SOURCE: base phone handset #1 holding charge
The base unit should not need a charge. It should be powered by the plug in adapter. It may have a battery to keep operation for a short time in a power outage. The adapter may be loose, the adapter could be broken or the plug in the phone may be broken.
SOURCE: uniden coedless phone displayn problem
Not sure of your model, but on mine, you hit the menu button, arrow down to global setup, hit select. go to CIDCw (CALLER ID W/ CALL WAITING) and hit select, select ON option for call waiting or call waiting deluxe.
Hope this helps.
SOURCE: Dead Uniden DCT5280 Handset
if battery just replace battery but the head sets are compatible with other handsets of same ghz say 2.4 you just gotta set in base and let base recognize new hand set these phones are practically built the same way but only with new technology
SOURCE: I am going away for 3 months. Should i leave my
hi, its not safe to leave it on since you will not be using it, over charging could destroy the battery.
cheers
