Question about Dishwashers
I have a Bosch, it appears to be be stuck mid cycle. The rince button light is on. Water is not going in but the pump seems to be drawing the water away, I have put water in to the machine manually to try that part out. Pressing all buttons and holding or pressing the pair to reset dones not work. It did its overnight wash and it was put on again just to do another wash as some things were not totally clean and this is where it appears to have got to its stuck stage.
    Problem Solver:
  • 7 Answers
You have water in the base of the d/w, under the actual tub. This can be cause by a seal leak or too much soap. If you take the bottom panel off and feel inside the white base by the motor on the right side you may find water.
Posted on May 18, 2011
My F&P GW601 stops during final rinse, and beeps an error condition.
  • I just fixed a F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.)
    Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!!
Aug 29, 2015 | Fisher and Paykel Washing Machines
Will not rince at end of wash cycle
If ur machine have additives cycle, check whether the solenoid valve (for opening water inlet to the additives' tray) is working or not. You can check this by listening to the sound of water during additive cycle. If it is not working, you have to replace the water inlet valve unit.
Nov 19, 2012 | Bosch Washing Machines
Bosch classixx 1200 express spin light flashing water wont drain pump is running water draining very slow i checked for blockage none found help... thanks
Sounds like the blockage is closer to the drum, Tilt the machine as far back as you can to access underneath. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
Feb 28, 2011 | Bosch Classixx WFC 2465 Front Load Washer
I have a Bosch washer wfc5301uc it is showing error code E02
Could be a faulty inlet valve, or not enough pressure to operate valve,
Remove hose onto valve, and check the water is getting to it o/k,turning off the water to the valve before you undo the hose.
Hope this helps.
Jan 10, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Powerpoint dishwasher TW26
    cannot change the program low salt and low rince lights on but no lights on the cycle indicator lights.
    May 02, 2008 | Dishwashers
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
    Bosch WLF 2260
    suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
    Jun 14, 2007 | Bosch Axxis WFL 2060 Front Load Washer
    Dishwashers Logo
    32 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
