Question about Ricoh Caplio R1V Digital Camera
Caplio R1v does not start any more. Lens is not moving after I removed depleted batteries. Lens came out, but after replacing fully loaded batteries screen does not show anything, lens is not moving. The only thing I see happening is flashing of the green AF/fl LED when switching on or off. It seems there is a software problem? Connecting a USB cable flashes green AF/fl LED.
Have you tried to take photos & then use the USB cable to download those trial photos? or take test photos and then swap your SD card into another SD card camera?
The rear screen has all its electrics passing through a flat ribbon connector, as this is the only link to the main body of the camera. This ribbon folds over itself at 45 degrees within the case when the camera is assembled.
This fold is OK until the camera is compressed accidently, when that fold in the ribbon may become a crease, and then one or more of the connections within the ribbon may fail at the crease, and while camera works otherwise, you have then lost function of the rear screen.
Take some test photos & if they download OK, I'd suspect this ribbon connector is the problem. Camera Good, Screen not working.
I currently have this problem with my R1v & have yet to see if a replacement ribbon connector is available from a Repair facility, so my help may only give you insight, without end-solution.
Posted on Jun 21, 2011
My lens isis stuck and will not retract
Camera requires servicing, which may not be financially viable. If this is the case, replace the camera.
Jul 15, 2016 | Ricoh Caplio R7 Digital Camera
Wont shut down or start up zoom lense gets stuck open
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 22, 2011 | Ricoh Caplio R6 Digital Camera
Video on camera only records for 26 seconds?
For extended videos, you need a class 6 or better card.
Jul 05, 2010 | Ricoh Caplio R1V Digital Camera
Error 00-00-00 30-00-28
The error code will be due to bad batteries. Insert new batteries fully charged the camera will instantly try to zoom in or zoom out to adjust focus. If this does not happen then there is a problem with the Lens Assembly.
Lens has been forced due to an accident or too much sand or dirt is clogging it up.
You need to re-calibrate the focus.
Hope this helps.
Jan 26, 2010 | Ricoh Caplio G4 Digital Camera
I lost my manual for an Caplio R1v? Can you send
http://www.ricoh.com/r_dc/caplio/r1v/support/manual.html
Nov 18, 2009 | Ricoh Caplio R1V Digital Camera
Ricoh caplio r7
If light is the problem shot off the flash mode on your camera menu. Also try to change the angle from which you take the picture this help a lot.
Artgirl
Jul 08, 2008 | Ricoh Caplio R1V Digital Camera
Ricoh camera malfunction
The problem eventually fixed itself somehow.
Mar 17, 2008 | Ricoh Cameras
Caplio r1v camera not uploading onto computer
I am not able to upload my photos from camera to computer. Help me out. Its very urgent.
Feb 10, 2008 | Ricoh Caplio R1V Digital Camera
CAPLIO 1V WILL NOT MOUNT
http://www.ricoh.com/r_dc/download/sw/mac/caplio/index.html maybe that helps you greetings
Oct 01, 2007 | Ricoh Caplio R1V Digital Camera
Ricoh Caplio R4 Lens
This is an easy fix for a camera shop. Just tell them that your lens is off track, and needs to be aligned. It should cost less than $50.00. If you are really good with electronics, you can attempt it yourself. Just let me know if you need the schematic to the camera. Best regards, Bill
May 20, 2006 | Ricoh Caplio R4 Digital Camera
Ricoh Caplio R1V Digital Camera Logo
56 people viewed this question
Top Ricoh Cameras Experts
Fred Block
Fred Block
Greg Cann
Greg Cann
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
