Question about Craftsman 8.50 Torque Rating Rear Tine Tiller
I had a problem with my tiller going into reverse tilling. It goes into froward & reverse without tilling OK. But I have to be very careful when engaging the tines, mostly reverse tilling. It sometimes locks up & the belt will not turn but the drive gear does, causing the belt to smoke heavily. Sometimes when you put the bar back to start tilling it seems to lock up & causes engine to shut off. Other times it works great. Have to be real careful when depressing engaging bar as it can feel tight & I know it is not going to work. Move lever a little & it will work. Is it in the gear box & if so I do I check it?
  • 1 more comment
  • steh May 25, 2011
    Sorry for just getting back with you. Had to go out of town and just got back last night. Anyway, here is the info you asked for.
    Craftsman 7.0hp/19"
    Model # 917.293490
    SN 030101T005964
    Hope this helps and I look forward to your response.
  • steh May 29, 2011
    Sorry for just getting back with you. Had to go out of town and just got back last night. Anyway, here is the info you asked for. Craftsman 7.0hp/19" Model # 917.293490 SN 030101T005964 Hope this helps and I look forward to your response.
  • steh Jun 03, 2011
    I have responded twice with the info you requested and have not gotten a reply back from you. Do I need to get another expect to get an answer?
  • 2,926 Answers
Was is the model number of this tiller?
Posted on May 18, 2011
I want to sew reverse for a few stitches to do a miter corner. how do I reverse stitching.
Usually there's a button in the center of the stitch dial you can push in to reverse it. Hold in to reverse, let go to keep going froward.
Mar 12, 2015 | Sewing Machines
The Tinds will not engage and I have problem getting the tiller in forward/reverse gear.
you need grease on your power shaft that has the forward/reverse this is where the power goes to the wheels slids back and forth A round wheel one side forward the other side reverse
Mar 24, 2011 | Yard Machines Tiller 208cc 18in Tilling...
Dynamark model 53455100 runs fine, but won't till in forward (tills ok in reverse) Can you help
This machine runs reverse off of a different shaft (camshaft)
The problem is in the belt/pulley set up off of the crankshaft.
See if you don't have a bad belt or pulley. Make sure the belt is being tightened all the way.
Joe
Feb 12, 2011 | Garden
Drive Engages Hard From New To The Point The Arm Is Bending And Can't Get It Up High Enough To Engage It Into Reverse. It Also Pulles Hard The Cord Will Bind To The Point That It WillTip The Machine. If I...
just for get reverse when you have a problem the first thing i do when i buy a tiller is do away with reverse gear it will make you hurt yourself just go to the end of garden turn around and start over again
Jun 27, 2010 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
Craftsman rear tine tiller will only go forward. The shift lever will not move to either the ''Till'' position or the ''Reverse'' position
Pretty common failure for all brands unfortunately. The transmission will have to opened up to determine the cause and it is not cheap to have done. Sorry
Apr 27, 2010 | Garden
When going forward the tines are going in reverse
I've never seen one of these so excuse my ignorance. Is it possible that the cable to change from forward to reverse is out of adjustment? Can you go to where the cable attaches to the shifting mechanism, detach it and manually try to change from reverse to forward? Hope this helps. Good luck!
Mar 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Tiller will go into every gear except forward/till..whats going on?
check the shift lever where it goes into the transmission. a lot of times, the lever will get sloppy where the roll pin goes through and it won't shift into till. sometimes you can drive the roll pin out, pull off the lever and peen the holes over. sometimes you have to drill the lever and shaft and put in a snug fitting bolt and nut. OR, the chain driving the tines is broken, and that means a new transmission. hope it's simple
Jul 19, 2009 | Craftsman 8.50 Torque Rating Dual...
I just bought a used Pony tiller. It runs good, but after tilling for a couple no hours the forward and tines just stopped. Had not hit anything. It goes in reverse and the tines work in reverse, but I...
Check under the metal or plastic cover just behind the engine. This covers the forward and reverse belts. Your belt either broke, jumped off fthe pulley, or needs a tension adjustment.
Frank
Jul 04, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Craftsman 8.50 Torque Rating  Rear Tine Tiller Logo
291 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
