Question about Samsung SF-5100 Plain Paper Laser Fax
Wont accept a new toner cartridge makes a very
Wont accept a new toner cartridge makes a very loud screeching noise
    Champion:
  • Samsung Expert
  • 214 Answers
You have to cleaan all the gears. on the side and use a bit of oil.
this is a commen problem form sf 5100
Posted on Oct 06, 2011
Ricoh Aficio SP213w jams
Hey Check the catridge it properly seated or not in no then remove and reinsert.
If yes then replace with new one.
Apr 20, 2016 | Ricoh Aficio Office Equipment & Supplies
Brother MFC-8480dn laser printer makes a high screeching noise when prints.
Typically what causes what you are describing on many laser printers is the worn-out three gear set between the toner cartridge and fused assembly that needs replacing but sometimes simply replacing both the fused assembly and toner cartridge will temporarily resolve this issue
Feb 11, 2015 | Brother Office Equipment & Supplies
Lexmark c772 when printing it make load Laud noise
Please power off the printer. Remove all the toner cartridges. And then put them back in. Make sure you install the toner cartridges properly. After that power on the printer. Try printing again.
Jul 20, 2012 | Lexmark C772dn Laser Printer
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
I have a 1990 jeep YJ replaced the alternator and now there is a loud screeching noise replaced the belt,replaced new bearing in idler pulley still makes a loud screeching noise?
If the belt is not tense enough it will squeal, so make sure it's tight enough. Otherwise you can use a stethoscope or long screwdriver up to your ear to isolate the source of the noise.
Sep 16, 2009 | 1990 Jeep Wrangler
Can't load the toner because the access point hasn't spun round far enough to accept the toner cartridge
Open the front cover and look at the L/H side. You will see a hole with what appears to be a circular plastic piece inside it. On the cover itself should be a piece of plastic that sticks out. Notice that as you close the cover this enters the hole and depresse the "circular" bit inside. This unlocks the cartridge carousel so that it can rotate. Simply use a pen or screwdriver to depress the circular bit inside the hole and rotate the cartridges by hand until the right cartridge is aligned for removal. (BTW If the plastic part on the door is broken off the printer will make a loud screeching noise when it is switched on and an error will occur).
Hope this helps & good luck.
Jul 09, 2009 | Epson Office Equipment & Supplies
When I print with my bother 1450 hl laser printer, the printer ma
Hello sir; Before we go further I suggest you replace a new cartridge see what happen.
May 18, 2009 | Brother HL 1450 Laser Printer
LOUD NOISE
Hard to tell without hearing it. But, if it is doing it all the time it is turned on but not in use most of the time that would be a fan making the noise. The other suspect would be a fault toner cartridge or the fuser. you may need to have a tech look at this.
Hope that helps...
Jun 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Makes click a clack noise and toner cartridge wont come out!
Toss it.
These are 'disposable' printers. You can get a new one for less money than it would cost to fix.
Feb 20, 2008 | Brother HL-2040 Laser Printer
Samsung SF-5100 Plain Paper Laser Fax Logo
94 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
