Question about Hoover Washing Machines
I've recently bought a Hoover 800F New wave and I don't know how to open the door...can you help me please?
Turn the wash temperature control knob anticlockwise until you come to the key symbol at the end of the blue zone; then turn the knob a little further and the door will swing open; a special safety device prevents thedoor from opening during the wash or at the end of the spin cycle; at the end of the spin wait up to two minutes before opening the door - the instructions from the user's manual. good luck!
Posted on Oct 28, 2011
Vectron wave toy doesn't charge
2Hz is probably the ripple current from the charger.
Apr 14, 2017 | Spinmaster Spin Master Air Hogs Vectron...
Every time I use my New Hoover steam vac it leaks all the time I've tried every thing, I even bought a new tank same problem, I'm not taking it to be repaired its the 3rd one thats done it an
After the second time I would have asked for a refund. Maybe you need to do some diagnostic work.
1. Does it leak while sitting unplugged?
2. Does it leak while plugged in but not being operated?
3 Does it leak when the solution is above or below a certain level.
4. Are you over filling it?
5. Does it leak only when you pull the trigger? (valve problem)
Keep asking yourself questions to discover where and why it's leaking.
Good luck.
Nov 13, 2012 | Hoover Max Extract Steam Cleaner
Computer Running Slow
Okay, you have the same issue I used to have. I inherited a laptop from my mother, and she was the second owner. It was loaded with programs I didn't need, and had a zillion files tucked away. If you can go into your control panel and access the add or remove programs, go through it and remove every stinkin' one of the optional programs you don't ever use, or can do without. Be sure you know what you are removing. Next --and this may sound silly, especially if you have done it already-- you need to go into your homepage in your internet connection and clear all browsing history from every browser you use. These can include google, msn, explorer, firefox, etc. I find if I don't clear my browser frequently, my computer is a real *******. The next obvious step would be to get into all my documents files and delete any old files, such as photos that you don't want, a huge music collection, etc. I have all of my music stored on my D drive, because it has the same memory as my C drive, but is nearly empty. You can store and easily access all your entertainment files in D if you have a large capacity. I would perform this test: from your start menu, open my computer and right click your c, or main hard drive and click on properties. This should give you info on how much storage space you have left on the disc. If it is less than 50 percent, you may need to delete some old trash. Do the same with your d drive. If all else fails, you can go into your recovery program and see if you can wipe the computer, but that is a last resort. I had to do this with mine so I could program it to recognize me as the computer administrator. I was tired of fighting with a zillion hidden files I couldn't get into, much less locate. Hope this will help.
May 02, 2012 | Dell Computers & Internet
How do I find my WEP key?
ITS THE SERIAL NUMBER ON YOUR ROUTER, NOT SURE THE MAKER OF YOUR ROUTER, HAVE YOU TRIED OPENING YOUR BROWSER AND IN THE ADDRESS BAR JUST TYPE 192.168.1.1 AND IT SHOULD BRING UP YOUR ROUTER MENU, YOU CAN ALWAYS CHANGE THE CODE OR DISABLE IT, THERE SHOULD ALSO BE ALL THE INFO ON YOUR ROUTER SOMEWHERE IN THE MENU, WHOEVER SET THE ROUTER UP INITIALLY SHOULD HAVE BEEN IN THE MENU TO SET OR CHANGE THINGS. IF YOUR SETTING UP THE CONNECTION ON YOUR COMPUTER JUST CHOOSE YOU ARE CONNECTING TO A DSL THAT IS ALWAYS CONNECTED, AND IT SHOULD JUST AUTO CONNECT WITHOUT THE WEP KEY, BUT AS I SAID YOU CAN GO INTO THE MENU BY TYPING 192.168.1.1 IT SHOULD GIVE YOU ANY INFO YOU NEED.
Dec 31, 2011 | Computers & Internet
I have an older model Flair unit. I took it apart to try and give it a good cleaning and noticed that there was a small glass bulb-looking part with one of the thin wires was broken. Of course the other...
It's attached to the pulse radio-wave ionizer. It comes on when the unit is on to show the radio wave is working. It's not needed and I've never seen a replacement but Radio Shack could probably help you replace it if you wanted.
Jun 23, 2011 | Ecoquest Flair Air Purifier
Hello good day i have a really serious and somewhat embarrassing problem with my ASA 600.4. After my trunk was slammed a loud ascending sine tone emitted from my speakers and it probably would have...
do you have a cap hooked up?
does the sine wave recreate itself ever? always?
disconnect the RCAs and power up/down. same ascending noise?
ascending sine is usually a leaky capacitor...
need more info
May 09, 2011 | PowerBass ASA6004 4-Channel Car Amp
I've got an Hoover HDC884X Built in Electric Double Oven. Can you tell me what I need to do grill toast. Don't understand the knob controls and the manual doesn't help as it is too generic
Hi, I understand your frustration, the manual supplied is next to useless! The 'obvious' settings appear NOT to work (as the grill remains on full heat setting all the time). The only way we've managed is to lower the food away from the grill..... not ideal I know - but also we don't use it for toast.
I suppose Hoover would be the next best port of call for assistance, oh for a proper manual, not a horrible generic one that attmpts to cover every model they produce - AND FAILS.
This is purchasers main complaint about buying Hoover ovens it seems.
I'll come back to see if anyone can supply a solution to our problem.... and hope it's not a fault in manufacture.
May 05, 2011 | Ovens
Hoover 800F User manual
Hi.
I can point you in the right direction
Go to Hoover in your browser, and go to after sales, download user instructions.
You should find what you want.
Good luck
Nov 16, 2008 | Hoover AAA140 Front Load Washer
Washing Machines Logo
245 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
