I have a Fisher & Paykel smart drive 9 excellence 7.5 washing machine and the is a squeak coming from the bottom of the tub?
  • Washing Mach... Master
  • 713 Answers
Hi Craig,just read your posting.The squeak could be the bearings.Is the machine noisy on spin?Could you reply back and tell me what part of the cycle the squeak happens.Looking forward to your reply.
Posted on May 18, 2011
We have a Fisher and Paykel Excellence 7.5 SmartDrive 9. I think we lost wedding ring through it. Do these machines have a coin catcher in them somewhere?
have a look under the machine where the tub hose goes to the pump
the catcher is in that hose
the tub hose will go in the top and the pump hose in the side so that any items drop to the bottom and are not put through the pump impeller
Mar 16, 2017 | Fisher and Paykel Washing Machines
Fisher & paykel smart drive 9 mw059au no power
Most of the faults are pump related.
check the Ohms reading on pump should be 33- 35
If readings are less change your pump.
Jul 28, 2012 | Fisher and Paykel Washing Machines
Our Fisher and Paykel excellence 5.5 smart drive 9, washes fine but when it comes on rinse cycle it wont drain the water and makes a humming sound.
Check your pump with a multimeter for correct reading
230V AC Pump 50Hz 33Ohms +/- 8% @ 20oC
110V AC Pump 60Hz 7Ohms +/- 8% @ 20oC
Also check for blockages that may stop pump from turning.
Disconnect from power & Bail out all the water you can before removing pump.
Jul 07, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Fisher & paykel excellence 7.5 smart drive 9 manual
www.fisherpaykel.co.nz/admin/pdfs/pdf_usecares/426991_aw_uc.pdf
Sep 05, 2010 | Washing Machines
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Cleaning washing machine
pull dispenser up and off lossen large plastic wing nut in bottom of agitator throat lift agitator off if you wish to remove basket pull plugs out front corners of top remove phillips screws lift top up remove agitator as described remove ring on top of basket it just snaps off lift basket straight up
Jun 13, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
F/P Excellence 6.5 smart drive 9
Your inlet valve could be clogged, check this out.............
Dec 26, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
173 people viewed this question
Top Washing Machines Experts
