Question about ASUS P5GZ-MX Motherboard
I have mboard P5GZ-mx. Would I able to put graphic card Gainward 950gt in my PC? If I tried to install this graph.card - there was no signal vga/dvi. Signal was on onboard vga only. Option PCI/internalVGA is in BIOS enabled. Graphic card is OK - tested in other PC. thanx
  • arsenalforev May 17, 2011
    thnx, yes, non-compatibility, it could be. But its standard PCI-E Gainward 9500GT 512MB with GPU NVIDIA GeForce® 9500GT, HDMI+VGA+DVI. How i could find info about compatibility/non-compatibility?
    I have videosignal on onboard vga only. Its possible to switch off onboard vga?
    Problem Solver:
  • 15 Answers
You said video(graphic)card is ok in other pc,may be the video card you install in asus p5gz-mx motherboard is not compatible ..
Posted on May 17, 2011
    thnx, yes, non-compatibility, it could be. But its standard PCI-E Gainward 9500GT 512MB with GPU NVIDIA GeForce® 9500GT, HDMI+VGA+DVI. How i could find info about compatibility/non-compatibility? I have videosignal on onboard vga only. Its possible to switch off onboard vga?
How to add second monitor on ECS RS482-M
Doesn't work that way Max.
You can use EITHER the OnBoard Graphics,
OR;
the Add-On Card graphics. (Graphics card)
BIOS will NOT support both at the same time.
If you wish to use dual monitors, get an AGP card that has more than one graphics port on it.
For example, although I'm using a graphics card based on the PCI Express technology, and not AGP technology; my card has a VGA port, DVI port, and HDMI port.
1) VGA Connector; http://en.wikipedia.org/wiki/VGA_Connector
http://en.wikipedia.org/wiki/File:Male_VGA_connector.jpg
2) DVI; http://en.wikipedia.org/wiki/Digital_Visual_Interface
http://en.wikipedia.org/wiki/File:Dvi-cable.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface#Connector
3) HDMI; http://en.wikipedia.org/wiki/HDMI
I use the VGA port, and the DVI port.
RCA EN-V L26HD31, (26 inch HDTV) to the VGA port.
HP 2009M 20 inch Widescreen monitor to the DVI port.
Had to install drivers for HP 2009M.
Let's say I had two DVI ports on the graphics card.
(ATI Radeon HD5450 is the graphics card I have)
But I have a monitor with a VGA cable, and a monitor with a DVI cable.
I would (And have) use a VGA to DVI Adapter.
One example,
http://www.directron.com/dvi.html
Note that the DVI is Male, and the VGA is Female.
The graphics card DVI connector is Female.
The VGA Cable connector is Male.
So.............what is the manufacturer name, and model number of the graphics card; plus what type of monitors are you trying to use?
That is, what type of monitor cables do they have?
Know this;
My HDTV I'm using as a monitor is Digital. However I'm using a VGA cable on it. Best quality would be achieved if I got off my lazy rear, and attached a DVI Cable to it. It uses both.
VGA is Analog. A computer however puts out a digital video signal.
The computer has to convert the digital video signal to an Analog one. This slows the video signal down, and the quality is not as good.
Best to use a digital monitor. (Or a digital monitor WITH a digital cable. DVI Cable. Such as I need to do)
You are also using a PCI Express graphics card, NOT an AGP graphics card.
I'm wrong? OK.
In the meantime turn the computer off, unplug from power, and yank that AGP card out of the slot you put it in.
Tell me what expansion slot on the motherboard you put it in.
The Orange expansion slot on the motherboard, is a PCI-Express x16 slot. Uses a PCI Express graphics card -> ONLY
The white expansions slots are PCI.
Can use a PCI graphics card. CANNOT use an AGP graphics card.
Post back in a Comment.
Regards,
joecoolvette
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
Feb 18, 2013 | DFI 661GX-MLV SIS661GX CHIPSET SOCKET775...
No monitor signal on my m2n-vm dvi after installing my new graphics card asus en210.The graphics card was tested on my other pc and works fine..any help?
First boot the computer without connecting Graphic Card, then go to BIOS and find for VGA option change the option to compatible mood, save the setting and come out of it. now off the computer re connect your graphic card and start the computer.
Aug 15, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Monitor does not connect with computer . dvi no signal
Could be a bad monitor and if not, then the graphics card if it has one, if not the motherboard connection. Try it with another monitor to rule out the monitor, then if you ave a graphics card, remove it and reseat it.
Jul 24, 2012 | ASUS P5GC-MX/1333 Motherboard
I cant get display in my asus p5gz-mx motherboard . monitor is ok. pc is on but no display.........
If you are using a flat screen monitor with multiple inputs be sure that the monitor setup is selected to VGA. If that is okay try repeatedly hitting the keyboard key for entry to the BIOS Setup when you reboot. If nothing appears try installing a video card. Check your motherboard over carefully to see if anything is loose or not installed properly like the memory or any added cards. Did the processor come installed or did you install it? Is it a supported dual core Intel processor? Do you get any beeps when you boot up?
Sep 18, 2011 | ASUS P5GZ-MX Motherboard
This board grahpic card/diplay adapter is 1gb or 256 ??? plz detail i want to install windows mac iuse board built in vga or extra pci vga ....
your graphics socket slot is PCIE DDR2. you can use graphics card up to 1024gb.
your biult-in vga is Intel graphics 256MB
Feb 06, 2011 | ASUS P5GZ-MX Motherboard
I don't have graphic driver for motherboard P5GZ-MX
Hello ccccc0000nnn!
Asus has the graphic driver for your P5GZ-MX motherboard available for download on their website. The link for your motherboard is P5GZ-MX
Just pick your operating system from the pull down menu and then scroll down to VGA and click the "+" sign.
Nov 22, 2010 | ASUS P5GZ-MX Motherboard
Does this motherboard supports nvidia 8400GS 512MB graphic card or not?
Yes it is.
Nvidia 8400GS 512MB is PCI-E Card Ready for and 100% Compatible with this Motherboard.
Aug 25, 2009 | ASUS P5GZ-MX Motherboard
My computer won't detect ATI RADEON SAPPHIRE X1550 256MB
go to bios and enable it to detect graphics cards most bios have an option for onboard only or onboard and external graphics adapters
May 04, 2009 | Sapphire ATI RADEON X1600Pro 512MB...
NO signal using DVI-D
A. There are two types of cable; DVI "I" and DVI "D". Make sure you are using the correct one B. Update your following drivers: 1.VGA card driver 27.00 or later version 2.WDM driver(capture driver) 1.11 or later version 3.Expertool program (overclocking program) 2.81 or later version
Nov 12, 2005 | Gainward 128 MB GF FX5200 VGFX5200T...
ASUS P5GZ-MX Motherboard Logo
174 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
