I want to know how to have a better cooling with the 1.5 ton LG intelloair window AC......what shud b the reading.....at present it reads indoor 35 and desired 18
    Genius:
  • 1,015 Answers
I would start wiyh a thourogh cleaning of the coils and blower.If you have service ports check to make sure you have the proper amount of refridgerant. If you do not have service oorts you can put some on that just clamp over the pipes and are self tapping. Hope this helps you. Thanks.
Posted on May 17, 2011
How can resolved PJ error in daikin vrv 2
PJ is an error that has to do with the outdoor unit not matching the indoor unit. This means the outdoor board thinks it's a 2 ton unit and the indoor thinks it's a 1 ton unit. (Just throwing those numbers in)...but, the indoor is not matching the outdoor. You need to read the manual and go through the setup process.
Jul 30, 2017 | Heating & Cooling
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
My window AC of 1.0 ton capacity is drawing 8.4 amperes instead of 7.0 (max,).There is no abnormal sound from any where in the AC ,Voltage is full(230-VOLTS). is this may be the case of low cmpressor oil...
Is the AC cooling properly?
If it is I would not bother it.
Your amp draw while somewhat high is not significantly high and would not worry me from a trouble-shooting angle, especially if it's cooling well.
Did you read the amp draw with the cover off the AC? If you did that would account for a slightly high reading. Even if you read it with the cover on - I would not worry about it, as I said above, it's just not that significant.
As far as 'low oil level.' -- I would not even be thinking about "oil" or whether or not it was low or whatever. This is just not an issue in such a small unit.
Jun 07, 2011 | LG Goldstar GWHD5000 wall/window Air...
Out door is not working
Check for communication from indoor to out door.Check power in out door unit. If not, check the following.
Keep cool mode and temp setting minimum 3 degree less than room temp.
Check indoor unit return air sensor. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace air sensor
Check Indoor Pipe Sensor Disconnect from PCB and measure resistance. Pipe sensor = 5kOhm at 25C. If not replace pipe sensor.
Thanks and hope helpful?
Feb 04, 2011 | LG LS-L1210CL Mini Split Air Conditioner
My weatherking outside compressor isn't big enough to handle my cooling needs. It is 1.5 ton unit, can I put a bigger ac unit onto this one without changing my heating system which is sufficient?
if your indoor unit is 1.5 ton the answer is no
if your indoor unit is 2.0 ton then you can jump to that size.
Note :your duct system may have been designed for a 1.5 ton and may need to be reconfigured for a size increase.
Your hvac contractor should know this?
Jun 14, 2010 | Weather King 10AJA4201AH Air Conditioner
My LG intelloair 1.5 ton split a/c's compressor not working.
check the compressor's start/run capacitor. if it is swelled at the top, where the connectors are, replace it.
Apr 04, 2010 | Heating & Cooling
Ice formation in the indoor unit
you need to have the unit checked for the amount of freon in the system this must be done with a gauge set the freon amount is obviously incorrect
also the a-frame evaporator must be sealed in the furnace cabinet
May 28, 2009 | LG Heat cool Window Air Conditioner
Formation of ice on evaporator element
hi! there,
eventually ice freezing evaporator occured two factor you have
dirty fin evaporator and undercharge system.
1. undercharge can easily detected using clamp
ammeter clamp on one line of evaporator while running
read the amper the compare this to yuor service
manual the rated current of the compressor.
2.if the reading current is below the rared current on
manual or there is tag on the body of unit specified
rated current.your unit need to recharge.
if has the same current no change at all freon is still
good, this only need cleaning of eveporator fin.
clean this by pressurise water to purge out all debris
particle on fin tube of evaporator.
cracking sound usally made by blwer or fan
misalignement or distorted bearing blower .
regards have anice day dont forget to rate me.
Apr 10, 2009 | LG Heating & Cooling
Non cooling
Check the indoor fins and air filter if dirty, so if its dirty cleaning is needed specially the indoor fins it should not be block with dirts6702929.jpg. But if it is clean then you need a qualified technician it may need additional gas.
Mar 09, 2008 | LG GL6000ER Air Conditioner
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
