Question about GPS
MY GPS MODEL HAVE ERROR #2 CALL \SDMMC\NAVIGATOR\SIGN,EXE
SOURCE: intellinav.exe application error
I HAVE THE SAME PROBLEM. FROM WHAT I CAN TELL THE UNIT HAS TO BE SENT IN TO BE FIXED. FUTURE SOLUTION TO THIS PROBLEM IS NEVER EVER BUY SOMETHING WITH THE NAME NEXTAR ON IT............
Posted on Jan 13, 2008
Did you try the switch on the back of the GPS? Turn off on the front, turn the switch on the back off, then on. This has worked for me numerous times.
Posted on Jul 02, 2008
rockitman187
  • 2559 Answers
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Posted on Jan 29, 2009
SOURCE: Nokia 500 gps. Display
Try this, I have similar issue with the unit freezes and has a box in upper right corner. Go to the Nokia website, download their software update wizard and follow the instruction. It will flash the unit and fix the issue.
Posted on Mar 23, 2009
  • 3 Answers
SOURCE: Fatal Application Error/Mobile Navigator.exe
0xC0000005 0016A9D8
Posted on Aug 02, 2009
I recently did a factory reset on my gps 84h-3 and now my navigation will not open but the rest of the icons open just find
On the main sreen you have an app that looks like two arrows one pointing right the other left. Clich/tap on this icon then tap select \SDMMC\ destinator exe. This will get you back on track. All of your previous maps will be available if you saved them.
Aug 08, 2013 | GPS
My Evesham nav-cam 7000 model ps1025 is showing
My Evesham nav-cam 7000 model ps1025 is showing the following:-fatal application error Application Mobile Navigator.exe has performed an illegal operation and will shut down.If the problem persists contact the program vendor.Program 0xc0000005 Address 000d026c.What can i do to remedy and get a cd disc for it?
Oct 12, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
AUDIOVOX NVX226 NOT RUNNING APPLICATIONS
the file is missing contact the nanufacture
Apr 11, 2009 | Audiovox NVX226 GPS Receiver
Createfile failed on INI file
Hi. I had the same problem, and i fixed it by creating a APShell.ini file wich was missing in MyFlashDisk\Shell directory.
In APShell file :
Version=1.0.2.43
Language=23
[Navigation]
Path1=\SDMMC\ROUTE66\R66n8.exe
Path2=\SDMMC\N8\Navigate8UI.exe
Path3=\SDMMC\ROUTE66\R66Navigate8.exe
Caption1=Navigate
Caption2=N8
Caption3=Navigate
ClassName1=
ClassName2=Explore
ClassName3=
Reset=
reset device and it should work.
Mar 30, 2009 | Route 66 MINI Handheld GPS Receiver
Nokia 500 gps. Display freezes and has a box in upper right corner. Bluetooth hands free works but navigation does not. Troubleshooting info found on Nokia Wiki says "this means the shell is started...
Mar 21, 2009 | Nokia N500 Auto Navigation
Fatal Error Application comes on when turning on the GPS
The problem i,m having is All the routes i have taken have Now a Permanent Orange Heavy Line and i can not identify any Roads on my Navigation 4000
Feb 03, 2009 | GPS
I have an A2265FF all in one navigation unit in my ford focus, the SD card had route 66 installed on the card which I updated and since then I have lost the files for loading the navigation, I have...
I can understand your problem, this problem arises with new SD card.
So, please copy Navione folder to memory card root directory, enter the directory, use Notepad to open Loader.ini to edit, enter your correct path, for example: \ Storage Card \ NaviOne \ NaviOne.exe save you, run to enter Loader.exe navigation procedures.
I'm sure it will work out for you. The error message shows similar indication. So, do it and load your route installed. It will work out surely.
With Regards,
Shyny
Apr 22, 2009 | GPS
GPS Logo
93 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
