Question about Linksys Wireless-G WRT54G Router
I have configured my router but am failing to ping it remotelyWRT54GS r
  • 20 Answers
Please check the ip address of your network.you can use class c.ip address which is 192.168.0.1 then try to ping using the command ping 192.168.0.1 -t
Posted on May 18, 2011
I am unable to browse iternet, it showing massage that cannot connect for an unknown reasons please check your internet setting and change them if needed . currently i am using htc touch diamond (cdma)
There could be many reasons for your problem.
1. If you use proxy server, make sure the server and the service are up and running
2. If you use proxy server check the Internet options and look for the correct values in the required fields.
3. If you use wireless router check the connection to the router.
4. If you use router check the network configurations. Many of the routers have internet connection test. So login localy to the router interface and check the connection.
5. If everything above is correct try pinging a website from cmd. Open command prompt Start->Run->cmd. Write the command "ping www.google.com" (without the quotes). If you have ping look for application that blocks the http traffic on port 80. If the result is "Request timed out" try to ping 209.85.148.104. If you cannot ping any site or computer outside your network, then you have to call your provider.
Mar 01, 2011 | Computers & Internet
I purchase a netgear universal wireless internet adapter to connect on my samsung tv to get the internet , netflik etc.....i was not able to pass the test with the gateway ping which failed. the model...
I have a couple of questions
1. What gateway are you pinging?
2. From what device are you sending the ping?
If you are trying to ping the gateway on the modem/router provided by your internet service provider then you will not get a ping response, this is because it's configured not to respond.
Oct 06, 2017 | Computers & Internet
WiFi on tx2620es do not connect to Router
false
WEP, WPA and WPA2.
all 3 are encrypted, wpa2 is best.
you never once said the magic words "connected"
nor what window,s XP? must we GUESS OS?
IG GUESS, COMMAND LINE IPCONFIG /ALL
FAILS, / NO IP ASSIGNED?
WELL THAT MEANS DHCP FAILED, OR NOR CONNECTED.
i see you doing things impossible, like PING
WITH NO ASSIGNED IP;.
the tx2620es must connected,to work
if it is connected,id remove the drivers, for the NICwifi
and load them freshoff HP.com
that will work
everytime
if not virus infected.
see the words connected, well some times it can lie.
obviously its in the tx2620es
id use CP + device manager
and blow the wifi stack away and get new drivers off hp.com
then find your SSID and connect, using the correct Pw
Mar 01, 2017 | HP Pavilion Tablet Notebook
After configuring network TCP/IP automatic Dns server automatic or preferred and alternate dns as given by isp, setting router to mode router encaps..pppoa (second trial RFC1483) multiplex..llc virtual...
ftp://ftp.zyxel.com/
this the web site download the user manual from this site what ur configuration go thought it i think you get it and maybe the problem in the pppoa line its working or not just check it
Apr 02, 2009 | Zyxel Prestige 660HW Wireless Router...
BT ADSL prob: ATM OAM F5 segment ping - OAM F4 FAIL
are you using the router through a BT line? if you are BT will be able to sort this problem for you by sending the router an update that it sounds like it needs
hope this helps
Nov 20, 2008 | Computers & Internet
Configuration Utility
Can you ping the router? I mean open a dos shell, type ping -tf 192.168.1.254 - what are the results? Maybe the ping fails, because you need to have your pc set to the same subnet address, to access the router on that IP. Test ping to your own gateway address first.. That will work & show you what to expect from a working ping. You get the gateway address by opening a dos shell & typing ipconfig /all - that shows the current IP address plus the gateway address. Actually, the gatway address might be the same as the router config address, unless you have a NAT function turned on.. Anyway, if you change your IP address to 192.168.1.252 - For example, you will no longer be able to access the internet, but shud be able to enter the configuration web page of the router.. Try the router default settings first. Another thing is that some routers require a direct cable called a 'crossover' cable to connect to the router or you have to go via a hub or a switch, with standard ethernet cables.. This probably looks confusing, but if it does not help, pls post your questions here.. Rgds,
Jun 24, 2008 | MSI RG54G2 Router (MS-6848-002)
Pings-no-pongs
well, try to check if you configure your xbox360 properly, if it is correctly configure, well better check the cable which you used to connect your xbox360 and your router.
Mar 12, 2008 | Computers & Internet
ICMP blocked automatically
return, cut this configuration, but put route the her isp´s.
You can ping after this?
Can´t ping you has other problem.
Feb 18, 2008 | Computers & Internet
Routing configuration
Contact an ISP for an IP address.
configure the computers in the 2 networks to have the IP address you got from your ISP as the default gateway..
Cheers
Jan 09, 2008 | D-Link DI 514 Wireless Router (DI-514)
Linksys Wireless-G WRT54G Router Logo
27 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
