Question about Amana ABB2222FE (22.1 cu. ft.) Bottom Freezer Refrigerator
Auto defrost not working causing ice build up. How does one remove cover of evaporator with drawer slides in place? Is it necessary to remove drawer slides to remove evaporator cover?. If so, how are slides removed?
3 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: drs2662aw amana side by side
Sounds like you may have a restriction or blockage, may also be low on freon
Posted on Aug 25, 2007
Sea Breeze
  • 4654 Answers
SOURCE: Ice is building in the freezer - I can manually
WHEN YOU JUST DON'T HAVE THE MODEL NUMBER Yes, tere are tings to check but I need the model number to help you bctter .The problem is most likely the defrost timer. I don't have your model number so I am going by what I can find about a Kenmore Elite.
The defrost timer is located most times insid the fresh food compartment and behind theconteol panel. Usually there is a hole that you can put a flathead screwdriver through and slowly turn the timer clockwise until the refrigerator compressor and fans stop. Let it stay like this for about 25 minuites until the compressor restarts. During this time the refrigerator should be in defrost. Open the freezer and listen for crackling and sizzling noise caused by defrost. If the compressor does not restart turn again clockwise and this will restart. If you nee the defrost timer here is a link below.
482493 Defrost Timer
Let me know if this don't work and we will need to go mto step 2, Thanks, Sea Breeze
Posted on Jul 29, 2009
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
Samsung RM255LABP/XAA freezer only gets to 27 degrees, won't harvest ice. Fridge and lower freezer work fine.
Ice cannot be produced at that temperature you're going to have to find out by taking the drawer out removal of the rear wall of the freezer and see if the evaporator is freezing over or is the condensate drain opening is blocked. Your model has dual evaporators and we need to see if your evaporator in the freezer is defrosting properly or if for some reason the defrost drain is blocked causing moisture to cover the fan causing a cooling problem.
Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Maytag model MSD2351HEQ freezer side is not working, refridgerator is cold
f1cdedb3-5e7c-47c1-8d68-7566d4da0a75.jpgSounds to me you may have a defrost failure. In most cases the fresh food compartment will show signs first but your model has an auto damper that may be causing the fresh food section to remain cold. Do you notice frost build up on the rear inside back panel of the freezer? Example HERE. If you do you will need to manually defrost the freezer, remove the rear panel of the freezer and use a hair dryer to melt the ice covering the evaporator coils. Example of ice/frost build up on the evaporator coils HERE The most likely cause for the problem is a defective=> 12002495 Defrost Control Board The defrost board is found inside the fresh food section and inside the control panel. Item 12 in this photo HERE is the defrost control board. Second possibility is the=> 67004948 Defrost Heater Item 7 in photo HERE and is the 67004757 Defrost Thermostat and that item location 3 HERE First the defrost control board needs to be checked for burn marks or signs of heat damage. I am here if you would like me to help you get to the parts I listed above, Thanks Sea Breeze
Aug 09, 2013 | Maytag Refrigerators
Kenmore Elite Bottom freezer is causing all kinds of problems. From the start we have had problems with the ice maker not freezing the ice fast enough and overflowing into the slides causing issues with...
Hello, ok lets start with the ice and frost all over the freezer compartment. This is mainly due to your unit haveing a defrost issue. If you were to remove the rear panel on the inside rear of the freezer by unscrewing the screws that hold in the panel you would then gain access to the evaporator coil. There are three key parts that make the defrost function work properly the defrost thermostat, the defrost heater, and the defrost timer or on some units instead of a defrost timer they have a control board located behind a panel in the rear of the machine. The defrost thermostat is usually the first place you would start diagnosing your defrost issue. Also when you remove the rear panel and gain access to the evaporator coil if you found any ice build up on the evaporator you would then defrost any ice with a hair dryer and also assure that the drain hole below the evaporator is clear of ice as well as any obstruction as well. The defrost thermostat is a small round disc like part that has two wires going to usually found on one of the compressor copper lines, the defrost heater is the element looking metal piece that is usually found below the evaporator coil itself. Both of these pieces can be tested for continuity using a multimeter to assure if they are functioning properly. Most of the time it is thhe defrost thermostat that fails that does cause this issue. So first test these two key parts and message me back with your finds. If both of these parts test as working properly I will then further instruct on how to test the remaining parts. Thanks again I look forward to your reply
Rick
Jul 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have recently purchased a Whirlpool Gold refrigerator with the freezer drawer on the bottom. I love it but the freezer has had ice covering the items in it a few times, it almost looks like snow. My...
hello cathy, Depending on where the actual snow is located if it were against the rear freezer wall then you would have a defrost issue in which either the defrost thermostat, the defrost heater, the defrost timer has a fault these parts can be checked by doing a continuity test on them with a multimeter to assure they are functioning properly. If you can message me back the model number i can most likely find your schematic for your machine and point out where each piece is located. On some newer units they do not have a defrost timer instead they have a adaptive control board which takes the place of the timer before you do any checking of these parts it is most important to also assure that you have no rips or tears in the freezer door seal. although if you did you would see the ice build up more towards the door instead of on the rear of the freezer wall. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
p.s you would have to remove the screws that hold the rear panel in the rear of the freezer which would give you access to the evaporator coil and the defrost thermostat and the defrost heater if when you do remove the panel you see the evaporator coil with ice build up on it you would have to defrost the ice with a hair dryer and then conduct your tests this ice build up is a definite sign of a defrost issue Thanks again I await your reply Rick
Jun 11, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Plastic Casing on center back, inside refrigerator is making noise like built up ice. How does that plastic cover come off?
Hi and welcome to FixYa, I am Kelly.
While it is covered in ice and you try to remove it.. you will probably break it. (been there done that) Defrost it manually first. I checked your model number and it is missing the last 3 digits of the model number.... However, the inside of the units are pretty much the same so I used the model ending in BOO. See this link for a picture of the back access cover and screws:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160170&diagram_id=28194805#d28194805
(Items 11, 12 and 22)
The cover has 2 screws and 2 tabs. Remove the screws and gently release the tabs.
NOTE: Ice build up is usually the result of an automatic defrost cycle circuit problem or... a slow running evaporator fan. I do not recommend you even attempt to gain access at this time. (
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Whirlpool GB9SHKXL Bottom Freezer...
I have a Kenmore Elite Model # 795.75546401. Ice forms underneath the freezer drawer and I have to remove it weekly or the drawer wont open. I can not see any access to drain lines in the back or how to...
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:The defrost timerThe defrost thermostat (also called the bi-metal switch)The defrost heaterIf it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problemSelf-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Jan 26, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
Jul 26, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Evaporator fan stops working due to ice buildup around fan.
you need a drain tube heater.it is like a chain fence tie made from alluminum,you can actually use the fence ties,wrap one side around defrost heater and stick the other side in drain.that will prevent it from happening again
Mar 07, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Control panel shows "Er dH"
The “er dh” code means a problem with the defrost cycle. It is triggered when the defrost sensor does not reach 46 degrees F within 2 hours of the defrost cycle starting. If indeed the defroster is not working, the evaporator (in the bottom of the fridge in the freezer compartment and behind a plastic cover) will eventually ice up completely, blocking the flow of cold air to the upper compartment. Use a thermometer to check the upper compartment to verify that no or little cool air is reaching it.  If the evaporator is iced up, the defrost cycle is not working. Quick fix to restore operation to the upper compartment: tape over all vent holes in the upper section to keep that cool while you work below. There are about 6-7 vent opens in the back wall and two large one on the floor of upper compartment. Remove freezer door, drawers, slide rails and pull back the plastic cover (2 screws hold it in place, one in the center and one behind the ice maker) at the rear of the freezer section to expose the evaporator. Spray hot water on the ice accumulation on the evaporator (it looks like a radiator) to melt it (remembering to sop up what flows to the drain pan at the rear). The entire operation can be done in about 30 minutes (most time is used for removing ice and sopping up water from the drain pan). All should be ok for 3-4 days depending on humidity before the evaporator ices up again.  In the meantime, order a replacement control board. You can view this by removing a panel w/ 3 screws at the rear left of the refrigerator. This panel controls all refrigerator functions, including defrost. Most likely, the integrated relay for the defrost cycle failed. Swapping out panels is a 10 minute job. Panels cost about $116 incl shipping from repairclinc.com. Shipping is about a week.  You can find a free service manual on line that will help to identify all parts and is particularly useful for removing doors and trays so you can get at the evaporator.  All in all, the customer service is useless. The fridge however is very easy to work on and amazingly simple. The replacement board has a slightly different relay for the defrost heater, so LG may have realized a problem existed with the original. It is also possible that electrical surges damaged the relay.  In any case, 10 minutes and $116 seems pretty minor to have the fridge back to new condition. Good luck.
Jan 22, 2009 | LG LFX25960ST Stainless Steel French Door...
Amana ABB2222FE (22.1 cu. ft.) Bottom Freezer Refrigerator Logo
67 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
