Question about Epson Stylus Photo R220 InkJet Printer
Blinking red lights
Epson Stylus photo R220 suddenly shows blinking red lights
I have a canon s630 and the yellow light blinks 7 times and green once, what is causing this and can i reset this printer?
Posted on Dec 15, 2008
SOURCE:
My epson stylus R230m printer is blinking the two red light what will i do
If blink is alternative, jast download service tool for epson e 230 and follow the given instruction that are inside the file web address:tricks-collections.com/resetter-epson-stylus-photo-r220-and-r230/
if blink same time: it,s a fatal error. it could be something wrong with the carrage or board or encoder belt
Thank you.
Feb 28, 2011 | Epson STYLUS R230 InkJet Photo Printer
Two red lights are blinking simultaneously...I check if there is any paper jam but i don't see anything. anyone can help me would be much appreciated.
first have you checked any clogged papers? have you checked ink cartridges if yes continue doing the following
Before run adjustment program or software resetter Epson Stylus Photo R220 and R230, set date setting in your computer to 12 January 2006. Appearance of adjustment program Epson stylus photo R220 and R230 like adjustment program for Epson C45. Your Epson Stylus Photo R220 and R230 must be installed correctly in your computer before using the software otherwise so this software resetter will not be used.
Here how to use the software
  • Download and extract downloaded software and run it.
  • Click accept button.
  • Set model name, port selection and destination setting and equal to your printer.
  • Click Maintenance Tab.
  • Check mark waste ink pad counter.
  • And the clear the protection counter (reset counter to zero)
  • Then click Ok, Ok
  • done
download link:
http://www.mediafire.com/?9njmgwlxqgj
Nov 10, 2009 | Epson STYLUS R230 InkJet Photo Printer
2 red lights blinking
Please see this solution I posted up earlier on another R230 query
Oct 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
What should I do, my Epson stylus R230 is not printing and the 2 red lights are blinking? What button on the SSC utility service should i click on?
Run SSC. Menu Configuration. Select installed printer. Select printer mode to Epson R220/230. Close dialog box by clicking cross sign at top right of dialog box. Icon will show at bottom right of dekstop. Right click, select protection counter. Show current value for checking waste ink counter. Click Reset protection counter. Turn off printer. Turn on again. Usually SSC doesn't work at Vista.
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Sep 24, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson r220 print head goes left and then makes a grinding sound
Your printer needs a service reset. Epson printers will only accept x number of cartridge changes / print head cleans. Basically it's telling you that the waste ink pad is saturated. It will cost about £30.00 from a local service centre
May 30, 2009 | Epson Stylus Photo R220 InkJet Printer
Both red light keep blinking
You need to reset waste ink counter. Use SSC Utility or R220/R230 Adjusment program. Find the software at indoreset.blogspot.com.
May 27, 2009 | Generic Memory EPSON STYLUS PHOTO R220 w/...
Printer says "ink is out" when I try to print but it's not
this mean your printer waste pad maybe full and the printer needss to be reset download the ssc and it will reset it for you
Mar 03, 2009 | Epson Stylus Photo R220 InkJet Printer
Red light on printer blinks continuously
http://inkjetprinterhelp.us/epsonSSC.html
photo r220
this site will reset your protection counter on the overflow ink well for excess ink during head cleaning.
its called the ssc service ultility.
it really works, i reset mine on 6-18-2008.
main website
http://inkjetprinterhelp.us/epson.html
good luck!
Feb 27, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus photo heeds reset on mac
Hi, this means your printer needs a maintenance service from epson, ie the printer has met its end of life unless you want to pay epson £75+vat for the maintenance call.
Happy New Year
John
Dec 30, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
591 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
