Question about Epson LQ-2090 Matrix Printer
I have added a new paper size on the epson LQ-2090. However when i come to print the document my paper size doesn't appear. Please can you advsie?
I use COSA software. Fanfold paper size 15"X12" but Printer Epson LQ 2090 did not match. advice me.
Posted on Aug 15, 2012
dodgecharger
  • 254 Answers
SOURCE: epson lq 2090 matrix printer
This may be a mechanical problem- perhaps the belt which pulls the printhead back and forth is slipping a cog tooth in the drive mechanism. Check this belt for proper tension, and that the cogs are in good condition.
There is also a home sensor located at the left-hand side of the printhead movement area which sets the home position of the head, and from this, the start of printing is determined. If this home position sensor is defective, this will cause problems. One certain Epsons, this sensor was a switch, and this would become erratic.
These are possibilities to check...
Posted on Feb 01, 2008
alvinbga
  • 130 Answers
SOURCE: Printer Epson LQ 2090 out order
Light Pattern Beep Pattern Problem
Solution
________________________________________________________
* Paper Out light An unknown or serious
* Pause serious error has occurred
** Tear Off/Bin ..... ______________________
*** Font Light Turn off printer and leave it
*** Pitch Light off for several
seconds; then turn
on the printer again
Posted on Jun 19, 2008
SOURCE: PROBLEME OF MY EPSON LQ 2090
je veut voire les composants du imprimante epson lq2090
Posted on Mar 03, 2008
SOURCE: My Epson LQ-590/LQ-2090 keeps having paper jams
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Posted on Jun 24, 2009
SOURCE: How to define a custom paper
Sir,
I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for WindowsXp using printer Epson-LQ-2090. immediately
Posted on Aug 17, 2009
When I print a multiple page document on tear paper roll, the first page prints correctly but the pages after that start printing too near to paper tear size or up to paper tear size. What should I do
Sounds like your top margin is not either not set properly or your documents do not have page feed command at the end. Are you sure you have the correct driver installed?
Nov 23, 2014 | Epson Dot Matrix LQ-2090 Printer
What is the meaning of pitch in this printer andalso tear/off/bin means
Pitch is the size of the caharacters or the letters.Tear off is where the paper gets torn off by the perferation.It is used to push the paper up or down after printing to a position where the tear off guide meets the perforation.
Oct 29, 2012 | Epson LQ-2090 Matrix Printer
My epson lq 2090 paper load problem occurred find the solution about that
It's very cold in your place? And the paper is tick? I noticed problem with tick paper in the cold season, but i'mnot very sure about this.
Dec 20, 2010 | Epson LQ-2090 Matrix Printer
Sir, I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for...
have you created same paper size as per windows 98 custom paper size ..... if not create as same please create the same and select the printing area also in the server properties ...... in the printing preference change page size to your created page size in layout tab advance option and in paper/quality tab advance option ... and check it ....
Nov 20, 2009 | Epson LQ-2090 Matrix Printer
Printer Epson LQ 2090 ask to insert paper for every pages
Please take note of the paper used. Letter Size A4 or custom. This can be set on the PC (Mac or Window). If not you may just reset the hardware by holding the 1st and 3rd button and then power on. You may hear a beep sound after resetting. Good luck
Sep 02, 2009 | Epson LQ-2090 Matrix Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Sir,
May 19, 2009 | Epson LQ-2090 Matrix Printer
Solution
seconds; then turn
Jun 11, 2008 | Epson LQ-2090 Matrix Printer
Epson lq 2090 matrix printer
Jan 31, 2008 | Epson LQ-2090 Matrix Printer
Epson LQ-2090 Matrix Printer Logo
345 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
