Question about Kitchen Ranges
Bunn G9 grinder. Adjust portion time. Since power went out the portions are low. It has an analog dial. There are 2 knobs and 2 switches. One for left one for right. I don't understand the switch. Each has a high and a low position. The knob has 2 scales. One for high and one for low. I am going for a 2.50 oz setting. I can't figure out the high low switch The manual says nothing about it
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link to understand the operation of the knobs and switches for your product.It has elaborately described the functions in page 4:-
http://docs.google.com/viewer?a=v&q=cache:QZWZgdMTK9MJ:www.bunnomatic.com/pdfs/commercial/manuals/10218.0000.pdf+Bunn+G9+grinder+instruction&hl=en&gl=in&pid=bl&srcid=ADGEEShbCbauP-2WLjsktG4OUAAGAexxtYuyzvk5gbvQWNpCd9QxwdbNKoBDQaq9D46ot4e1b7INctjENNn0XwXINZJf8LzOEgzDlkFfqFngYEFpmNK26v3bM1BDZri_ED81OS6wUnwl&sig=AHIEtbRbxZSmjx3D6ogi3nx6425RD_BpBg
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 17, 2011
Hi, can you adjust the portion size of beans ground per cup for a saeco rotel conforta automatic espresso machine. The coffew is coming out fine, but too weak.
In the waste basket you got a nice round coffee puck i think you need to ajust the grinder its not chopping fine enough press for a coffee and put the dial down 1 like if your at 6 put 5 remmember the coffe you grind will take 2 coffe to reach try a couple and if your satisfied good if not go down on more try again
Mar 29, 2015 | Saeco Coffee Makers & Espresso Machines
Analog on digital watch not working
when a watch has analog hands and has digital portion, 9 times out of 10 it will have 2 batteries inside. A lithium battery and a normal battery. It is possible one died before the other. Usually the lithium (digital portion) lasts longer. Have the battery changed.
Dec 06, 2013 | Watches
I cannot move the screw to change the grind. How do I do this on a G9.
It should be easily move.I don't know how its stuck.
BUT a Good advice.If you in future disassemble the grinder.Then,make sure you either count the screw rotation of unscrewing or just put paint mark on screw where it was previous fixed.
Once you open grinder its very hard to put it back to work grinder like before.
Thanks
Please rate my work
Sep 19, 2011 | Bunn G9 HD Electric Burr Grinder
I took off the grind settings knob on my Bunn G2 grinder... and now it won't grind!
oooooooooppppppppppsssssssssssssssss
you should not do this
the knob keeps two burrs together .The knob forces the screw (when you turn for grinding quality).
and adjust burrs far and close as needed
.reinstall it and turn the knob to the right until you feel tightness.Then,turn to the left 3 turns. and then adjust the grinding quality whatever you like .
thanks
please rate my work
Apr 27, 2011 | Bunn -o-Matic G2 (2 lb. Commercial Coffee...
I have a bunn coffee grinder that keeps on jamming up everytime you put coffee beans in it. I took the front part off to clean it out every time it jams,but it keeps on doing the same thing. The model bunn...
It sounds as though your grind is out of adjustment. The grinder is probably set too fine. I have not worked on a G3 grinder but I would think it is like the Bunn G2. On the front knob you will find 2 small set screws and one larger adjustment screw (in the middle of the knob)
1. Set the selector knob to finest setting (Espresso or Turkish)
2. Loosen the 2 set screws about 2 turns.
3. Activate the start switch (you must activate the "bag switch" behind the chute)
4. With the grinder running, SLOWLY turn the center screw clockwise only until you hear a very slight whirring sound (this is the burrs touching).
5. Then, back off the center screw counter-clockwise about 1/8 of a turn, shut off grinder and re-tighten the set screws.
Check the grind in the "drip" setting by running a few beans through... the grounds should be about the consistency of sand. You should get a better flow through the machine with the grind adjusted properly. You may want to check the cleanliness of the hopper in the top... I have seen these dirty enough to impede the falling of the beans to the grinder.
Also, whenever you remove (for cleaning) the 2 larger screws that hold on the front "plate", be sure to put them back in evenly... kind of like one would with a wheel on a car- Finger-tight then slightly tighten each on a little at a time (back and forth) until tight.
Hope this helps.
Oct 15, 2010 | Bunn Coffee Grinder
Grind is like powder
There are 3 springs in the holes around the top neck of the machine, the top part which sits under the collar adjustment knob.
Mar 28, 2010 | Mazzer Grinder-doser MINI
Bunn omatic won't make full pot-even with water line hooked up
Use the dial with numbers on it and adjust to a higher number. Remember to go in half steps such as 2 adjusted to 2 1/2, 3 adjust to 3 1/2 etc.
If you only have a High Low knob, that is to set your water temp.
If you have an electronic circuit board, you will need to follow the batch instructions pasted on the inside cover (facing the lower burner) to adjust for water level/batch. This cover has 4 screws.
Sep 08, 2009 | Bunn VPR Coffee Maker
Bunn G2 is caked and I need to remove burr gear
For this job, you will need detailed instructions. You can download a use and cleaning manual for this Grinder at this adress: http://www.bunn.com/pages/techdocs/manuals/grind.html
Nov 18, 2008 | Bunn Commercial Grade Home & Office Black...
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
