Question about Cycling
What makes the oil milky in a ktm 85sx 2004 - Cycling
  • 40 Answers
I presume you mean the gearbox oil and that the oil is white? If so then coolant water is leaking into the gearbox possibly through the water pump.
Alex
Posted on May 17, 2011
How much oil do you put in the front forks of a 2004 ktm sx 250
A good rule of thumb on anything that has a plug that removes to pour oil in, which I am assuming this one does, get it level and pour oil into it until it just starts to run out of the hole,. Again make sure it is setting level.
Gillight
Jun 22, 2012 | 2004 KTM SX 250
KTM 105 SX spark plug fails every ride???
Hi, Sagi nice novella and the usual suspects are:
1. Fuel mixture too rich or enrichner left out too long.
2. Faulty spark plug.
3. Incorrect spark plug for the engine type or service.
4. Piston rings badly worn or broken.
5. Valve guides are badly worn and/or seals worn, crushed or have come off the valve guide and are pumping oil through it.
6. Spark plug cable weak or leaking check for spark jump in the dark.
7. Faulty ignition coil.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.ktmforums.com/forums/two-strokes/1966-solution-fouling-spark-plugs.html
Why Does My Dirt Bike Keep Fouling Spark Plugs
KTM 85sx 105sx service manual repair 2004 2009 85 sx 105 sx Download... $8 cheap
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 85 105 SX Owner Manual
Mar 11, 2017 | 2007 KTM SX 105
I have a 2004 ktm 950 adventure with 26,000 miles. Replaced the two head gaskets about 400 miles ago because it was building pressure in the coolant system and filling up reservoir then blowing it out the...
Hi, Rhodgin first thing I would do is check for coolant in the oil and oil in the coolant then I would bleed both systems for uninvited air for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
KTM 950 990 LC8 water pump and low oil pressure issue What up KTM
ADV 950 losing coolant Horizons Unlimited The HUBB
KTM 2003 950 Adventure Repair Manual
KTM 950 ADVENTURE 2003 Owner Manual
Mar 25, 2017 | 2004 KTM 950 Adventure
My sons 85sx front shocks are leaking oil.can they be fixed?
yes the shokers can be repaired at any agency.cost:upto 200-300rs
Jun 09, 2011 | KTM JL QT504 Motorcycles
Hi My 2000 LC4 Supermoto has water in the oil I have all parts to Replace Head Gasket and Seals.( Thanks to AMS KTM) What I would like to Know is how to flush out the Oil System of the creamy oil before...
drain the milky oil out and buy the thinnest oil you can find. fill the engine to the top with the thin oil (dont start it up) then drain it out straight away do that once or twice then put in the proper oil and it should be ok
Aug 23, 2010 | 2000 KTM 640 LC4
Would too much oil in case make oil leak on 2004
All engines have a oil level .if too much oil is put in an engine ,above the recomended level then pressure produced when the engine is running will force ouil into places its not meant to go .This will cause oil leaks in any number of places and could cause damage to seals or correct running of the engine .
Mar 12, 2010 | 2004 KTM 625 SMC
How do i check the tranny oil level on my ktm sx 125
I would think the it is all one unit, motor oil lubricates that as well.
Sep 05, 2009 | 2004 KTM SX 125
1998 f-150 oil issues
that milky substance is just the result of not changing the oil enough, it is water and oil mixed. the water is just condensation that ends up at the highest point, the oil cap. clean it off and it should be fine. make sure that the oil is at the correct level.
Dec 11, 2008 | 2004 Ford F150
Cycling Logo
101 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
