe the roller. push your little finger in to gently rotate the roller bit by bit so that you clean the whole roller. Only touch the side of the roller with your finger, so that you don't leave residues.
HP recommends that you use a little distilled, sterile or bottled water on the bud, but not tap water. I found that just using a dry bud worked to remove the build up of dust from the roller.
This succesfully got my PSC 1317 picking up paper again. I think it will apply to other printers in the PSC 1300 series.
Jun 25, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer/copier is spitting out pieces of thin plastic film/tan on one side and dark grey on the other. Paper is jamming and discoloration on one side of the sheets all the way down.
If it is clear thin plastic like saran wrap, then that is probably the fuser roller sleeve.
The only way to repair that is replacing the rollers or fuser unit.
That would be a cause for the jamming also.
Replacing the fuser unit or the fuser rollers will probably require a service technician to come in to replace these parts.
Most copier companies do not make the fuser unit customer replaceable except for a very few makes and models.
Sorry I couldnt give you some more information.
I hope this information still helped you a bit.
Good luck.
Mac =)
Mar 29, 2008 | Canon imageCLASS D761 Copier
Printer jams
Have you checked the paper path for anything which might be lodged there? A small crumpled piece of paper, paper clip, or even some broken piece of plastic from inside the printer itself. Are the rubber rollers extremely dirty/covered with paper dust? Depending on the design of the printer, one set of rollers may be spring loaded, and if the spring is broken, disconnected etc, the tension on the roller of course goes away. Anything like this will prevent proper paper movement through the printer
May 29, 2007 | HP OfficeJet G85 All-In-One InkJet Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
123 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
