taken out HD and battery turn on (all the lights come on and go off the circle with the Z in stays on) and I get the IBM screen (hit blue button to enter setup etc) it stays on screen for 22 secs approx then turns off (if I hit the blue IBM button I can get in to the bios or boot normally options) after the count down then it re starts it turns off ??
firstly thanks I really apprietiate your help.
You can't post conmments that contain an email address.
Navigate here: http://www-307.ibm.com/pc/support/site.wss/migr-46024.html
Click the link for Mouse/TrackPoint
Select the driver for the Windows installation you are using.
Note: The machine type on the R40 does not matter for the Mouse/TrackPoint driver, only the Windows version you have installed.
Best,
Hunter
I hope you elaborate more, what you did in installing the printer, so I can advice directly in your problem,
but any, I have some guidelines in troubleshooting a printer and hoping that this can help you in determining the problem.
if is connected to USB see if Operating System problem,
if your using XP or Vista and your system cannot recognize it, then OS is not Updated or Modified, I encounter some of XP and Vista OS.
what your going to do is activated your auto update, in the internet, so the Microsoft will automatic update your system. after a multiple updates, your system can now recognize any new drivers.in doing this: in your control panel, double click security center, ON the automatic updates or you can use the link below fo direct download:
This could be a battery problem. Remove the battery and start on the power supply only. If this doesn't work, then check the power supply with an ohm meter to see if it's getting the proper output to the machine. If the supply checks good, then I'm afraid that you have a problem component on the motherboard, and will need to have it professionally diagnosed in order to track down the exact problem component.
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
"FixYa!"
- The solution provides great advice on how to solve the problem.
"Helpful"
- The solution provides useful leads that helps solve the problem.
"Thanks
for Trying" - The solution does not solve the problem but the
effort is appreciated.
"Inappropriate"
- The solution has absolutely nothing to do with the problem.
I had the same problem but managed to track down the firmware file qvr40.bin , copied it onto the mmc then updated on camera. All seems well now, so hopefully fixed the problem
