Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Hi my dyson is not sucking up very well when i put it on its side and switch it on the brushes are not going round when i put the white dail to on at the bottom the brushes go round but it makes a terrible noise i have cleaned the brushes checked the soleplate is on correct and taken the clear hose off and checked for splits the suction is there when i have been checking these things hope you can help thx
  • Official Brand Answer
  • 2,572 Answers
Sorry to hear you're experiencing a problem with your cleaner. Please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US). We can run through some checks over the phone and provide you with the assistance you need.
Kind regards,
Jack
Dyson Customer Service
Posted on Jun 17, 2011
How do I reset my dyson dc25
You may need a new belt if the brush bar motor is working properly. It could be the switch or brush bar motor if the motor does not run .
Jul 06, 2014 | Dyson DC25 All Floors Bagless Upright...
Wand suction getting activated - Dyson DC40
Is the vaccumm on or off when you put the bin back ?on?
Apr 13, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Dyson brush wont turn
Hi There is a reset switch on your Dyson that needs to be pressed when something gets stuck in the brushes. The reset switch helps protect the motor that spins the brush from damaging if something gets stuck inside the brushes. There is a little red pole that sits up behind the brushes on the vacuum head, I believe it's on the left side of the floor head as if you were behind the machine vacuuming. Try pushing this reset switch first.
Oct 08, 2012 | Dyson DC25 All Floors Bagless Upright...
Brushes wont go round
Your DC24 is equipped with a sensor which shuts off the brushbar if something jams it. Once you've checked the cleaner head for obstructions, and removed any threads or hair from around the brushbar, you should be able tor reset the machine as shown in the video below.
You may also want to refer to our online Support guide:
http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/my-brushbar-is-not-rotating/stabiliser-check
Please note, the brushbar will never rotate when the machine is standing upright, so make sure you recline the machine into the vacuuming position before testing it.
This should resolve the issue, but if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK) or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 06, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
My Dyson DC17 sucked up a scarf for about 5 seconds before I could shut it off. The belt did not break however the roller brush will not turn now! I looked for a reset button when checking the belt but...
To be on the safe side I would remove the brush just as if I was going to put on a new belt. Perhaps your belt stretched just enough so that it will not get a grip on the motor spindle and brush. Clean the brush while you have it off and be sure it turns freely. You can see details at this URL: http://media.dyson.com/downloads/US/floorcare/manuals/dc17_opmanual_usa.pdf Also at this URL you can see the ON/OFF button for the brush itself, did it get turned off accidently?
If you find this solution to be helpful, I would appreciate a Thumbs Up rating from you. Paul
Oct 11, 2010 | Dyson Vacuums
My brusg stopped turning after sucking up a shoe
Hi There is a reset switch on your Dyson that needs to be pressed when something gets stuck in the brushes. The reset switch helps protect the motor that spins the brush from damaging if something gets stuck inside the brushes. There is a little red pole that sits up behind the brushes on the vacuum head, I believe it's on the left side of the floor head as if you were behind the machine vacuuming. Try pushing this reset switch first. Did this fix your problem? If no, please let me know and I'll be more then happy to do some more advanced diagnosing with you.
May 02, 2010 | Dyson DC25 All Floors Bagless Upright...
Beater bar not working
Hi its Darran at Dyson.
If the brush control has been switched off the brush bar won't go round when the vacuum cleaner is lowered into the vacuuming position. If this is in the correct position, we would recommend checking the brush bar and cleaner head for blockages as this can prevent the brush bar turning.
If none of the above resolves the problem, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Many thanks
Darran
Apr 12, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beeter brush not spinning
Hi If the Dyson has a brush protected switch on the left hand side of the machine, then it has a drive belt that can only be replaced by a serviceman or Dyson repairer. If the Dyson doesn't have brush protection, then pop open the sole plate and change the drive belt.
Apr 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction when vacuming floors
Hi.
There are 2 types of Dc07 one is clutched & has two belts the second has only one belt going from motor to brush roller.
Lay machine on its side pull back handle as if you are to vac carpet switch machine on look to see if brush roller is spinning.
If it is not spinning unplug machine from mains supply & remove the sole plate by turning the three plastic screws to unlock position, Lift sole plate away if you have non clutched machine you will now see the brush roller with A belt going from this to the motor shaft belt may have snapped or come off so replace it.
If your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive.
If you still have no brush rotation after doing all this then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
There are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/index.htm
Jul 05, 2008 | Dyson DC07 All Floors Bagless Upright...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
378 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
