Question about Dell Latitude D600 Notebook
Connecting my laptop to my Samsung DNie 29' Tv
I am trying to connect my laptop Dell Latitude D 520 to my TV using a S Video cable (7 pin), i get the picture, but it is black n white. Can you please help....
  • 2 more comments
  • Yaddu Aug 14, 2008
    Yeah!! The laptop video output port is a seven pin. No, there is no adapter for the video output
  • Yaddu Aug 15, 2008
    i have a 7 pin SV cable and the output point on my laptop is also seven pin. I get the image on my laptop, but it is black and white
  • Yaddu Aug 16, 2008
    kewl.. will try that!! Thanks
  • Anonymous Mar 18, 2014
    the laptop has Windows 7 Pro 64Bit Os. The connection is via a HDMI cable
  • 56 Answers
Are you connecting the S-Video directly into the video output port of your laptop? S-Video 7pin? Video output port 7 pin too?
Is there an adapter for the video output port, for your laptop?
Posted on Aug 14, 2008
  • 1 more comment
  • Joe L.
    Joe L. Aug 14, 2008
    Try upgrading the video card drivers.
    If your connecting your 4pin s-video into the 7pin video output port on the laptop directly it should work fine. As it does for my own laptop.
    Comment back for more help if that doesn't work.
  • Joe L.
    Joe L. Aug 15, 2008
    Try using a 4pin to 4pin SV cable, as I had the same issue with my laptop. And I just tried connecting the 4pin directly into the 7pin video output port and it worked. Picture with color!!
  • Joe L.
    Joe L. Aug 16, 2008
    not a problem....
How to connect 520 to a tv
In the Quick Reference Guide ()
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d520_setup%20guide_en-us.pdf, at page 12, you can see 2 connectors that can be used to connect your laptop to the TV (4=S-Video TV-out connector and 6=video connector).
Depending of your TV (type and model), you can use one or both of theese connectors. For an analog TV you can use only the S-Video TV-out connector, using a proper cable (S-Video to S-Video or S-Video to SCART). For a digital TV (LCD, LED) you can use also the video connector (D-Sub 15 pin), if your TV is equiped with a similar video connector. If not, you must use a converter, but is more expensive.
In all cases you must use a second cable for the audio signal (see the audio connectors, at page 11).
Aug 09, 2014 | Dell Latitude D520 Notebook
S-Video Connecting Laptop and PC
The best way is via the VGA connector on the computer and by connecting the Audio out on the back of the computer to the RCA sockets on your TV. You will need a 3.5 mm jack to stereo RCA cable for the audio.
May 05, 2013 | Computers & Internet
How could i connect this tv to laptop
Connect by this way:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Sep 16, 2010 | Samsung CW29M64NS 29" TV
How do I connect my dell laptop to my LG LCD TV
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
May 30, 2010 | Dell Latitude E6500 Laptop
Why does the s video output on my dell latitude d600 not work?
You must have the correct drivers installed, and you must enable the output as a second monitor but to do that you must connect to the TV IN first. Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally.
Feb 17, 2010 | Dell Latitude D600 Notebook
HOW I CONNECT MY LAPTOP WITH TV LAPTOP MODEL IS DEL LATITUDE D600
all you need is a connecting cable depending on your laptop's tv out port. The following website displays several connecting cables. http://www.cableuniverse.co.uk/catalog/cable/pc-to-tv-cables/ Also, update your bios and graphic drivers
Nov 07, 2009 | Dell Latitude D600 Notebook
How to connect dell laptop to samsung 29 inch tv using cable
Dear Sir,
For getting display in TV you have to select input source as TV generally in all other laptop
short cut key is fn+f4. generally short cut function key shows picture of small square box.Search for that short key then activate the out put for TV by pressing that key with Fn keys.
I think it solves your problem.
good luck
Aug 27, 2009 | Samsung CW29M64NS 29" TV
Conection to TV using S-video on Dell D600
Google this and read the forums... d600 s-video out
Dec 10, 2008 | Dell Latitude D600 Notebook
Problem connecting my dell latitude laptop to my tv
Check the monitor settings under "Display Properties/Settins/Advenced/Monitor" (right click on desktop).
Dec 02, 2008 | Dell Latitude D600 Notebook
Connecting Dell Precision Laptop to Samsung 29 inch Easy View (CRT) T.V
dear sir.
here u have to chek cable yr laptop is not support with a same s-cable u need to connecter for s-vadio to audio vedio connector and it's convort yr s-cable to comosite cable afer that it's automaticly dosply thru composet.... yeah one thing have to chek with different cable then selacet display propatise to set output setting is set in to s-video.. it's help u...:)
Thanks
please vote
jo_chinmay
Mar 16, 2008 | Samsung CW29M64NS 29" TV
Dell Latitude D600 Notebook Logo
820 people viewed this question
Alun Cox
