The cable may be broken inside. First I would remove the speedo clock and undo the cable that goes into the back, unscrew the nut anti clockwise and pull out the cable, it may have snapped at this end or at the other end where it goes to the front wheel. if its not snapped push the bike forward and note if the shaft is spinning. if it is not then it is broken. Trace the cable down to the front wheel and there will be a similar fixing going into the hub of the wheel, unscrew this and check that the shaft in the cable is broken or spins or not. I think you will find that the cable is broken at either of the ends. Hope this helps. Alex
