Question about Chevrolet Vehicle Parts & Accessories
Steering column replacement for 1974 cheyenne
    President:
  • Chevrolet Master
  • 2,620 Answers
Www,Imctruck.com
Posted on May 17, 2011
How to replace steering wheel position sensor on a 2006 Cadillac DTS?
Manual Steering Column with JL4) or
Steering Wheel Position Sensor Replacement (Power Steering Column with JL4) ?
Preliminary Procedure Remove the intermediate steering shaft. Refer to Intermediate Steering Shaft Replacement .
Steering Angle Sensor Adapter
Procedure Disconnect any electrical connectors as needed.
Tip
If reusing, secure the old steering wheel position sensor before removing it for proper alignment upon reinstallation. Refer to Steering Wheel Position Sensor Centering .
Callout
Component Name
Notice: Secure the steering wheel utilizing a strap to prevent rotation. Locking of the steering column will prevent damage and a possible malfunction of the SIR system. The steering wheel must be secured in position before disconnecting the following components:
The steering column
The intermediate shaft
The steering gear
After disconnecting these components, do not move the front tires and wheels. Failure to follow these procedures may cause improper alignment of some components during installation and result in possible damage to the SIR coil.
Preliminary Procedure Remove the steering column. Refer to Steering Column Replacement .
Intermediate Steering Shaft Bolt
Procedure Remove the steering column boot seal in order to access the intermediate steering shaft bolt.
Intermediate Steering Shaft Nut
Notice: Refer to Fastener Notice in the Preface section.
Tighten
47 N?·m (35 lb ft)
Tip
If necessary, scribe location marks between the intermediate steering shaft and the steering column and the intermediate steering shaft and the steering gear to mark their alignment before removing.
If replacing the intermediate steering shaft, transfer any scribe marks from the old one to the new one.
Callout
Component Name
The steering column
The steering gear
Preliminary Procedures
  1. Remove the left side instrument panel insulator panel. Refer to Instrument Panel Insulator Panel Replacement - Left Side .
  2. Remove the driver knee bolster. Refer to Driver Knee Bolster Replacement .
  3. Disconnect the intermediate steering shaft from the steering gear. Refer to Steering Gear Replacement .
Steering Column Nut (Qty: 4)
Notice: Refer to Title not found in the Preface section.
Tighten
25 N?·m (18 lb ft)
Steering Column
Procedure
  • Disconnect any electrical connectors as needed.
  • If equipped with AN3, disconnect the automatic transmission range selector cable. Refer to Automatic Transmission Range Selector Cable Replacement - Column .
  • Transfer any parts as needed.
  • Sep 12, 2015 | Cadillac Cars & Trucks
    How do I replace the ignition switch on my 74 MGB
    After removing the column covers, (screws in holes underneath) The 2 unslotted studs holding the ignition and steering lock assembly onto the column are anti-theft screws. They will turn by hitting them on the edges with a hammer and small sharp chisel - counter clockwise.
    Feb 12, 2014 | OE Aftermarket 1963 - 1974 MG MGB...
    On a 1974 chevy cheyenne truck the ignition will turn all lights on and then will not ignite the starter .i replaced starter and still does nothing
    When you replaced the starter did you also put a new solenoid on it?
    I would suspect the fusible links. There are 2 down on the wire harness going to the starter. They are a round piece of black rubber, maybe 1/2 inch long on a wire close to the solenoid. You should see 2 of them. You can either replace them, with a wire 2 sizes smaller, or just cut them out and splice the wires together.
    Sep 29, 2013 | 1995-1997 Chevy Suburban Ignition Starter...
    I cannot get the plastic around the steering column off a 1985 jetta to replace the ignition. can you help with answers to remove this and the lock assy
    1. Remove the steering wheel, then remove the steering column covers.
    2. Remove the turn signal and wiper switches.
    3. Disconnect the ignition switch wiring.
    4. On some models, the hole in the lock body for removing the ignition lock cylinder was not drilled by Volkswagen. To make the hole, use the following measurements in conjunction with the illustrations. Drill the hole where "a" and "b" intersect on the lock body. The hole should be drilled 0.19 in. (3mm) deep.
      1974-77 Dasher-a= 0.45 in. (11.5mm) b= 0.32 in. (8mm) 1975-76 Rabbit, Scirocco-a= 0.43 in. (11mm) b=0.43 in. (11 mm) 1977-89 Rabbit, Jetta, Scirocco and 1978 and later Dasher, Quantum and Fox-a= 0.47 in. (12mm) b= 0.39 in. (10mm)
    Fig. Fig. 1: Lock cylinder drill point on 1974-77 Dasher
    Fig. Fig. 2: Lock cylinder drill point on other models
    1. Remove the lock cylinder by pushing a small drill bit or piece of wire into the hole and pulling the cylinder out. It might be easier to insert the ignition key, turn it to the right a little and pull on it.
    To install:
    1. Insert the lock cylinder into the housing with the key in the cylinder.
    2. While gently turning the key side-to-side, press the cylinder in to the stop. It should click into place.
    3. Temporarily fit the steering wheel onto the splines, then make sure the column locks and unlocks smoothly.
    4. Install the switches, column covers, wiring and the steering wheel.
    5. Connect the battery cable.
    Let me know if you need anything else
    May 04, 2011 | Volkswagen Jetta Cars & Trucks
    I just purchased a 1989 chevy cheyenne but was told the turn signal does not work. I was told it was a switch in the steering column...Is that fairly easy to get to and fix?
    To perform this repair you need to remove the steering wheel. there will then bee two or three screws holding the mechanism in place. down towards the bottom of your steering column you will find the wiring that you needs to disconnect. Pull the wiring up and out and install the new signal switch in reverse order.
    Jan 24, 2011 | Chevrolet Chevy Cars & Trucks
    Cant get key switch out of housing, on a 1974 chevy pick up.Trere are no screws or clips visible.
    If you mean remove the ignition tumbler from the steering column, you will have to remove the steering wheel and lock plate, then you will need to remove the turn signal lever and screws, and then pull the turn signal switch up and out of the way, you should then be able to see the housing for the ignition tumbler down in the steering column. Look at the tumbler housing and there should be a small slot towards the end of the housing that you can put a small standard screwdriver into and depress a locking latch that is built into the tumbler. When this latch is depressed you will be able to pull the ignition tumbler straight out of the column.
    Apr 19, 2010 | 1986 Chevrolet Chevy
    Need instructions on how to change ignition switch on the steering coloumn of a 1974 chevy truck
    how do i change the lock ignition on a 1986 chevy truck. got the lock ring off but the steering wheel will not come off
    Jul 13, 2009 | 1986 Chevrolet Chevy
    Vehicle Parts & Accessories Logo
    Top Chevrolet Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Mike
    Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
