Question about Diesel 3 Hand Brown Digital Quartz Display DZ4038 Watch for Men
How can i set the time for the Digital Quartz Display DZ4038
How do I set the time on my pasnew watch
Dealextreme - PASNEW Sport Waterproof Quartz Analog ...
? 6:32
https://www.youtube.com/watch?v=7D6i4d-1NYQ
Oct 25, 2011 - Uploaded by TheTemplegeek
... PU watchband - Dual time display: analog and digital - Features timer, ... PASNEW Sport Waterproof Quartz ...
How to set watch model WR30M - YouTube
? 3:02
https://www.youtube.com/watch?v=VGRAb0aF2lQ
Apr 29, 2015 - Uploaded by TheUltimate
11:24. How to Set a Timex Ironman Triathlon Watch - Duration: 1:15. by Inside Endurance Sports 2,441 views ...
how to set time in digital watch - YouTube
Dec 15, 2015 | Watches
Ferrari World Time watch setting, manual is awful and useless
You have to hold down B to set up T1 which is the time the hands will display. Once you see the City and T1 show up on the digital display you can go through the various settings to set time/date etc. Use B to cycle through setup and A to make the necessary changes.
Pushing the crown allows you to set up T2 or the time displayed on the digital section. You set this by choosing the time zone.
Hope this helps
Jan 05, 2015 | Ferrari FE-05-IPB-FC World Time Mens...
I just replaced the battery and now it won't let me set the watch, how do I do that?
mcdevito75 here, If you replaced the battery yourself you may have moved the quatrz movement and mis-aligned the buttons the thier contact spot on the quartz movement. You"ll have to open the back nd check by pushing gently on each button 1 at a time to make sure each button is makeing contact at the right spot on the quartz movement, also even if the battery is new it can still be weak or dead as they have a shelf life, also you may need the exact battery number Casio recommends, a small watch repair shop in your area can advise. The 2 buttons you need to set your watch are MODE and SET. --------- Press and maybe hold in the MODE button, 2--3 seconds, MODE button usually on the right side of watch caseing, see the display flashing, now press set to set each function, (hour, minute etc.) press MODE after ecah function is set, (hour, minute etc.) once everything is set, press MODE again to see steady display.
Jul 21, 2010 | Casio WVA105HDA Wave Ceptor watch
Replacement Strap FOR DZ1131
customerservice@dieseltimeframes.com
Send them an email! they can probably assist you best!
Jan 07, 2010 | Diesel 3 Hand Brown Digital Quartz Display...
Broken band
You can go to walmart and they sell bands and also try the flea mkt. They have all different brands that fits your style and even change the pins.
Nov 30, 2009 | Diesel 3 Hand Brown Digital Quartz Display...
Setting time on Seiko watch 7N43
Mike 1935 if your watch has hands only & no digital display the crown where you set the watch pulls out half a click to set the date and should pull out a little further to set the time try that.
bjbc I am assuming your seiko watch is a digital watch. Try holding in the top rt button if its the watch I think it is it should change to 12yr time.
Mar 09, 2008 | Watches
Diesel 3 Hand Brown Digital Quartz Display DZ4038 Watch for Men Logo
118 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Diesel Watch Expert? Answer questions, earn points and help others
