Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
I HAVE A BISSELL PROHEAT 2X HEALTY HOME, IT WORKED JUST FINE THE LAST TIME I PUT IT UP. YESTERDAY, I NOTICED THE FLOW GAUGE WAS NOT SPINNING, SO I CHECKED AND SURE ENOUGH NO WATER WAS COME OUT. I CHECKED AND ALL THE TUBS AND EVERYTHING ARE IN THE RIGHT PLACE AND HAVE LIQUID IN THEM. HAVE TRIED PRIMING CLEANING THE BRUSHES RUNNING HOT WATER THROUGH IT... HELP
  • 276 Answers
Have you made sure that the tanks are seated properly and the red
(or black) auto-load gaskets are in place.
Check the bottom of the Water Tank and the Formula Bottle to make
sure each has a red auto-load gasket attached and facing outwards.
You should be able to press the x-valve in the center of the auto-load
gasket so water or cleaning solution comes out.
Posted on Jun 01, 2011
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell proheat cleanshot 2x won't stop putting out cleaner and water, the little dial won't stop spinning
First clean the Flow Indicator filter. Turn the Flow indicator cap counter-clockwise to remove it. Lift the rotor and the filter under it out. Clean the filter and reinstall in reverse order. Make sure you have unplugged the unit before working on it. Then clean the lint filter on the heat tank cap (it looks like a screen) and reinstall it. There's not much more to these so if that doesn't work call the Bissell Consumer Care at 1-800-237-7691
Oct 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell proheat 2x carpet shampooer will not put out any water
Have you cleaned the filters? Check your User's Guide for directions. One is located under the Water Tank Cap (small screen) the other is under the Flow Indicator. Bissell Consumer Care 1-800-237-7691 Hope that helps.
Jun 23, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Unable to get the flow gauge to spin
The heater is plugged up or the pump bad or both. Usually the heater take it apart. Becareful of the VERY VERY small red o ring around each screw. You can take it apart and clean out all the build up from the cheap soap everyone uses. It cakes up in the heater.
Mar 13, 2014 | Bissell 66Q4 PROHEAT 2X HEALTHY HOME
Spray does not work on floor cleaning
Here's a quick link to troubleshooting steps. http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
If you continue to have difficulty, here's a link to locating one of our Authorized Service Centers.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 23, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell ProHeat 2X CleanShot Upright Deep Cleaner, 9500; flow gauge will not spin and the machine is not dispensing solution with both the solution and water tank full. I have cleaned all inlets where...
No what it means are the tubes that carry the solutions are plugged and most likely full of old detergent that hardened. You will need to clean all the plastic tubing out for the dispensers. When your done using the machine always run clean water only through the dispenser and tube to flush out the detergents.
Jun 10, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat 1699-5 won't spray, belt ok
Hi There,
It sounds like to me that this may be your pump. The newer ProHeat 2X models actually have a Silinoid problem right now which is more common then the pump going bad, but if you have the original ProHeat series, then it sounds lik you have a bad pump.
Here's a link to a very, very helpful repair guide directly from Bissell that will explain to you step by step how to trouble shoot, and replace the pump if needed. I would be lost on the ProHeat series without this handy repair guide.
I'm pretty knowledgable now on these machines, if you need some help or some clarification on how to repair this, please feel free to reply to this repair by using the Clarification request form. If you found this helpful, please be so kind and rate my repair, and give feedback.
Here's the link:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-proheat-repair-guide.pdf
Thanks again,
Chris Jones
GoVacuum.com
Apr 19, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
My Bissell 9500 Proheat 2X has no suction.
I think you have a suction problem, as everyone else seems to have! Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use). There is a little red plastic piece about 1 inch square on the under side of it. Flip open the little door on it and you will probably find that it is blocked with hair, carpet fibre, etc.. Clean it out and your problem will hopefully be solved!
Aug 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
311 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
