Question about Packard Bell Computers & Internet
Can not plug monitor in to tower - Packard Bell Computers & Internet
  • 56 Answers
More details please..
Why can't you?
Pins in the plug are bent?
2 different types of plugs?
Posted on Aug 14, 2008
6ya staff
SOURCE:
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
I NEED TO HELP WIRING MY COMPAQ HOME COMPUTER
Set all items up ready to be installed Plug in your mouse and keyboard into the back of the tower. If u are using the old style connectors these have pins and will also be colour coordinated so you know where to plug into tower. They will have a notch inside so plug in carefully so not to break pins. If they are USB connections they will be square at the end and u will see where these plug in at the back of the tower these do not have colour coordination as u can plug in anywhere. Next your VGA cable, this is the cable that looks the same both ends with 15 pins in it. One end goes into your monitor and the other into the back of the tower these are shaped so they only fit in one way, again caution that you do not force in as you could bend the pins. Next ensure u have the power leads into the tower and the monitor, these are the cables with a plug on one end and a female 3 hole socket at the other, u will see where these plug into both devices. Next plug into wall ensuring socket is off first Then switch on Switch on your tower....monitor should come on by itself, if not hit the power button on your monitor Voila ...done
Oct 27, 2011 | HP Compaq Evo D310 PC Desktop
Moniter reads no signal but tower light is on
Have you changed your resolution recently? Have you installed any programs recently? Have you made any hardware changes lately? Make sure the monitor is firmly connected to the tower and to the back of the monitor. Is the monitor plugged into the wall outlet? If you have two video ports on the back of the tower make sure you are plugged into the correct one, you may also try switching to the other port. Try another monitor if you are able to or try the monitor on another tower to see if you can isolate the problem to the monitor. Do you get anything appearing on the monitor when you first start the computer up? Have you been using a video card or onboard graphics?
Jan 04, 2011 | Acer Aspire X3400 (2702458) PC Desktop
No sound from this monitor. I have everything plugged in , volume icon is turned all the way, mute is off, adjusted speaker levels, etc on my desktop.
Firstly,
You need to check if the green cable from the computer tower is blugged into the back of the monitor (The cable looks the same at both the ends) this is for the output to come through the monitor.
If that is plugged in and if not working, Try a headphone on the tower and check if the sound is coming from the headphone, If yes, You will have to adjust the volume on the monitor or the speaker of the monitor might have gone bad. If there is no sound coming in, Then the problem is with the tower and not the monitor.
Dec 02, 2010 | Acer X193W LCD Monitor
I dont know how to hookup my monitor to the tower
You will have two plugs coming from your monitor
One will have a blue plug that looks a little different, the other one will have a regular plug which can be plugged into your power surge or into a wall outlet.
The blue one will match up with a port on your tower. If you look on the back of the tower where all of the plugs go you will see one that looks similar but is opposite to the one coming from the monitor. Make sure you turn it to fit then screw it in and you should be good to go
Nov 06, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
Monitor plug on tower is loose.can i install a another video card and how do i do it
open the tower before replacing the video card, try to tight the screws that hold the video card,
if is necessary to replace it, take one screw on top of the video card, and pull it up,
May 18, 2010 | Computers & Internet
My hp2009m monitor goes into sleep mode
Monitors are programmed to go to sleep when there is no input. If you shut it down on the other "tower" also it will do the same. You need to physically hit the power button on the monitor to actually shut it off.
Feb 15, 2010 | HP Computers & Internet
I have a hp2009m flat monitor and hp a1473w
everything seems to be working as normal.. that is just a message and it happens with some of the monitors.. you don't have to worry about it..
Tower won't turn on
hi try to put the monitor lead in the tower, the leads are both the same, the fuse might be out in the tower lead.
Mar 28, 2009 | E-Machines eMachines Desktop PC
Plugged speakers into wrong slot and the monitor went black and the tower started beeping. Monitor and the tower both have power
Hi...there,
Oh...common...plugged to a wrong hole doesn't caused a black out...It's seems you got a busted backlight inverter....
Jan 09, 2009 | Fuji FP-988D 19" Flat Panel LCD Monitor
Computers & Internet Logo
15 people viewed this question
Top Packard Bell Computers & Internet Experts
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
