Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain and spin. unplugged and tried to restart to no avail.
  • Whirlpool Master
  • 3,051 Answers
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
Posted on May 17, 2011
MY DUET SPORTS DOES NOT DRAIN.
your pump is probably plugged or the impeller on the pump motor is not turning properly and jamming.
Sep 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stuck Mid-Cycle, Wet Clothes!!
unplug the machine for 15 minutes then try again
Jun 09, 2009 | Whirlpool GHW9150 Duet Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine previously off balance, I pressed cancel button
THERES A LOCK/UNLOCK TO THE FAR RIGHT OF THE PANEL..HOLD IT DOWN FOR 3 SECONDS - MY KIDS DID IT TOO
Feb 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet
try hitting pause cancel twice if that doesnt work turn the dial around all the way to off try to unplug the washer if all that fails the remove the three torx screws remove the lower panel and reach up where the latch is after unpluging the washer on the bottom of the latch is a tear shaped tab pull it down till it clicks that will unlock the door
Mar 30, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet won't run
The trouble could be with the door interlock. When the clothes were jammed in the door it could have caused the door latch to put strain on the interlock.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
574 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
