Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
I have a Transcend JetFlash here which the Windows XP CANNOT possibly recognize. Base on my suspicion, it could be I have removed the said JetFlash from my USB drive.
  • SanDisk Master
  • 32,281 Answers
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Posted on May 17, 2011
Transcend jetflash 210 not working in windows 7
Click Start, then Run Enter regedt32.exe and navigate to HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb f a USB key doesn't exist, create one and create a new DWORD value called DisableSelectiveSuspend and make its value 1. Restart the PC. Transcend have a lifetime warranty http://www.download3000.com/download_48621.html
Jan 15, 2013 | Electronics - Others
Transcend 32gb jf v60 pen drive not working
If now you can see your usb drive there might not be any need to do the following
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you might have restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Transcend jetflash recovery
JetFlash Online Recovery is an advanced new software tool specifically developed for Transcend JetFlash USB flash drives.
If your flash drive is not working properly, in most cases it can be repaired instantly by using the recovery tool's simple user-friendly interface.
The JetFlash Online Recovery Tool is conveniently located on the Internet, so no matter where you go, you can service your flash drive 24 hours a day, 7 days a week.
All data on your JetFlash drive will be permanently erased during the repair process.
Please backup the contents of your JetFlash before proceeding.
This software is designed to repair malfunctioning JetFlash USB flash drives.
It will not recover
any data/pictures stored on the device.
Hardware Requirements: USB Port (supports USB2.0), Internet Connection
System Requirements:
Windows XP SP2/ 2000 SP4 or later version(Administrator rights required)
Windows Vista (Administrator rights required, must turn off UAC) To turn off UAC in
Windows Vista, please go to Control Panel > User Account -> Turn User Account Control on or off > and then uncheck ''Use User Account Control to help protect your computer.'' Please remember to restart your PC for the new settings to take effect.
Windows 7 (Administrator rights required, must turn off UAC)
To turn off UAC in Windows 7, please go to
Control Panel -> User Accounts -> Change User Account Control Settings -> change to "Never notify" -> then, Please remember to restart your PC for the new settings to take effect.
Download Links
JetFlash Online Recovery (for Windows 2000 SP4/ XP SP2/ Vista /7)
JetFlash Online Recovery (Only for V15; for Windows 2000 SP4/ XP SP2/ Vista /7)
JetFlash Online Recovery (Only for JF620; for Windows 2000 SP4/ XP SP2/ Vista /7)
User Manuals for JetFlash Online Recovery
Manuals (Traditional Chinese)
Manuals (English)
If you need more help with this post a reply
Hope this helps.
Nov 27, 2012 | Electronics - Others
Usb TRANSCEND JETFLASH " ELITE" NOT WORKING ON WINDOWS 7
what i have found is that you will need to use your jetflash 8 gb with windows 7 only if you keep trying to use it with xp you will get error messages or wanting to scan or format it
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
hope this helps you
Jan 18, 2012 | Electronics - Others
Windows Xp not recognise my USB TS4GJF110
To initiate recognition of the USB device by using Device Manager, follow these steps:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
Windows XP recognizes the new device.
4. Close the Device Manager window.
Aug 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to remove write protect on my 8gb transcend jetflash
If you dont have any switch for 'write protection' in the USB body, then download the utility called 'Jet Flash Recovery Tool' from trancend web site. It could help you.
Please come back and rate my solution if it turns to be helpful for you. Thnx
Mar 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Win98se doesn't recognize transcend jf v30 4gb device
Download unzip and install the Win98SE driver for JetFlash V30 frm transcend:
http://www.transcendusa.com/Support/DLCenter/Driver/JF_win98driver.zip
HTH,
Regards,
Deboo
Feb 16, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Download copy JFSW.exe for JetFlash elite
Driver Installation – Windows® Me, 2000, XP and Vista
No drivers are required. Newer Windows operating systems have built-in drivers that support the JetFlash®. Simply plug your JetFlash® into an available USB port and Windows will automatically install the files needed to use your device. A “Removable Disk” with a newly assigned drive letter will appear in the My Computer window.
JFSW.exe is the older version. You might want to try JetFlash Elite v2.0, a newer more advanced version of JetFlash elite - highly recommended:
http://www.transcendusa.com/Support/DLCenter/Software/Setup_JFSW2.exe
I think you know about this page, but here's a link to save you googling:
/index.asp?axn=SRH2&ModNo=107&ItemID=TS2GJFV30
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Transcend T.sonic 610 MP3 Player
Transcend jetflash 2GB no detecting
ny Transcend jet flash 2GB fingerprint not recognized, any help fpr me pls to format or to find any solution for this problem...
thanx
Basman
Nov 01, 2008 | Transcend (589307) Media
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
145 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
