Question about GE GSS25JF Side by Side Refrigerator
GE GSS25JFMD side by side, the water does not always dispence.New filter and clean water line.Sometimes it works fine then just stops for a while,then just starts working????
    Problem Solver:
  • 17 Answers
My guess is that the water line is at the dispenser is freezing up.
GE had some problems with this had have a heater kit that sells for about $60 un-installed that usually resolves this problem. This heater is an after market fix and has to be hard wired/spliced into other wiring of the dispenser. As a technician I never liked installing these and would advise against a DIYer from doing it.
However, if you chose to do so the heater kit does come with complete instructions.
I would also recommend that you ensure that the water line freezing is the problem. You can do this by the following.
When it does not dispense water follow these steps.
1st-- Remove the toe kick at the bottom of the ref.
2nd-- You will find a plastic water line coming from the hinge of the freezer and it goes through a hole. Pull on this hose pulling the line through this hole where you should find a coupler. You want to take the hose apart at this coupler.
3rd-- To do this the coupler works like a Chinesse finger cuff (sorry, but that's the only way I know how to describe it). You want to push the water line in a little and hold the white plastic lip/sleve and then pull the hose out.
4th-- Once this is done. Press the disp. lever as if you were getting water. If water comes out of disconnected hose then it is safe to say that the water line if frozen at disp. If water does not come out then there is something more going on.
5th-- To reconnect the hose to the coupler just push. Then give a slight tug to ensure its locked in there. Press disp. lever to check for leaks
Posted on May 17, 2011
Water will not dispence in ge refrigerator model number gsl25jfpa bs
Your line is frozen. Frozen water dispenser line is a problem with this model. There are number of solutions.
1. Contact GE 800 386-1215, option 5 and ask for WR49X10173 heater kit. There is a video http://www.youtube.com/watch?v=BdNX3LteJTw to help you install it. Try to get GE to send you the fix free.
2. Get a hair dryer and heat the dispensing box until the water dispenser works. This is not a permanent solution, though, and it takes 15 to 30 minutes. Hang a long beach towel or blanket over the open freezer to save the cold air.
3. Place a long, clean fishing line or weed wacker line up the water dispenser line. When it freezes, pull carefully to dislodge the frozen water.
4. Buy another brand of refrigerator and let GE know they make inferior products.
Jan 10, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Water dispencer works and stops, works and stops
I have a similar refrigerator and there is a problem with the the water line freezing in the area of the freezer door. You can solve it by removing everything perishable from fridge and shutting it down. I have had to do this twice and it works. We now keep the freezer set at 1 and it has been fine for a year. GE does make a small electric aftermarket heater that goes in the door area if needed.
Mar 27, 2011 | GE Profile Performance 25.2 cu. ft....
Water dispenser not working
This could be that your water supply is not good , check to see if you have plenty of water pressure going to the dispencer, this is aproblem sometimes at the valve, also change your filters, and make sure all is clean, this is a good start, if this does not do it will have tocontnue to troubleshoot
Feb 04, 2010 | GE GSH25JFR Side by Side Refrigerator
Kenmore side by side water dispenser has stopped
Most likely need to replace the water inlet valve. The water supply line should be directly connected to it. There are 2 valves bracketed together, 1 for the ice maker and 1 for the water dispencer. You will probably have to buy both valves, but want to do this anyway as the second valve will fail soon. Hope this helps.
Jun 14, 2009 | Refrigerators
GE GSS25LGMF Water dispenser-no water
Order and install a WR49X10173 water tube heater. It may take 24 hours to then thaw, but it has worked for me on numerous refrigerators. Cost for the part will run about $50.
Feb 07, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
Water dispencer want work
yes the filter will keep water from dispensing but the best way to see if it is it is take your kickplate off under your doors and you will see a water line coupling unhook it there by putting your fingers on each side the line and pulling back on the coupler then put the line in a glass or bowl and push in on your dispensor paddle if you have water there then call a authorized technician cause it is frozen inside the door
Dec 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
In operative water dispenser.
I have GE side by side refrigerator - 2004 model GSH25SGRB SS. From the blog I found out the problem is with frozen water line. If I keep the door water would dispense ( thawing). Or if you disconnect at the bottom ( take the grill out and disconnect) the water would dispense.
I placed a call to GE. The service person came. He said GE could fix with a 3 watt heater. He opened the panel. Pasted a heater. It came in a Y shape form. He connected that to the internal wiring. After some time the water started working.
Part $40. Labor for 15 min work = $210. Total = $250.
This is really should be a recall case. No part broken. They had to design a heater to solve this problem. What a rediculus thing is this. I am trying to call GE and ask to refund.
What a cheat GE!!. F them.
Feb 11, 2008 | Refrigerators
GE GSH22JSRE Refrigerator Ice / Water Dispensing Issue
I have the same issues as above, ice maker makes ice but will not dispence or give water,
when I push the lever to get anything the lights go out and the fans slows or stops until I let go of lever.
Side by side GE : Model # GSH25KGRE WW / Serial # MG278521
has anybody else had this issue with this model?
Feb 02, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE GSS25JF Side by Side Refrigerator Logo
220 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
