Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Unit will heat only will not cool and how to repair
We have a split type gree aircon, with one (1) horsepower. it was just newly installed, around 6 months ago. we are just surprised that one when my wife turned it on, thru the use of its remote control, the indicator box on the aircon reads or flashes "F2". I detached the batteries of the remote control for severa hours and I also detached the power cord from the wall socket, but it was to no avail. it did not work. with "F2" on the indicator box, the aircon won't give cool air, it is just working like an ordinary fan. please help us.
Posted on May 29, 2011
  • Terence Fourie
    Terence Fourie Aug 01, 2012
    You wont believe how streight forward wiring these split aircons are, but when rushing, small wiring mistakes do happen. Most of the time the control wiring comes with the aircon and is pre connected into the inside unit allready.. Suggest you switch off at isolator and or pull plug out of the socket then open the inspection/ wiring compartment on the side of the outside aircon.(condenser unit). you will see possibly 2 sets of wires and if larger than an 18000btu unit, there should be a thin set of black plug in wires for the auto defrost sensor. On the wires going into the connector terminals there should be numberscorrelating their connection points. eg. L (LIVE) will go to l on the termonal block. 1 will go to 1 on the block and so forth. Check that those wires are correctly placed or the incorrect output from the control board will go to the incorrect component in the condenser unit. If all is good, then very possibly the 2 way valve is stuck, then you will need professional help. Just out of interest, it should be in warrenty so checking the wiring will be all you could do.e
  • Mitsubishi Master
  • 43,501 Answers
All of the troubleshooting guides are here...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Posted on May 17, 2011
The best way to use the unit cooling
What is the make and model of the air conditioning unit? If you need more questions for your AC Repair needs, check us out online.
Jul 12, 2017 | Heating & Cooling
Fujitsu ASTA12LCC WILL NOT HEAT OR COOL. GREEN TIMER LIGHT FLASHES TWICE AT INTERVALS. FAN WORKING. IS IT REPAIRABLE?
Serial signal reverse error. Basically the outdoor unit is not talking to the indoor unit. This is normally due to damage to the outdoor controller PCB and it needs to be replaced.
Jul 03, 2017 | Fujitsu Heating & Cooling
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
I have 3 Fujitsu heat / cooling multi split ductless units connected to one rooftop unit. Only in heating mode and only coming from the same indoor unit is a loud almost screeching/vibration sound. It can...
If it happens in heat it must happen in cooling. The indoor unit has nothing to do with if it's heating or cooling. You likely have 2 moving parts in the machine, the blower wheel and the swing fins. Turn swing option off, eliminate that. You get the rest...
Jun 04, 2017 | GE Zoneline AZ38H12DAD Split System Air...
Friedrich SS12F10 chassis fan is running compressor not cooling is it worth repairing - how much
Hello, if this is a window ac and is not cooling I would make sure the unit is receiving proper airflow across the evaporator coil, chek filter and clean if dirty, clean evaporator coil with coil cleaner which you can purchase at any heating and cooling store. If the unit still does not cool than ypu most likely have a leak in the system and is undercharged. In this case the repair would be between 80- 120 dollars. In some cases if the unit is less than the repair you are better off buying a new unit. However, if your unit is more than the repair then you are better off getting it repiared.
Apr 28, 2011 | Friedrich Heating & Cooling
Have a lg lfx25960st has frost on back wall of freezer fan was making grinding noise now no noise and wont freeze ice thanks d hopper
Older freezers have a mechanical timer that shuts the cooling unit off and activates a heating element to melt the ice that forms on the cooling coils next to the fan. Newer ones control it with a circuit board. It sounds like yours is not defrosting and the ice buildup has stopped the fan. Or the fan could be bad and without the airflow thru the cooling coils they are covered with ice.
You need to remove a cover inside the unit to get to the fan, cooling coils, and defroster heating element. There could also be a thermostat attached to the heating element that will need to be checked.
Unplug the unit, disconnect the heating element and check for continuity ( with an ohms tester ) , it should give some reading on the tester. You will need to talk to a repair shop to get the exact ohms it should read. If you have a friendly repair person, they will tell you how to check everything out.
Sep 23, 2009 | LG LFX25960ST Stainless Steel French Door...
Heat pump not cooling after wiring damage repaired.
Do you have the model number? This would help find the code
Aug 10, 2009 | American Standard Heating & Cooling
High cool and low cool not working
Pls check the following....
1) Fix the wire connector to Reversing vale
2) Check the Capacitor if this a low capacitance or (open) not function using Multi-tester.
3) Check the Selector switch if this is not function using Multi-tester . or check the PCB Board (if electronic your units) replaced the Board.
If not yet,go to the nearest repairman to repair that units.
Thank you,have a nice day.
Edgz
Jan 25, 2008 | Amana PTC093B50AJ Electric Heat Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
1,236 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
