Question about Thetford Porta Potti
Thetford Toilet C402CL in camper When you try and fill up the cassette from the outside the water doesn't go anywhere, it just remains in pipe. Please can you advise how to unblock
4 Suggested Answers
SOURCE: hi our thetford cassette toilet (c200)blows the
Probably the rotor has come to a stand still (carbonade). I suggest you will clean the rotor with an house-hold acid liquid (like the one for cleaning coffeemachines).
Flying Dutchman.
Posted on Aug 04, 2010
SOURCE: I have a thetford cassette
HAVE BOUGHT A SECOND HAND PORTA POTTI 165 ELEGANCE AND DO NOT KNOW HOW TO WORK IT
Posted on Jun 15, 2011
  • 7 Answers
SOURCE: We need a Manual for a Thetford Cassette C200,
Email Thetford Australia on infoau@thetford.nl and they will email a copy of the manual.
Posted on Oct 13, 2011
The flush pump on my thetford cassette toilet is not working
Thetford makes toilets with hand pumps , and electrical pumps . Permanent , and portable toilets . Without more info , it is hard to guess . With my portable electric model , batteries had to be replaced .
If you need parts , go to ;
http://www.thetford.com/products/toilets/cassette-toilets/
Click Parts at the top , and go from there .
Feb 05, 2018 | Camping, Backpacking & Hiking
How do you Clean out algae in toilet water holding tank
Walmart sell aglaecide for swimming pools and hot tubs. I'd use that first. After algae has died, scrub inside of tank lightly and flush a couple of times.
Aug 06, 2014 | Thetford 33203 Sliding Cassette Cover Gray...
Pump works no water
Thetford makes good pumps. No pumps last forever, actually only 4 to 5 years of constant use because the pump sucks air at first startup before pumping fluid. Air ruins the pump. The pump also collects sand (small tiny particles) which act like sandpaper and ruins the shaft, and impeller, etc. It's cheaper to buy another pump than to fix it, because more importantly you won't find parts to fix pumps. whether RV pumps, or Fountain pumps - the reason is the pumps require to be sealed - factory seal. So no one will carry parts.
May 10, 2014 | Thetford 33368 Cassette Toilet Pump Camper...
My toilet in my camper is leaking water from where it mounts to the floor
If its like a normal toilet there is a wax ring that might be bad/needs to be replaced. Its a cheap part.. but work to get to it... have to uninstall the toilet.
Sep 19, 2013 | Thetford Porta Potti
I have neptune parma toilet, which was purchased 6 months ago. It was working fine but now it has a problem with filling up. It takes a minute before it will start filling up then it makes noise like...
This is usually the fill valve. Try adjusting the water height. If that doesn't work, you can replace the fill valve fairly inexpensively with a new one at any home improvement store
Aug 27, 2011 | Neptune FB1625 Parma Toilet
We have a water leak on a Thetford Style Plus toilet installed in our 2 1/2 year old Fifth Wheel RV. The toilet flange bolts appear to be tight and there is no visual evidence of black water leak or...
Thetford says that the vacuum breaker is usually at fault. I have the same problem. Try changing the vacuum breaker first (it is easier than the water valve).
Dec 23, 2009 | Thetford Porta Potti
Casset toilet will not pump water for flush
Open door, remove toilet cassette unit, look in under flush water tank, observe a short metal blade that actuates a safety switch. This is between two plastic guides. Now look just outside the right hand guide. There you will find the fuse which is a standard blade type. Just pull it down to remove from holder. You will probably find it rated at 3 amp. If it is blown you will probably have to replace pump. Looks difficult but is actually dead easy. Instructions come with replacement Thetford pump. Only problem you may have is a perished sealing ring on the paper holder cup which is no longer available as a spare. Just use a good quality outdoor type sealant as a replacement. Be sure to recover any bits of broken ring from the flush water tank as these can be drawn into your replacement pump and cause it to sieze. At minimum this will cause you to say bother! Happy repairing.
May 27, 2009 | Thetford Porta Potti
Need take out thetford toilet of ace award
can anyone tell me where is the fuse fits under a thet ford cassette toilet model ppc2r and wot size
Apr 27, 2009 | Maximum Thetford Porta Potti 365 Portable...
Thetford Porta Potti  Logo
85 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Patricia Cross
Level 1 Expert
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
stynger007
Level 1 Expert
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
