Question about Ovens
I have a B6622 Series Built-in Oven (Kelvinator) with a H3420 Drop-in Ceramic Hob (Year 1993). The Overheating Protector for 1 plate is not working. What is the cause and where can I get a spare part if needed. Regards Horst
  • hmarker571 May 18, 2011
    the burner is working but not the limiter, ie, the burner is not cutting off and thus getting too hot.
    Regards
    Many thanks. The solution was helpful.
    Regards
    Horst
    President:
  • 1,654 Answers
Is the burner working but not the limiter? Usually the burner won't work if the limiter is bad. What is the problem is the burner getting too hot or not working at all? Parts for these are available and they are easy to change out as well, they simply unplug and plug back in. If you want to search the internet for parts then just google the make and model for appliance parts and go from there or I would rather get them from a local dealer who can return it if needed .
Posted on May 18, 2011
  • Dcramer531
    Dcramer531 May 18, 2011
    I hve looked several places and can't find anything on this model range or parts for this. I suspect it has been discontinued. I did however find a wide range of Kelvinator range parts that might be inter changable. Does the burner control at all? or does it get too hot when on high? The limiters are for an extreme overheating condition that could cause a fire and they kill the power to the burner or stove when this happens, they are also known as thermal fuses. If the burner is getting too hot when not on high the the burner control switch is the problem. These only work on high or not at all when they go bad. There are replacemet controls available in this link I am going to send you, I still recomend a local dealer if possible. These switches also are very easy to replace, they just have a nut behind them holding them to the front of the panel.
    kelvinator.partselect.com Just cut and paste this in your browser
How can you remove burnt plastic from electric hob oven
from the ceramic or glass cook top
will be a slow process cant scratch the top
hope its not tuppa ware
it will smoke
plastic scraper or solid plastic spatula
with hob off .. boiling water little at a time
may have to low heat the hob again
Apr 16, 2017 | Ovens
Where is the fuse location for Kelvinator wall oven model # R30-1
Kelvinator Oven Product Support ' ManualsOnline.com
kitchen.manualsonline.com/support/electrolux-kelvinator/oven/
How to light an oven of kelvinator KCL86GSC gas co. Kelvinator ... Replacing thefuses on my kelvinator stove model H
Nov 15, 2015 | Ovens
Trying to change element on westinghouse PAK806 stove with ceramic cooktop. cant figure how to lift hob.
Hi I have a Westinghouse PAK806. The oven works fine, heat and fan, but none of the plates will turn on.
Any ideas?
Jul 13, 2011 | Ovens
Where can I get a manual? Can it be downloaded? Thanks
.pdf user manuals can be obtained via steve.richardson@fisherpaykel.co.uk Quoting the exact model number located on the rating plate located on your appliance as detailed below.
Range Cookers
Behind the Drop Down Storage Panel beneath the oven door or on the Oven Chassis behind the door
60cm Freestanding Cookers and Ovens
On the Oven Chassis behind the door
Hobs
On the underside of the hob (any oven or hob situated underneath the hob may need to be removed to gain access.).
Feb 15, 2011 | Stoves Ovens
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
Oct 20, 2010 | Ovens
My glass cermamic cooktop is burned, i mean literally. Its milk stains or sauce stains all over it. And i cant remove it. There are dark brown stains on it. Please help me
try using a ceramic hob specific scraper to removed the burnt on bits then use a ceramic hob cleaner.
Can you let me know what country you are in and I can send you alternative links.
The following link are for the uk.
https://www.bosch-eshop.com/eshop/bosch/gb/ceramic-hob-cleaning-1.htm
311299 is the most cost effective as it contains cleaner and scraper.
Aug 21, 2010 | Ovens
I have dropped a cup onto my ceramic Zanussi hob, is the slither of glass that came off able to be repaired ??
Just to clarify something, is your hob above a double oven D2100-4 because that is only telling me about your oven the hob will have its own Mod. no. But any crack to the glass on any Hob can weaken the glass and really should not be used due to the weight of Pots on glass if the glass did break it could be quite dangerous with all the electrics below.
Hope this gives you some help in the matter.
Good Luck.
May 06, 2010 | AEG D2100-4 Electric Double Oven
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Jul 15, 2009 | Ovens
English Instruction Books required
Hi there ..it is possible these products are for the Turkisk home market and therefore no need for English Instruction....however i am checking this out for you and will contact you shortly
regards Sir Galahad
Dec 13, 2008 | DCS Large Appliances Built-In Ovens...
Ovens Logo
105 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
