Question about HP Office Equipment & Supplies
Printer keeps asking to align catridges - HP Office Equipment & Supplies
  • 56 Answers
Take out the cartridges and replug them back in.
Also if you go to the printer's property page, there is sometimes maintenance tools like align cartridges.
To get to printer's property page in Windows XP goto Control Panel --> Printers and Faxes --> And right click on your printer and select properties.
Posted on Aug 14, 2008
SOURCE: Catridge alignment
Actually my main problem was my HP Deskjet Printer was not connected to the computer so I went to HP website/support and they me the solution by downloading the printer diagnostic utility and check those with those device that are in red code and there I had it, bullseye.Ok?
Posted on Sep 07, 2008
pankaj_dic
  • 1250 Answers
SOURCE: align catridge
its the utility present on its software it self use it , for the allignment
Posted on Oct 15, 2008
  • 240 Answers
SOURCE: psc 900 keeps asking to align cartridges.
uninstall and reinstall the driver of the printer...
other solution...
flash another compatible firmware to it..
replace the encoder strip of the printer..
maybe the encoder was destroyed...
Posted on May 12, 2009
nonontech
  • 4737 Answers
SOURCE: When I replaced the black catridge #32 and
This is another very common issue and Lexmark blames the Cartridge, (Non-Lexmark cartridge).
Well, let's try this, Remove all the cartridges, Turn off the machine, let it cool for few minutes (10 minutes will do and don't forget to unplug the power cord and the usb cable).
Now turn back On again, install the cartridges (with no issues) followed by the one which is showing the error, Press and hold down the Cancel button while it's being installed. Release the cancel button when you are done. Now let it show up whatever it wants to...If you are asked to align the cartridge, Keep tapping the cancel button while and don't let it align.
If anything shows up on the computer screen, click more and uncheck the box and then close the window. Now restart the printer and check if the same message reappear or not.
Let me know if the problem persists.
Good luck.
Thanks for using FixYa.
Posted on Oct 06, 2010
  • 5 Answers
SOURCE: my printer has a new full ink catridge. the
clean jets and retry
Posted on Jul 19, 2011
I keep getting a error code 1203 what does that mean
Hello
It means your catridges overflow even from brand new catridges after several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge
use a klennex with a few drops of water to dampen and clean off those contact on the holder and your printer should work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned catridges a couple times then run clean catridges a couple times.
Print the test page to see how it looks .
Be sure not to leave any debris of klennex on those holder contact panel.
Jun 10, 2011 | Dell 926 All-In-One InkJet Printer
I keep getting the message Alignment Failed.
hello deer1626, if a printer gives you a message alignment failed that means your catridges are not properly installed try removing the catridges and fixing them back you will get a notification of aligning just follow the onscreen instructions and thats all
Jan 03, 2011 | HP Officejet Pro L7680 All-In-One Printer
HP 6000 Won't print with yellow cartridge
Try this :
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Regards
Soumajit
Mar 12, 2010 | HP Officejet 6500 Wireless All-in-One...
Cartridges alignment problem
To align catridges:-
  1. Load plain paper.
  2. Press the Menu button, and scroll to Align Cartridges.
  3. Press Select. An alignment page prints. Once this page prints, your automatic alignment is complete
To do it from your computer:-
  2. Open the lexmark Series Utility.
  3. From the catridges tab, click align catridges.
  4. Click OK to print alignment page.
  5. This will be make the alignment successful. If not successful, it should be done manually.
Aug 25, 2009 | Lexmark X4270 All-In-One InkJet Printer
'colour cartridge is not compatible'
please make sure you align the catridge before using if not it will keep showing, if you actually aligned it reinstall the driver
Jul 16, 2009 | HP PhotoSmart 1315 InkJet Printer
Lexmark 2500 printer problems
its very possible the new cartridge is faulty. I would suggest getting another one. Some new cartridges are acutually refurbished and just refilled and sold. Eventually they stop working correctly.
Joe
May 26, 2009 | Office Equipment & Supplies
I hve a installed a new hp print catridge but it deos not print
It asks you to align it. Press ok. The printer will print off an alignment page, then you have to run it through the copy part of your printer. Then press ok, and it will run through and line things up for you.
Apr 15, 2009 | HP Officejet 4215v All-in-One Printer
Align catridge
Oct 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Won't print anything. always wanting to print a test page
hi this is a ink catridge align ment problem. u do one thing. go to printer properties and printer priference and go to service tab than u check ink catridge align ment.. than ur printer working fine...
Aug 18, 2008 | Lexmark X2500 All-In-One Printer
204 people viewed this question
Ben Johnson
