Question about Sony DAV-S400 System
My system is stuck on (c2) headphone and I can not any sound, unless I put the headphones in.
  • Sony Master
  • 2,098 Answers
Hi Steve,
This is an indication of faulty earphone jack, this is where the headset directly hooked up. See sample picture below.
When the you hooked up the headset to this jack, internal switch will released the contact to cut the audio goes to the main speaker out of the unit. Once you pulled out the headset plug, the audio will back to the main output speaker out through this switch.
In your cased, there's a malfunction in the internal switch of the earphone jack that's you haven't sound output at the main speaker out.
You may spray contact cleaner directly to the earphone jack while inserting and pulling out the headset plug to clean the lead. If the symptom still persist, you must replaced it with new one to back the unit in normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
Posted on May 17, 2011
I have a 2002 Chrysler Town & country and I can't get the sound to work for the Vcr/player Without headphones. How do I get the sound without the headphones?
I had one of these and it turned out to be the headphone jack, when you put the headphone plug into the jack it disables the speaker and when you unplug the headphones it enables the speaker. There's a contact in the jack and it is probably stuck to headphones. The jack may need to be replaced. Try and wiggle the plug a few times but not hard as it may break from the curcuit board.
Oct 19, 2014 | Cars & Trucks
Turning off
I got a DAV system that had exactly the same problem, ie. it was stuck in "headphone mode", this mode should be active when headphones are attached then it should revert to amplifier mode when the headphones are removed.
I opened the cover and removed the amplifier output board (the one where the speaker wires connect to) and soldered the following dry joints.
1) large brown capacitor on the amp output board.
2) dry joints on the rear headphone socket (the one that has the connecting lead from the front headphone socket)
3) Then one of the surround channels didn't work so I soldered further dry joints on all the coils (white vertical rectangular blocks)
I tested all surround chanels before putting the lid back on (careful, watch the mains) and found all was now working ok.
Mar 11, 2008 | Sony DAV-S500 System
No sound without headphones sound with headphones
your device speaker or head phone socket is defective.
Aug 04, 2014 | Computers & Internet
IMac G5 17" no sound from internal speakers and no start up gong,, OK on external speakers and headset
The first thing you should try is to hold down the keys command-option-P-R as you power up the system. That should reset the PRAM in case there is any funny muting information stuck in there. If you hear your optical drive reset more than twice and there is still no chime sounding, let go of the keys because that's not the problem.
Go to System Preferences / Sound. Choose the Output tab. It should say something like "Internal speakers, built-in." When you plug in headphones, it should switch to saying something like "Headphones, Headphone port." If (as I suspect) the output is stuck on "Headphones, Headphone port" whether the headphones are in or out, the problem is most probably a very simple mechanical problem. There is a "shorting strip" in the output jack that makes an electrical connection back to the speakers when a plug is removed, and it may be dirty, bent, or broken off. If it's not broken, it's possible to clean it and/or move it back into position with really fine gauge tools and a steady hand. If it's broken off, you're out of luck unless you want to solder a new jack onto the motherboard (I wouldn't recommend it).
Apr 14, 2013 | Computers & Internet
The tip of the headphone jack broke and got stuck inside our lcd tv's headphone port. Now the tv has no sound unless you put the head phone
You need to lay the TV down on a carpet or bed, take the back off and possibly the board that has the jack to poke the tip out from the other side.
May 25, 2010 | Samsung LN-S4051D 40 in. LCD Television
My razzle. headphones only to hear sound.
I sprayed WD40 on the headphone plug and put it in and out of the headphone jack on the phone a few times. It seems that the jack gets stuck when the headphones are plug in but doesn't go back when the headphones are removed.
Apr 13, 2010 | Cell Phones
2005 dodge caravan, factory dvd... no sound through speakers
My grandcarvan sxt came with a remote for the DVD system and wireless headphones from KOSS. You have to press the headphone button on the remote to change it to headphones otherwise it comes through the main system. With the button pressed we can listen to cd or radio in front while they wear the headphones in back. You might need the remote to change it back to main system. The headphones from Koss are lifetime guaranty and not too expensive.
Dec 06, 2009 | 2005 Dodge Grand Caravan
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
Sound still appear at speaker even when headphone was installed
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Jan 23, 2009 | Audio Players & Recorders
Sound is warped
Likely what happened is, in your efforts to get the piece out of there, you loosened a solder point on the headphone jack, and it will need to be resoldered. If you don't feel comfortable doing this yourself, you can send it to a technician who can.
Sep 15, 2007 | Creative Labs Zen Micro MP3 Player
Sony DAV-S400 System Logo
136 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
