Question about Motorola Mobility RAZR V3
Bluetooth The bluetooth light constantly stays on even when the bluetooth is disconnected.
    Brigadier General:
  • 7,752 Answers
Try master clearing and resetting the phone
Posted on Aug 21, 2008
SOURCE:
My jbl charge 2 power light stays on but wont turn on or off. What's wrong
if its connected via the included usb cable to your device , it will as power is being transferred via cable to units battery, if your using Bluetooth only , device will stay on as long as any Bluetooth signal is in range , and this can be any devices Bluetooth signal , even your thermostat will trigger this to stay on , use your phone to scan for other sources of Bluetooth ? it should develop a list of avail blutooth devices in range (they might not belong to you??)
Jun 25, 2015 | JBL Audio Players & Recorders
Bluetooth will not stay connected to cell phone when wi-fi is in use
If this only happens at home, you can probably enter the wifi settings and change the channel it uses to connect. If it happens any time you're near a wifi connection, you'd have to change the channel setting within the Bluetooth device if that's even possible.
Mar 08, 2014 | BluetoothTronics.com Plantronics Marque 2...
Bluedio model N65 can t connect to my blackberry
I hope you would have followed the instructions correctly.
Here they are again:
1: Ensure that the bluetooth is set to be discovered, you do this by holding down the power button, in other words the one on top, the light should blink a few times until it stays on without blinking.
2: Quickly go to setup on you blackberry, (if it is more convenient you may do this first) select bluetooth setup, then select search.
Given that the blue light remains constant on the bluetooth, meaning it's no longer blinking, the phone should find it, connect, using any code, I suggest 0000, and my friend your bluetooth is ready to free you of the pain and heat, for those who love speaking for long hours, that your ears so often suffer.
Happy Connecting!!!
Jul 29, 2011 | Computers & Internet
Cannot figure out how to pair my jabra with my blackberry bold......both work....just wont connect
Go into your Blackberry's Bluetooth menu and after turning Bluetooth on, scroll down to Bluetooth Options and select the item. A new menu will appear, scroll to the item which allows you to set Bluetooth to be discoverable (by default, it's hidden). You may have to click on Options to find this menu. You can set it to be permanently discoverable (a security risk) or to be discoverable for just 2 minutes.
Turn on your Jabra headset by holding down the main button until the blue light stays on constantly.
Go back to your Blackberry Bluetooth menu and click "search devices". After your Jabra shows in the results list, select it to add it to your phone.
If prompted for a passcode enter either 0000 or 1111 (varies by Jabra model and by the country it's sold in).
Your Jabra should now be paired and the constant blue light will revert to an intemittently flashing blue.
If this has resolved your problem then please let me know by taking a moment to rate my answer. If not, then please add a comment and I shall attempt to assist you further when I'm next online.
Jul 22, 2010 | Jabra Bluetooth Headset with Adjustable...
When charging my H710 bluetooth, do I have to wait until the green light goes off before disconnecting it from the charger? Thanks
No, you don't have to wait. The green light doesn't actually go out. It stays green until you disconnect the headset from the charger.
Jan 10, 2010 | Motorola Mobility H710 Bluetooth Headset
I cannot get it to connect. My Palm Centro recognizes it, but says that is unable to connect even though it has done so in the past.
Try disconnecting the bluetooth device then turn the bluetooth off then hold the power button untill the bluetooth shows a solid red light then try connecting the bluetooth between your palm and the bluetooth device hope this helps
Oct 24, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Not pairing with HTC touch and bluetooth headset
I got jabra bluetooth which is not getting connected with my HTC touch mobile.It is not getting detected.
Oct 07, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
How do I put Jabra BT 135 in Discovery mode?
Turn the device on and continue holding the power on button until the light stays solid. That puts it in discovery mode.
Pair it with your device.
It will probably also ask you for the password to the bluetooth headset (mine did). The default is 0000.
Jun 30, 2009 | Jabra Bluetooth Headset with Adjustable...
My insignia bluetooth headset will not turn off
Plug the power adapter into the headset. Then press the Volume up and down buttons (+ and -) on the headset simultaneously. This will reset the device.
Jun 28, 2009 | Insignia Bluetooth Wireless Headphones...
Purple light wont stay lit for pairing
Make sure the microphone is closed and the BlueTooth is off. Hold the button in until it turns purple. As soon as it does release the button and flip out the microphone. The purple light should stay lit all the time now. That is until the pairing process is done with the phone.
Mar 18, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility RAZR V3 Logo
138 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
