Question about Pentax Optio A10 Digital Camera
Camera shutting down and zoom not operating
Surfron,
Can you please describe whic two screws you removed to resolve the issue with the zoom lens not operating. A sketch would be GR8.
Would appreciate any help you could provide.
  • Plan1 Aug 17, 2008
    Ron,
    Thanks for the assistance.
    Solution worked perfectly.
    UR a Champion.
    Thanks
    Heaps
  • 3 Answers
I took my camera apart again to show you a picture of it. The yellow arrows show the position where they used to be. The screws are next to the camera on the table.
Greetings, Ron.
Posted on Aug 14, 2008
I took off the battery for charging,but the lens did'nt back to it original place..as i put back the fully charge battery,still,it did'nt automatically shut down or back to normal....
Camera has to be repaired. The lens assembly with the focusing, iris setting, zooming is fubar and needs help.
Until resolved you will continue to get that error message.
Aug 12, 2015 | Nikon Coolpix 5000 Digital Camera
Camara restrarts
Usually a camera only shuts down, when one of its sensors detects a dangerous situation. somewhere a voltage to high, or somewhere it is overheating. Or the lens is not moving free. With some camera's you can force a shut down, by only pressing the lens a little, or just touching the lens while zooming or focusing. Don't try this, because it can damage the lens system. If nothing off this all happened to your camera, perhaps you should ask a service centre. But please check yourself, when you are focusing or zooming, that you don't touch the lens barrel.
Jan 26, 2014 | Sony Cyber-shot DSC-H50 Digital Camera
Lens comes out then camera shuts down. it has had 2 new sets of batteries in today
Hi there
The problem is with the sensor inside the camera responsible in sensing that zoom lens is out. do the following to resolve it
1. Turn on the camera
2. When the lens comes out try to observe the oreantation of the lens
3. Pull the lens a little outwards very carefully.
4. the camera will turn off, now turn on and it will work fine.
regards,
Saleem
Aug 26, 2011 | Cameras
WHEN ZOOMING IN WITH MY CAMERA IT TELLS ME TO SHUT OF POWER - VERY FRUSTRATING
The Turn off and on again error message displays when there is an internal malfunction or a malfunction with the Lens. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Main Settings 1 Menu of the Camera to OK. (Home-->Settings-->Main Settings--> Main Settings 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa
Jan 18, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
3 beeps after switchon and no operation
There is nothing you as the user can do to fix the camera, you have two choices, sent it back to the maker for repair/exchange or replace the camera.
May 17, 2017 | BenQ DC C740 Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Lens goes in and out three times when turning on or shutin off.
Try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists service of the Camera is recommended.
Jun 15, 2009 | Sony Cameras
Won't zoom out
This seems to be a common issue.
Mine was stuck at what seemed like max optical zoom.
When i would look in the lens I could not see the zoom lens. If you can not see your zoom lens and the optical zoom seems stuck I bet your camera has the same STUPID issue that mine has.
It was out of warranty and I figured I had nothing to loose so I took it apart to see if I could fix it, turns out I was able to fix it just by taking it apart and putting it back together!
Taking it apart is simple enough for the average handy man, if you do not have confidence that you can take it apart then do not attempt this repair.
Take off the bottom cover.
Take off the Hard drive cover
Now remove the three screws under the hard drive that hold the drive's plastic housing in.
Remove the screw that is right under the record button, now the drive house should be loose.
Disconnect drive cable from board and remove drive and housing.
Take off the plastic piece that has the zoom button, be sure to gently disconnect the wire.
Remove rear piece.
That screw marked with an arrow on the bottom, do not remove it!
Now remove the thin metal piece to expose the flat cable.
disconnect flat cable from board
gently flex it out of the way so you can disconnect the cable behind it.
Once you have both disconnected remove the circuit board.
unplug the flat cable on the back side.
Now remove the front piece.
At this point you are nearly there!
Now remove the metal housing that holds the lens assembly.
Once removed remove the lens assembly by removing the three screws.
If you thought that was bad, this next part will scare you.
Make sure you are in a very clean room with no fans blowing.
Remove the CCD from the rear of the lens assembly by removing the two screws on the back that hold it in place.
Remove the foam and square lens piece that were behind the CCD.
On the side of the assembly is a screw that holds the top cover in, remove it and gently pry off the top cover.
looking inside you will find the following:
on the CCD side is the focus lens.
in the middle is the shutter
On the side farthest from the CCD is a zoom lens.
On mine the zoom lens was not close to the shutter
If your zoom lens is not close to the shutter then you likely have the same problem as I had and you can fix yours!
If not, you likely have some other issue :-(
To fix mine I turned it over and I loosened the screws that held the motor and shaft for the zoom lens.
Then I slid the zoom lens as far back as it would go towards the shutter.
Then tightened the zoom lens motor and shaft mount.
Put it all back together, installed battery and bingo it's working again!
Why did this fix the problem?
Well there is a little sensor that tells the camera that the zoom lens is near the shutter.
Each time you turn off the camera it always puts the lens in that "home" position.
If the camera is turned on when the zoom lens is not in this "home" position then the camera seems to assume the zoom is broken and you end up with the infamous JVC stuck zoom issue.
My guess is this problem is caused by any of the following:
1. Removing the battery while the camera is turned on
2. Dropping the camera while it is on or off
3. Battery going dead while camera is in use
Final thoughts before you get started:
1. If you are not good at working with tiny parts or electronics, I wish you luck because you will need it. Might be better off printing these instructions and taking them with you to a repair facility and paying someone more familiar with this sort of work to fix it for you.
2. The ribbon cables are removed easily. Each one has a clamp that rotates to release the ribbon. Some rotate towards the ribbon to release, others work the opposite. It is quite obvious looking at them which ones go what way.
--e100
Sep 03, 2008 | JVC Everio GZ-MG21 Camcorder
Lens error, restart camara issue in SD900
well **** that doesnt sound complicated or anything.
Feb 29, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Pentax Optio A10 Digital Camera Logo
82 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
