Sony Handycam  DCR-SR40 Camcorder Logo
Posted on May 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery not charging properly, but the charging indicator is on. i then turn on the camcorder and it says its got no battery life and then goes off. can you help? thanks
Anonymous
Level 3:
  • Master 43,501 Answers
  • Posted on May 17, 2011
Anonymous
Master
Level 3:
Answers
43501
Questions
0
Helped
10843791
Points
101584
Did you try a need battery???
I think you will find that the battery is bad...
heatman101
Does it really need to be plugged into an outlet to turn on?
NO - the camera should have a battery life for at least 2-3hrs for video taking and playback.
It does need to be in it's base to recharge properly , maybe the battery is low and , but , once charged fully you should be able to turn on/off many times.
Try letting the batteries run down very low - and then leave them charging for 7-10 hours. -- Ray
A968 battery problem
This is a very commen with Chinese stuff. The looks are perfect, but the quality is exactly otherwise. Sorry to hear of your prob. See if you can find a standard battery of a good brand with the same specifications. Its better to buy a good and expensive battery than go in for three low quality ones. Give it a thought.
Aug 05, 2009 • Cell Phones
Willnot turn on
Do you know if the charge light blinks when it charges or like mine it stays on untill charged then goes out, if it is blinking when it normally stays on during charging then it could indicate a fault ( usually with the ccd ) and could prove to be a costly repair if not under warranty, maybe worth getting checked out.
Regards
Sharky
P.S. it could also indicate you have a faulty battery or ac adapter
Charging lights turn red and green...But camcorder will not power on
All right if you have the same problem that i had what you need to do is take the battery out the take the memory card out the put the battery back in then try and turn it on if it works then put the memory card back in and it should be fixed
Apr 29, 2009 • Cameras
Power goes off when booting ...
Hi if you had not used your notebook for sometime and kept it without charging the batt., then charge the batt fully probably for 12 or 14 hours and then switch it on .
Battery charge is finished very soon without even using it( in about 5 hours)
The proper way of charging the battery on your phone is by waiting for your phone to indicate that it's running out of powe but not completelyr, if you frequently charge your phone even if it's not yet necessary(battery life indicator show half-way) the ability of the battery to store power will deminished hence the battery life is shorter. Last resort would be trying another battery unit to test if it's your battery of your phone that's causing the unsual battery drain.
Or you can try the following steps on conserving your phones battery life;
  • Turn off your Infrared and BlueTooth when not in use. Even when they are not in use, they do keep drawing power looking for signals.
  • Switch off the vibration alerts. Vibration causes a lot of power usage thereby making battery drain fast.
  • Re-adjust your screen brightness to around 50%. Screen power is another silent killer.
  • Usually, presetted Backlight durations are of pretty high order, this can be readjusted to get more from your battery. Try reducing the Backlight duration.
  • Often we don’t understand that playing games requires Light, Sounds and Shakes. This in turn leads to tripling of battery drainage.
  • Lower Ringing and other message sounds. This too helps saving a lot of battery.
  • Finally, do charge your battery before it gets drained fully. This enhances battery life.
Samsung SC-D363 won't charge battery
well , just make sure that the camera is set to the off position when charging , otherwise i dont think it will charge properly.
hope this helps
2answers
I can't turn the camcorder on!
* Be sure the battery is connected properly. * Remove and replace the battery. * Connect the power adapter and ensure the battery is fully charged. * * The battery pack may be fully exhausted and require replacement. To ensure the life of your battery, be sure to remove it each time you are finished using the camcorder.
Is the battery dead?
Batteries can and will eventually die. Proper charging and discharging will prolong the life of your battery.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
