Question about Plumbing
Why well pump model mse-7 motor stop working. I replaced contactor coil it lost one leg on it. Well ran great for a week then I guess points on well got stuck it kicked breaker.I replaced points but motor hums. Points stay closed.
    Genius:
  • 1,400 Answers
Hello
Check your voltage at the pump,past the coil.if you have voltage then the motor bearings are worn or its open on thermal overload.Possible bad motor.
Also at the contactor check to see if it has themal overload protectors.
Posted on May 17, 2011
Air conditioner outside fan does not turn off
Is the compressor shutting down and fan is not??? How about the blower, is the coil freezing? Need to check the contactor on the outdoor unit, 240 volts hurts, please use caution. If not confident as to what you are doing call a professional. If need be turn off breaker, you do not want the coil freezing inside!
Aug 19, 2017 | Heating & Cooling
Tip
What to check when you air conditioner will not stop running:
If you discover that your outdoor air conditioner and/or heat pump runs continuously even with your thermostat off and the indoor blower is off, the most probable cause is a stuck contactor. In most residential air conditioners / heat pumps, the contactor is the switch that allows voltage to your compressor and condensor fan motor; therefore, allowing them to run. The contactor allows line voltage (normally 208 - 240 volts) to pass through a set a contacts to your motor. The contacts pull in when the thermostat calls for Cooling and they "open" when the thermostat "satisfies". This is accomplished with the use of a low voltage coil. When 24 volts is applied to the coil, it creates a magnetic force that pulls the contactor in to close the contacts. When the 24 volts is removed from the coil, the magnetic force no longer exists.....a spring will force the contacts back "open" and stop the compressor and fan motor from running.
The contactor is considered a wear-n-tear item as, eventually, the contacts will wear and begin to "pit". Eventually, they will either pit so severely, they will not allow enough voltage through them to operate the motors OR they may allow enough voltage and then overheat and weld themselves together. Often times you can lightly tap on the contactor and it will "free" the contacts and stop the motors. Unfortunately, once the contactor starts "sticking" it is highly likely it will stick again. Therefore, it is recommended that the contactor be replaced at first sign of sticking or when the contacts show signs of damage/overheating via a visual inspection.
Here's a video that might be helpful to you. :-)
on Apr 27, 2010 | Heating & Cooling
My grizzly bandsaw has voltage to the saw motor but the but motor does not turn. i have amped saw motor out = no draw. i have ohmed the three legs of saw motor and get readings of 10.4 ohms between
Check the rotor to see if it's locked (bad bearings, rust, crud inside motor, etc). Also try running it without any belt. Check the wheels for binding. If it has a gearbox (I can't tell, that's not a Grizzly bandsaw model number), check the gearbox to make sure it runs freely.
Jul 25, 2014 | Grizzly Saws
I have a evcon eb12b heat pump, it works intermitantly on heat, ihave replaced the contactor, and have 24v at the contactor, come times the heat pump will come on sometimes it wont, The hvac repair guy...
does this unit have a capacitor that is hooked up to the motor, as it may be the capacitor or motor, of course this is just a guess as I am not there to see it. I guess you can push in the contactor a few times and make sure all is coming on like it should, might be the control board. Just a matter of pluck and chuck. Good Luck Tim
Oct 24, 2010 | Heating & Cooling
My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
Coleman A/C-Heat Pump Start and Stop Run Problems
well you have it great job! on the out door unit when it will not shut off disconnect the yellow wire on the stat wires coming from inside if unit stops stat bad if not contactor "points' if they look pitted or buzz change them #1 reason for compressor failure high amp draw thru bad contactor hope this helps aboout 15.00 at hvac store seperate wires with zip ties so dont get mixed up if only one set of points then 30amp single pole 24vac coil contactor
Jun 04, 2009 | Coleman Mach III Air Conditioner
I purchased a Friedrich PDH15KS BTU Cooling, 17,000 BTU Heating, 9.3 EER PTAC Air Conditioner With Heat Pump and 5.0 KW Backup Electric Heat....in October of 2007...it was installed in November and ran...
The Warranty will be expired. Sounds like the contactor for the heater is wearing. Obviously a guess, but, "rattling" sounds like a bad cintactor to me. If thats the case, im guessing $100 diagnostic, $75 for the contactor, ISH...Best Wishes!!
May 23, 2017 | Friedrich Heating & Cooling
Plumbing Logo
77 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
