Question about EnGenius / EOC-8610 EXT / 54Mbps / 802.11a/b/g / Dual Band / Outdoor Wireless AccessPoint
Resetting the engenius eoc 8610ext
I google "resetting the 8610" and keep getting information that doesnt work. im using windows xp service pack 2. im using the eoc 8610 ext. it wont let me into it, when i try to ip into it. i think my fellow soldier friend went inside of it and change the ip address of the unit. i google this, and came up with procedures that dont work. do anybody know the correct way to reset this unit to the factory setting if it can be done. i did purchase the cable that i read you was suppose to have. the problem is: when i hyperlink into the unit. i get to the point after you set up all the setting it wont do anything or say anything after you type in flash reset.
confused in iraq.
  • net123 Oct 18, 2008
    same issue no # after typing flash reset
  • daneh May 23, 2009
    same issue and I have tried this on two different radios, one that I CAN log into (so I know it works) and one that I am unsure about. Neither radio gives me anything in HyperT. :-(
    ~le cry~
  • 481 Answers
I have reset lots of these using the manufacturer's instructions.
Plug in the serial cable before powering on the unit. When you power on the unit, you should be able to see a log of what the unit is doing. If you can't, then your parity, bits, speed, etc. in Hyperterminal are set wrong.
When the unit stops logging (usually with a #), type in
flash reset (and hit the return key)
You should see a bunch more logging, indicating that the unit is shutting down and rebooting. After that, you should be able to log into the unit at 192.168.1.1 with admin/admin or admin/(blank).
Posted on Nov 26, 2009
How do reset "EOC 8610
Push in the rest button on the back:
Reset Setting
  • Reboot (press 1 second)
  • Reset to Factory Default (press 5 seconds)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 17, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
I pushed the reset button on my engenius IEEE802.11 b/g router......it isnt working now it says it is on my when i try to use it on my computer and my xbox360 it automatically says that i dont have a...
When you push the reset button, you reset the network configuration to factory default. Now you have to reconfigure the unit to re-establish the network routing and addressing for your home network, the same way you configured it when you first got it. Its default address is either 192.168.1.1 or 192.168.1.2, depending on whether it was in bridge or AP mode when you reset it.
Aug 27, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
EOC -8610-S having problems conecting to 192.168.1.2, the login screen doesn't come up in the browser. It does on 192.168.1.1 though
The devices can be misconfigured or damaged.
Check if radio working fine, perform a site sruvay with a laptop (wireless).
Oct 06, 2009 | EnGenius EOC-3220 (EOC3220)
I forgot ip address of my EOC 8610. how do i
Try address 192.168.1.1 in most cases this is default IP for the routers.
Sep 23, 2009 | EnGenius / EOC-8610 EXT / 54Mbps /...
Restoring engenius EOC 8610 to factory default
Resetting the older beige Engenius radios requires a screwdriver and a USB-to-serial cable. You must unscrew the small plate at the bottom, which covers a serial connector. Plug the serial cable into it and then into your computer. Follow these instructions to perform the reset:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
Mar 31, 2009 | EnGenius / EOC-8610 EXT / 54Mbps /...
Resetting EnGenius EOC 3610
Dear Venmattey,
please follow these steps, it works:
1. Connect the EOC-3610 to your computer with a null modem serial cable.
2.Start a HyperTerminal session: Click Start and then select Programs-> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3610.
b. Select correct COM port. Ex:COM1.
c.Set baud rate as "38400", data bits "8", parity "none", stop bits "1",and flow control as "None". Then press “OK” to bring up theHyperTerminal window.
d. Unplug the power on the POE injector and wait 5 seconds then plug the power back in.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
NEW: Keenan Systems has written a software that will soft reset the 3610 series back to factory reset. Thisfree software is provided "AS IS" by Keenan Systems and is notsupported or guaranteed by EnGenius Technologies. Use at your own risk.
Be Happy Always
Regards
Dec 03, 2008 | EnGenius Computers & Internet
Senao 8610 not working
Are you saving your settings when you exit the setup screen?
Johnlgrn
Dec 29, 2007 | EnGenius / ECB-8610 / 54Mbps / 802.11a/b/g...
EnGenius / EOC-8610 EXT / 54Mbps / 802.11a/b/g / Dual Band / Outdoor Wireless AccessPoint Logo
1,223 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
