Need help finding a shroud for Polaris AVC "A" series air cond
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 190 Answers
Is this what you're looking for? Link
If I misunderstood your question please let me know.
Regards,
DIYpro
Posted on May 17, 2011
I would like to know details of AVC BAKA9318B4H Blower. especially, maximum air volume...
AVC BAKA9318B4H Blower Fan, DC24V 0.45A, Ball Bearing, 2-Wire
I can't find any details for that exact model except those above, but on this
http://www.avc.com.tw/fan_search.asp?select1=DC-Blower&select3=&select2=&select4=&select5=&select6=&button=search
webpage from the AVC website, there is a spec for a fan very similar to that you list BAKA9318-24H This is a 93mm diameter 18mm thick blower operating at 24V, like the one you refer to. The H signifies that is the highest airflow model of that type . Your fan also has this designation. I suspect that AVC spec is actually a more general one that includes other bearing types (-24H), while the -B4H indicates that it is specifically a ball bearing blower. The max air flow is 18.3 cu ft per min at zero back pressure and the pressure developed at zero airflow is equivalent to 35.3 mm of water (1 atm is equivalent to about 10m = 10,000,000 mm of water). There is noise figure quoted as well.
24.December.2014
Dec 23, 2014 | AVC BAKA9318B4H Blower
COLEMAN SHROUD REPLACEMENT 7000 SERIES
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Apr 15, 2013 | Coleman Air Conditioner Shroud Rv Roof Top...
Need a replacement r v air conditioner shroud polaris by dometic 28inches wide 41 7/8 inches long & 9 1/2 inches high
Can you get model number of bottom of upper unit, from inside the trailer? The roof unit model number will make it easier to find replacement shroud.
Sep 27, 2012 | Dometic Rooftop RV Air Conditioner
Hello, how do I clean the front cond,when I remove the shroud can't even see the front one but can see the back one.
I either do it with a shop vac with a ladder and long extensions on vacuum and a soft brush attachment from inside (and flashlight to see good) or remove all short philips screws on metal cover above evaporator and remove cover to access easier.
Aug 22, 2011 | Coleman Mach III Air Conditioner
Have a window unit here in Afghanistan. The compressor kicks off and on. I have cleaned the evap & cond. Is there anyway to bypass the hi pressure switch? Its a Wirlpool ACM124PS 1. Thanks! Tim
It sounds as though the outside fan is having a problem. Has someone replaced it? Is the fan in a shroud ? . I am afraid that if you by pass the switch you may cause the unit to fail as I am not certain as to what is causing it to kick out on the HP switch. Could also be over charged? could be outside fan . I need a bit more on this..
Aug 04, 2011 | Whirlpool Heating & Cooling
Hi, thnks for your help. During the night the air cond stop and the inside unit have the function "PF"
PF stands for Power Failure- either your electric power failed completely during the night, or just dropped too low for the unit.
You will probably need to reprogram the setting on your thermostat, and set the clock (if it has scheduling capability).
If you need a manual/instructions, see if you can find a model name/number on the display unit.
Jul 16, 2011 | Heating & Cooling
How do I clean air conditioner fan on Kenmore 5600 btu room air conditioner
You first need to pull it out of the window
Then, take off the case which will require removing several screws and the "wings" that make it fit in the window.
Set it on the concrete or a sturdy outdoor table
The rear and front coils will be the most important things to clean. Water is the best way to clean, but it you use a hose and sprayer, you have to be careful not to get the electrical components wet.
You can also use a good vacuum cleaner if you have one that has a wand.
The rear coil can be loosed from the fan shroud by just a few screws and set back to where you can get to the rear of the coil. It will be stopped up with dirt,etc. Take the vacuum or water sprayer and clean rear coil thoroughly. The front coil can be cleaned from the front. A wire brush would help you out greatly. Be sure to clean out the bottom pan of the air cond also, so that the unit will be free to drain properly. Be sure, if you loose the rear coil from the fan shroud not to bend the tubing coming from the coil. Also if you are using water, let the unit dry out for an hour or so before you plug it back in.
Jun 25, 2011 | Kenmore Heating & Cooling
I have a sharp lc 30hv6u that needs the avc system
There is no way around AVC, You will need it. unfortunately, it's expensive and hard to find.
Oct 22, 2009 | Sharp Aquos LC-30HV6U 30 in. HDTV-Ready...
Eb series electric heat/air cond./repair
I need more information to help you. When you say it "turns on" what does that mean? Only the fan works? If so does the compresser run? If not, the start relay could be the problem.
Ray
Sep 14, 2008 | Dayton Electric Heater
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
