Question about Poulan Pro PR550N21R 21Inch Briggs Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) ()
I cannot find the oil drain plug? The only bolts under neath are the engine mount bolts?
  • 608 Answers
Hi, they are made to drain from the dipstick filler. Remove the dipstick and lay the mower to that side. Remove the sparkplug cap first as a safety precaution. Hope this helps, regards Phil.
Posted on May 17, 2011
I have a 2001 chevy astro van, all wheel drive. How do you change oil pan no one has a book for it
looks like a tough job ahead
taking the sump off ?...motor in the engine bay
could try undoing plenty and lift the body up
if you cant get clearance under neath with motor in the engine bay
motor will have to come out
if trying with motor in the engine bay
lots of drive train in the way ..
undo engine mounts
support the motor .... even lift motor a bit
for clearance from steering gear and chassis ,suspension etc
to get the sump off
cant tell if it covers AWD
2001 Chevrolet Astro Manuals
Nov 09, 2016 | 2001 Chevrolet Astro
Is their an oil cap under neath lawn mower that can be used to empty oil?
Good question. Unfortunately is varies. Some mowers have a Plug underneath ( look at motor casing , past the blade). Some have a metal tube or a small plug on the side of the engine very close to where the Engine mounts to the deck.
Some just want you to pour the old oil out the Fill.
Sep 10, 2015 | Craftsman Garden
On a 3.8L what is the aspec diagram and tourque for the racker arm
Hi Juan, I'm AL the owner of Big As Auto Repair
Below is the torque specs for the rocker arm as you requested.
SPECIFICATIONS - TORQUE
DESCRIPTION N·m Ft. Lbs. In. Lbs. Camshaft Sprocket-Bolt 54 40 - Camshaft Thrust Plate-Bolts 12 - 105 Forged Connecting Rod Cap-Nuts 54 +¼ turn 40 +¼ turn - Cracked Connecting Rod Cap-Bolts (Refer to 9 - ENGINE/ENGINE BLOCK/PISTON & CONNECTING ROD - INSTALLATION) Crankshaft Main Bearing Cap-Bolts 41 +¼ turn 30 +¼ turn - Crankshaft Main Bearing Cap Cross Bolts (3.8L) 61 45 - Crankshaft Oil Seal Retainer Rear-Bolts 12 - 105 Crankshaft Damper-Bolt 54 40 - Cylinder Block Drain Plugs 20 15 - Cylinder Head-Bolts (Refer to 9 - ENGINE/CYLINDER HEAD - INSTALLATION) Cylinder Head Cover-Bolts 12 - 105 Flex Plate to Crankshaft 88 65 - Engine Mounting (Refer to 9 - ENGINE/ENGINE MOUNTING) Powertrain Torque Strut 54 40 - Exhaust Manifold-Bolts 23 - 200 Exhaust Crossover Pipe-Bolts 54 40 - Intake Manifold - Lower-Bolts 23 - 200 Intake Manifold - Lower Gasket Retainer-Bolts 12 - 105 Intake Manifold Upper-Bolts 12 - 105 Lifter Yoke Retainer-Bolts 12 - 105 Oil Filter Attaching Fitting 54 40 - Oil Cooler Attaching Fitting 27 20 - Oil Filter 20 15 - Oil Filter Adapter-Bolts 28 - 250 Oil Gallery Plug 27 20 - Oil Pan-Bolts 12 - 105 Oil Pan Drain-Plug 27 20 - Oil Pressure Switch 23 - 200 Oil Pump Cover Plate-Screws 12 - 105 Oil Pump Pick-up Tube-Bolt 28 - 250 Oil Dipstick Housing-Bolts 48 35 - Rocker Arm Shaft-Bolts 23 - 200 Spark Plug 16 12 - Thermostat Housing 12 - 105 Timing Chain Case Cover -M8 Bolt 27 20 - -M10 Bolt 54 40 - Water Pump-Bolts 12 - 105 Water Pump Pulley-Bolts 28 - 250
Should you need extra help visit my website here: http://www.bigasautorepair.com/
Apr 15, 2015 | 2005 Chrysler Pacifica
How do i remove 2008 cobalt oil pan?
  1. Raise and support the vehicle.
  2. Place a drain pan under the oil pan drain plug.
  3. Remove the oil pan drain plug.
  4. Drain the engine oil.
  5. Remove the engine belt
  6. Remove the lower AC compressor bolt.Remove the 4 oil pan to transaxle bolts (1).
  7. Remove the oil pan bolts.
Jun 17, 2011 | Chevrolet Cobalt Cars & Trucks
Location of oil filter
It's close enough to the drain plug .It's to the right and a little forward of the drain plug when looking under neath the vehicle. It's mounted in a recessed part of the bottom cover so you have to look up for it.
Aug 04, 2010 | 2001 Chrysler Sebring
How to remove oil pan on kia sportage 99? thanks,Zak.
Hi Zak:
Kia Sportage 1998-02 Repair Guide
Oil Pan - Removal & Installation
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain the engine oil.
  3. Remove or disconnect the following:
    Negative battery cable 2 Top intake manifold bracket bolts Front 3 axle housing mounting bolts, 4WD only Left front bushing from the axle housing mount and lower the front axle housing Both gusset plates from the engine Transmission under cover Engine under cover Oil pan mounting bolts and using a scrapper tool separate the oil pan Oil pan Oil strainer assembly Oil baffle 76b1888.jpg
  4. Fig. Exploded view of the oil pan assembly mounting
To install:
Fig. Tighten the oil pan bolts in sequence
  1. Clean the engine block, oil pan and baffle pan surfaces of any gasket material.
  2. Apply a continuous bead of Loctite Ultra Blue 587® silicone sealant around the baffle pan.
  3. Install or connect the following:
    Oil baffle. Torque the bolt to 84 inch lbs. (9.5 Nm). Oil strainer. Torque the bolts to 84 inch lbs. (9.5 Nm).
  4. Apply a continuous bead of Loctite Ultra Blue 587® silicone sealant around the oil pan.
    Oil pan. Torque the bolts to 84 inch lbs. (9.5 Nm). Transmission under cover. Torque the bolts to 84 inch lbs. (9.5 Nm). Gusset plates to the engine. Torque the bolts to 33 ft. lbs. (45 Nm). Engine under cover Front axle housing into position. When properly aligned, torque the bolts to 48 ft. lbs. (65 Nm). Intake manifold bracket bolts. Torque the bolts to 34 ft. lbs. (65 Nm). Negative battery cable
  5. Fill the engine with clean oil.
  6. Start the vehicle and check for leaks, repair if necessary.
Hope helps with this (remember rated this) Good luck.
Jan 12, 2010 | 1999 Kia Sportage
Where is the oil filter?
on most vehicles the oil filter is can shaped and mounted on the engine block, and will be found from under neath of the vehicle to change the oil 1 jack the front of the vehicle and secure it on stands 2 place a collection pan under the vehicle (large enough to hold the vehicles oil capacity) 3 remove the plug on the bottom of the oil pan to allow oil to drain 4 use an oil filter wrench to loosen the oil filter (it will contain oil as well) 5 allow several minutes for oil to drain, the longer the better 6 replace the plug 7 pour some oil into the new filter, and oil the rubber gasket on the new filter 8 replace the filter by hand (do not use filter wrench to tighten) 9 tighten the new filter by hand to one full turn after the gasket touches the engine and no tighter 10 refill from the top of the engine to vehicles oil capacity with recommende weigth of oil note. the engines capacity and the engines capacity with filter differ for the filter will hold oil as well 11 lower the vehicle from jack stands change every 3000 miles when driving in town change every 5000 miles when driving on highway
Jan 09, 2010 | 2009 Toyota Camry
Oil pan removal
Follow the steps below.
1. Drain the engine oil.
2. Remove or disconnect the following:
Engine under cover
Oil pan
Oil baffle
Jul 08, 2009 | 1999 Kia Sportage
Location of oil drain plug on a 1999 HD Road King Classic
The solutions are close, so I must assume they are HD Road King answers, just not a 1999 Road King. The drain plug is on the front (facing the forks) left side (clutch) of the oil pan. On the 1999 model the drain plug is a 3/4 inch bolt. After changing the oil, be sure to replace the O-ring. The O-ring is rubber and does not last more than a single oil change. HD charges a dollar for the O-ring, but better to replace it than to end up with your new oil all over the garage floor.
Nov 11, 2008 | 2006 Harley Davidson FLHR Road king
Oil plug
Bottom of oil pan...underneath the bike. Approach the undercarriage from the leftside of the bike, so you will not have to deal with the exhaust pipes. Remember to change your oil filter with every other oil change.
Nov 10, 2008 | 2004 Suzuki GSF 1200 Bandit N
Poulan Pro PR550N21R 21Inch Briggs  Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) () Logo
138 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
