Question about HP D1560 Deskjet Printer InkJet
Printer printing very slow... it used to print at normal speeds earlier suddenly it has started printing very slow...
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 145 Answers
Something might have been stucked with in the wheels check it and oil the wheels.
Ifthis solution helpful/useful for you please rate my solution. THANKS FOR USINGFIXYA.
Posted on May 17, 2011
Why did my printing rate suddenly slow down to about 20 Why did my printing rate suddenly drop to about 20 % of normal
Check the print quality settings in the Printer Control Panel. If set to best and color it will slow printing considerably and use ink much quicker. Draft and B&W printing is usually fastest and sips ink compared to other modes.
Feb 20, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
HP P3015 suddenly printing very slowly - about a page a minute
If you unplug the cable from the printer to the PC and print the MENU MAP, does it print slow or at normal speed?
If it prints slow, try following the directions below.
If it prints at normal speed, try removing the printer from the print queue and reinstalling it. Also, download the PCL5 drivers and reinstall it.
Good Luck.
Print a MENU MAP and a CONFIG page.
You will need this info to put the settings back in the printer.
1. Turn the device off.
2. Turn the device on. When the memory count begins, press and hold the CHECK MARK button. Continue holding
down this button until all three device control-panel lights flash once and then remain on. This
might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the ^ button
until COLD RESET is highlighted.
4. Press CHECK MARK . The device performs a cold reset and then continues its power-on sequence.
5. Check all I/O settings and reset any customer-set device configuration values.
COLD RESET sets ALL control panel menu items, including network settings back to factory defaults.
This is where the MENU MAP and CONFIG info come into play.
Feb 09, 2011 | HP P3015 Laser Printer
Very slow printing - HP 5610 all in one
Very simple solution: The cartridges still have ink in them but printing is very slow. Remove the cartridges from the printer. Take a wet paper towel and wipe the print head on each one until the ink flows from each head. Usually it is the color cartridge because it is used less than the black one. Once ink is flowing again, reinsert the cartridges into the printer and your normal printing speed will return. This worked for me, no thanks to the "experts" or trouble shooting guides.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Slow printing as if memory is full. Prints a little at a time, takes 4min for one page. Restarted and reset defaults.
Apart form changing the Advance Settings from the Printer Properties (i.e. Print directly to the Printer) we can change the Priority of the Print Spooler to make the Printer working fast from the Computer.
The “Priority” of a task is the degree of urgency that the task presents to the Processor- Request from a task with higher Priority are served earlier.
Now the default setting for Print Spooler is to run at Normal Priority. Now if the Customer mostly use his Printer for printing form Computer, we can make the Print Job faster by change the Priority.
Here is the Solution Below:
1. Open up the Registry Editor
2. Navigate to :
HKEY_LOCAL_MACHINE/ System/ CurrentControlSet/ Control/ Print
3. Right Click on the Print folder and create a new DWORD value called “SpoolerPriority” and set it according to what value you want or if it exists, just
set the value.
The value are as follows:
OxFFFFFFFF for IDLE Priority
0 for Normal Priority
1 for High Priority
Aug 11, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Epson R200 print job suddenly slows down
Your printer memory is full and it needs to wait to take on more data files for printing.
Jul 13, 2017 | Epson Stylus Photo R200 InkJet Printer
Lexmark printer is printing slow. Is there a way to check the memory?
change the printsettings from best or better to normal. in best or better mode the printer prints slow. in normal mode the printing speed will increase. thanks
Nov 13, 2008 | Lexmark Office Equipment & Supplies
Konica Minolta PagePro 1350W low print speed
Jacques,
Print speeds will vary based on a lot of factors. First thing to note is that your printer should have a first print time of about 20 seconds. This means the first page should take about 20 seconds before it starts printing and than will print at rated engine speed.
Secondly, depending on the type of paper and thickness your speed may slow down. Most printers will slow down for a thicker paper. In general the thicker the paper the more time it needs for the toner to fuse or melt to the paper.
The size of the paper will also greatly affect the speed too. Manufacturers spec their machines to letter size in the portrait orientation (the leading edge is the 11 inch or long side). In general for legal you will have a 15 to 20% reduction in speed and for 11 x 17 you can have as much as a 40% or more reduction in speed.
Print resolution may affect the speed. Usually most printers will print faster in a draft mode. This may also reduce the amount of toner used.
How do you connect to your printer? Different cables all have different speeds. For that matter is there an upgrade to the RAM? This could also change the speed of the print job. However these should not affect the final speed too much.
So to get the "rated" speed of your printer you will need to use standard letter paper with the long edge leading. Remember don't use thick paper and use a draft mode or lower resolution if possible to get the best speed.
I hope this helps.
Henry
Jun 02, 2008 | Konica Minolta PagePro 1350W Laser Printer
Printing Slow
hi,
check the length of the usb cable. if it is very lengthy then there would be problems with the speed.
if not
> unplug the usb cable
> click "start-->control panel--> printers and faxes"
> select the printer icon and delete it
> restart the computer
> plug the usb cable
> wait for few minutes while the driver installations are complete automatically.
> once that is done, try to print
thanks and regards
agnel
Mar 08, 2008 | HP Photosmart C3180 All-In-One InkJet...
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Hope this helps.
Jan 05, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP D1560 Deskjet Printer InkJet Logo
418 people viewed this question
Seeker5211
Seeker5211
